07-10-2020, 02:05 AM | #1 |
Rep 73
Remote start and climate control
Does any one know how to control the temperature remotely?
I prefer to keep car AC set at 69F. But, car seats in hot weather. So before going home I prefer to remote start the car from the app and want Mac AC to cool down faster. But it seems it only stays at 69. It will be max AC only if car was set to max AC before turning off. Any idea how to change the temp remotely? |
07-10-2020, 10:35 AM | #3 |
1053
Rep 1,952
To add to that, you can start the car up to 15 minutes before departure - after that it will turn off. So maybe just start your pre-cooling routine a little earlier.
BMW says it will allow 2 consecutive auto-starts before you have to manually start the car. So you could conceivably start the car up to 30 minutes before you leave. I imagine that would be plenty of time to cool down the car. |
07-10-2020, 11:17 AM | #4 | |
Rep 647
In theory, you leave the A/C in full auto mode at the desired temperature. The climate system knows if the car is hot or cold and to what extent and should be able to achieve the desired temperature quickly. For example, if it is very hot inside the cabin and the temperature is set at 70 turning the temperature to 60 will not blow any colder air at first than 70 until the temperature in the cabin gets close to the set temperature. |
Tenac4538.50 |
07-10-2020, 11:58 AM | #5 | |
Rep 3,507
2022 M8 Comp Convertible
dream54ing485.50 |
07-10-2020, 12:53 PM | #7 |
Rep 647
07-10-2020, 03:07 PM | #8 |
Rep 116
Drives: 2024 X5 50e LCI
The seat ventilation and heated seats won't activate until the seat belt is connected. So starting the car with no one in the vehicle, the seat ventilation would not activate.
07-10-2020, 03:39 PM | #9 | |
Rep 2,420
