07-08-2020, 02:33 PM | #2 | |
805
Rep 1,790
Addbuyer832.00 |
07-08-2020, 03:21 PM | #3 | ||
Rep 2,420
CC with braking function is the classic CC that brakes to the new set speed when you manually decrease the speed your self. If you want automatic speed regulation you need adaptive cruise controle. |
Addbuyer832.00 |
07-08-2020, 03:41 PM | #4 | |
Rep 444
My X5 is supposed to be fitted with something called ‘cruise control with brake function’ so I’m thinking it’s standard cruise control but with an emergency brake function to avoid hitting the car in front should it slow down or perform an emergency stop. I would then expect the driver i.e. myself to have to move off again / take control to move off again? I have used the cruise control for the first time today and there certainly isn’t any type of brake control I let the car run up behind slower cars in front as close as I dare before taking control. So where is the ‘with brake control’ I am getting concerned about what I’ve purchased here. It’s an ex demonstrator which I noticed immediately upon collection, hasnt got the hot/cold cup holders installed despite the car having the comfort plus package. It’s got all the other comfort plus features, soft close doors, massage cooled seats etc. I’m not in the slightest bit bothered about the cup holders, it’s something I would never use but the brake function on the cruise control is a safety feature. I’ve also noticed that the pedestrian braking or collision avoidance system might not be operational either as I’ve got it set to early but not once has it altered me to some incidents that have been close calls so to say |
07-08-2020, 03:48 PM | #6 | |
Rep 444
Thanks guys |
07-08-2020, 03:50 PM | #7 |
Rep 444
07-08-2020, 03:58 PM | #8 |
Rep 243
The "with brake function" does seem to be standard in today's cruise control systems, but I remember that my 1996 E39 BMW would only accelerate or coast but never break in cruise control, thus occasionally gaining speed on downhill slopes.
Addbuyer832.00 LogicalApex2024.00 |
07-08-2020, 04:00 PM | #9 | ||
Rep 2,420
The CC brakes if you lower the set speed with the levers on your steering wheel. And that is all the braking it does. So only if you manually order it to do so. It is the classic term Bmw uses for the standar cruise controle since years. The standard emergency braking for cars and pedestrians is only for city speeds. It needs the radar of adaptive cruise controle to be active on highway speeds. It is quite difficult to activate emergency braking on purpose. So it is hard to test. |
Addbuyer832.00 |
07-08-2020, 04:14 PM | #10 | |
Rep 444
X5 45e1090.50 |
07-08-2020, 05:03 PM | #11 | |
Rep 7,468
CC w/brake function (aka dynamic cruise control) is not the same thing as ACC (adaptive/active cruise control ), or CC w/active driving or traffic jam assist:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-08-2020 at 05:26 PM.. |
07-09-2020, 04:55 AM | #12 | |
Rep 444
I didn't come across any info when searching so thanks very much. Im the first 72 seconds of that video. |
09-23-2021, 04:14 AM | #14 | |
Rep 2
Software download
I am going to be in the same position as you and I was interested to see if that worked? |
09-23-2021, 09:50 AM | #15 | |
Rep 444
I have had adaptive cruise in other vehicles and find it useless so wouldn't spec it. Maybe things have improved since my last experience of ACC but i found it too slow to pick up once it had braked and another two cars had pulled into the gap it left so it braked again... never got anywhere |
09-23-2021, 12:59 PM | #16 |
Rep 6,797
I recently drove 2000-miles over a week, mostly on ACC. It works. I think it works a little better with the last s/w update I got (03.21) versus the s/w it was delivered with (07.20). You can set the following distance you want. Safety people recommend a 2-second gap between you and the vehicle ahead, whose distance will obviously change based on your speed. I tend to set mine to max, but it does tend to encourage aggressive drivers to pull in in front of you! One of my pet peeves is people that pass, then pull in front of you with little gap on a multi-lane highway where there's nobody else around...this causes the ACC to slow down unless you manually hold the speed until the gap increases. Way back when I was learning to drive, the instructor always told us to not pull back in until you could see the entire front end of the vehicle you just passed in the mirror...that generally will put you far enough ahead of them so if they have ACC, you won't cause them to slow down and it's a lot more comfortable for everyone involved.
On an older BMW, on a long grade, instead of using the brakes, I noticed that it downshifted rather than using the brakes...that is safer, because on a really long downhill, you could easily overheat them if they were constantly being applied and then not be available should you really need to stop. It might have used the brakes in other circumstances, but generally, I didn't notice. I guess it did slow down fairly quickly with the steering wheel buttons, so may very well have been using the brakes. |
