Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > M57 Tuning, Maintenance, Parts and DIY MEGATHREAD
      10-23-2017, 01:27 PM   #89
Persian Whisperjet
Kind of a Big Deal
Drives: 2011 335d
A piggyback is simple and can get you some zip but a tune comes in many varieties to suit your performance goals *plus* you can "tune out" undesirable components like SCR, DPF, and EGR so that the car knows they are gone and no CEL puts a suntan on your forehead.
Torqu3321.50
      10-23-2017, 03:21 PM   #90
M5_1of400
M5_1of400's Avatar
Drives: 2018 M5 / 2011 X5 35d
Piggybacks like JBD is a "plug and play" little box that intercept signals and adjust accordingly to dump more fuel.. so this is a cheap way to get extra HP, this is good for people on a budget or people that don't plan on keeping the car for long.. all you have to do is pull the JBD out and you are back to stock numbers.
Chip tuning like JR,BPC, etc. actually change the code in your DDE.. in a nutshell the car's permanently coded to perform A LOT better (if you plan on selling the car you will need to have the DDE re-flashed to come back to stock numbers). This option is much better but more expensive... totally worth it if you plan on keeping the car for a while. Most people in this forum go with JR 2.8 or BPC 2+ both of options unlock the full potential of the D without the need to swap any stock parts... but you will need to do deletes to avoid issues.
Welcome the D side.. cheesy I know.. sorry.
Originally Posted by TTStevens View Post
Looks like I'll be getting my first 335D within a couple weeks and this thread has helped a ton! I've owned a number of diesel trucks so I'm a little familiar with all the alphabet stuff but still learning for the 335D. I see a lot of discussions about "piggybacks" vs tunes. What exactly is the difference if someone could explain it a little better to me? I think I have a general idea, but want to verify that I have it right. Or point me to a thread that breaks it all down. Thanks!
      10-23-2017, 06:20 PM   #91
TTStevens
Drives: 2009 335d
Ha ha, thank you for the imagery and the info.
Thanks for the details and in-depth info. The car I'm looking into has a piggyback already and I'll probably leave it on for a bit as long as it's not turning the dash into a Christmas tree or the dreaded limp mode. Eventually I'll do a tune, but I figured an exhaust would be first that way I don't have to tune it again after the new pipes.
      10-23-2017, 07:26 PM   #92
M5_1of400
M5_1of400's Avatar
Actually if you are wanting to do your exhaust you must do the chip tuning first.. when you mess with the exhaust you are dealing with a bunch of sensors in the DPF and the SCR and the DEF tanks, the only way to avoid issues is to tune the car first.. that's why tuning is so much better.. all those sensors plus many many other things get disabled so they don't interfere with mods you do on the car.
I highly suggest you go look for the upgrade threads that tell you exactly what you need to do and how to do it.. this car is VERY temperamental if you don't do things right.. read read read.. (not trying to be rude) it is imperative you educate yourself very well before you start doing stuff to the D.. I cant stress it enough.. you'll thank me later.
[/QUOTE]Thanks for the details and in-depth info. The car I'm looking into has a piggyback already and I'll probably leave it on for a bit as long as it's not turning the dash into a Christmas tree or the dreaded limp mode. Eventually I'll do a tune, but I figured an exhaust would be first that way I don't have to tune it again after the new pipes.[/QUOTE]
      11-21-2017, 04:23 AM   #93
bait me
Drives: 2011 335d
bump
      11-30-2017, 04:14 PM   #94
747galaxy
Drives: 2009 BMW 335d
I've had the JBD diesel tuner for about a month and drove about 1,500 miles with it. After I installed it, I felt a big increase of power. Driving on the highway, you can easily go from speed limit to 90+ mph with just a small push on the gas pedal. No, it won't make it a diesel M3, but it will definitely increase the power you feel.
I don't know how it compares to a tune, but IMO, it's a good deal for some cheap horsepower.
      12-13-2017, 11:52 AM   #95
BB_cuda
BB_cuda's Avatar
769
Drives: 2011 335D Msport, 2013 X5D
Torqu3, it would be great to here where the X5 mods are same and where they differ. I know they use the same EGR delete pipe/racepipe. I don't know that is done with the "X5 only" low pressure EGR.
Looking at X5 specific downpipe looks to perhaps delete the connection to the inlet to low pressure EGR. I don't know specifics for removal of the low press EGR as well as what it connects to down stream. I will learn soon enough but pointing to areas of needed enhancement. Perhaps what i ask is buried in here and I haven't tripped over it yet. thanks
      01-01-2018, 12:28 PM   #96
335dsleeper
389
Drives: 09' 335d 10'35D
There is a flange piece sold by BPC and AArodriquez that blocks the low pressure EGR port on the backside on the LP turbo.
X5 delete pipe is longer than the 335d and the buzzken delete comes with the SCR delete section as well.
Other than that, performance mods and deletes are the same.
My X5 is done and it's amazing!
      01-10-2018, 03:20 PM   #97
Torqu3
Drives: 2011 335d
Ever expanding and updating this. I understand that it's a lot to take in, but it really is for the best that you know this information. Being knowledgeable with these cars can save you thousands in shop fees.
      01-14-2018, 03:32 PM   #98
BB_cuda
BB_cuda's Avatar
769
Finished the deletes on 1-3-18. I only lack the bimmertune, swirl flap blanks and clean the intake manifold while there. I don't expect to see much CBU since it's a 48,000 mile X5.
      01-29-2018, 10:01 PM   #99
fsd350
fsd350's Avatar
Drives: 2010 BMW 335d
Cuda, any words of wisdom on removing the DPF? I understand it is more difficult than on our cars. Been putting it off for a couple years.
      02-07-2018, 08:18 AM   #100
HudZ
10
Drives: 2011 BMW 335D
2011 BMW 335D  [0.00]
One thing I noticed not on this sticky are the software apps for diagnostic/whatever else they have the capability of doing. Would be nice to have a list of my options.
Torqu3321.50
      02-07-2018, 10:53 AM   #101
Torqu3
Drives: 2011 335d
I'll try and get something set up here in the next few days.
      03-05-2018, 10:42 PM   #102
HudZ
10
I would suggest adding this post for the vacuum line replacement. The pics and captions are perfect. I did a full swap in maybe 45 minutes. The best parts are understanding how to disconnect plugs. Those things are rubix cubes.
http://www.e90post.com/forums/showthread.php?t=1308500
      03-06-2018, 08:34 AM   #103
Torqu3
Drives: 2011 335d
Thank you for the suggestion! It's actually already linked in the DIY guides.
      03-21-2018, 09:59 AM   #104
alan308
Drives: BMW 335d
Originally Posted by Torqu3 View Post
I made sure to specify red scoops. We know the secret of the scoops.
Anyone ever see red scoops on a Le Mans Blue335d?
      03-21-2018, 11:20 AM   #105
Torqu3
Drives: 2011 335d
Looks the same as any other lemans blue e90 with red scoops. Pictures of that all over the internet.
      04-27-2018, 05:30 AM   #106
Defeo335d
Drives: Bmw 335d e92
Bmw 335d simple reliable tuning
Hello everyone If anyone can help from the UK
I'am in the process of purchasing another bmw 335d msport e92 after my first one was written of due to idiot drivers :/!
My previous one was a 2008 bmw e92 with a remap and dpf filter removal was pushing out 330bhp and 705nm perfect for me at the time didn't need any more then that to be honest and had no problems with her for 5 months before the accident.
Could anyone in the UK confirm any good tuning company's for this vehicle
2010 Bmw 335d e92 shape as I would like the same tune but have seen some people having problems with boost hoses etc and I don't fancy having any problem with a remap DPF filter tune.
Any help is much appreciated
I don't mind having a little more power just don't wish to have a tune pushing like 400bhp 800nm etc cause I'm guessing running costs problems a more to keep onto of just want something fun and pain free.
Thank you
      05-07-2018, 10:33 AM   #107
robnitro
Drives: x5 35d e70 2011
Can we add a howto on glow plugs and the controller?
I just did it on my x5 35d, which is similar.
Some pointers that should be emphasized:
-Warm up engine before removing the intake manifold to prevent the plugs from breaking in the head!
-Make sure you feel the connectors for the gp controller click in.
-After that, don't start the engine, but key in- ignition on- scan for codes and clear them and scan again. Of course there will be codes for things disconnected BUT make sure you don't see any glow plug codes to confirm that your installation is correct- if so, then you can go and put the intake manifold, etc back! (in other threads I read cases where poor souls had to remove the intake again due to a bad connection to the controller!)
      05-07-2018, 02:36 PM   #108
Torqu3
Drives: 2011 335d
I can work on it another day for sure.
      05-24-2018, 08:53 PM   #109
rlmccarty2000
Drives: 2011 BMW 335d, 2011 BMW M3 ZCP
2011 BMW M3  [0.00]
2011 BMW 335d  [0.00]
Is there a thread of verified independent shops in the US or do I need to go on Facebook to find these?
      05-25-2018, 12:01 PM   #110
Torqu3
Drives: 2011 335d
Facebook is typically easier, but judging by your posted location(Fitzgerald, GA) the best shop I know of that is somewhat local is AARodriguez Corp. www.tunemyeuro.com is the website. They do a lot with BMW diesel.
For just generic shop work, try this website: https://www.bimmershops.com/
