      01-16-2024, 09:33 AM   #1
Diirek
Diirek's Avatar
106
Drives: E93 M3, G05 X5 xDrive50i
Harmon Kardon - Spare Tirewell Woofer Install
Pretty underwhelmed with the bass output of the Harmon Kardon system. Decided to grab a retrofit subwoofer harness from Technic PnP and a cheap spare tire sub off of amazon. All-in I'm around a $350 investment.
Speaker install was a breeze with the battery and chassis grounding points being directly adjacent in the trunk. Confirmed the unit powers on but waiting on the PnP harness to show up in the mail today. Will report back on sound quality if anyone is interested.
I have a hunch I'll end up returning the Rockville woofer and replacing with the more expensive JBL but maybe the Rockville will surprise me....
      01-16-2024, 06:27 PM   #2
Diirek
Diirek's Avatar
106
Initial Reaction: Don’t know why I was expecting more from a $200 speaker 😂. Managed to get decent sound out of it after tweaking some settings, but don’t think this one is a keeper.
      01-18-2024, 08:25 PM   #3
E91toG05
E91toG05's Avatar
351
Drives: 2022 X5 45e
I mean you knew this had no place in this car lol
      01-19-2024, 08:14 AM   #4
Diirek
Diirek's Avatar
106
indeed I did.... already spec'ing out the replacement.
      01-26-2024, 08:26 AM   #5
Diirek
Diirek's Avatar
106
Wanted to follow up after a week or so. Still planning on swapping out in the future, but there appears to be a break-in period with the speaker.
I'm sure my ears/expectations have also adjusted since install, but the sub doesn't sound half bad now. It's punchier and overall cleaner throughout the lower frequency bands. Still not the solution for an audiophile, but well worth the $200 if all you're looking for is some decent bottom end and an easy install.
      02-11-2024, 08:23 AM   #6
swainbmw
swainbmw's Avatar
533
Drives: 2022 x5 40!
[QUOTE=Diirek;30847527]Wanted to follow up after a week or so. Still planning on swapping out in the future, but there appears to be a break-in period with the speaker.
You would be better off, replacing the front speakers, including the base under the seats and adding an amp that will give your true sound Quality you’re looking for the hk only has about 463 watts from factory
      04-25-2024, 03:16 AM   #7
dombi
11
Drives: X5 - G05, 30d (2022)
Diirek
How is your Subwoofer project going?
Can I ask what you ended up doing?
Have you found a solution that you are happy with?
      04-25-2024, 07:15 AM   #8
MADBMWX5MC
MADBMWX5MC's Avatar
1024
Drives: 2023 BMW X5MC
Ditto, but that's an interesting set up you did there...
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
      04-25-2024, 07:49 AM   #9
Diirek
Diirek's Avatar
106
To be honest, I’ve left it as is. I’ve had a number of compliments from friends thinking it was the stock stereo setup and how good the bass was. Hands down the setup sounds significantly better than from first install too. Once the speaker has broken in, it really does sound pretty good.
dombi10.50
      04-25-2024, 09:54 AM   #10
dombi
11
Diirek
I am in a similar boat. I ended up adding a Match 10DSP/Amp, exchanged the underseat Woofers. The sound is amazing, but the low end is still lacking.
I don't want to fill up the trunk with a gigantic Sub, so the Spare tire space is what I am looking at.
I know that installing the Sub in the Spare tire area is not ideal... but I hope that the sound would still be much better than without it.
Diirek106.00
      04-27-2024, 07:49 AM   #11
Diirek
Diirek's Avatar
106
Originally Posted by dombi View Post
Diirek
I went through the oem+ upgrades in my last bimmer and was never really satisfied with performance vs the cost. Happy with the decision I made here.
dombi10.50
      05-02-2024, 09:44 AM   #12
doctorwizz
Robot
doctorwizz's Avatar
30
Drives: 2023 BMW X5 40i Xdrive
Can you link the PnP harness your ordered? It fits a G05? Does it tap in the the speaker wire harness in the back somewhere?
Thanks
swainbmw533.00
      05-02-2024, 10:17 AM   #13
Diirek
Diirek's Avatar
106
Thanks
https://technicpnp.com/product/hk-op...oster-systems/
Yes this one is for the G05. If you go to their website, you put in the model of your car and select which radio option you have (this is for the Option 688 - Harmon Kardon).
It intercepts the factory amp in the left side/rear of the cargo area. Takes less than a minute to access and install.
dombi10.50
      05-02-2024, 10:20 AM   #14
doctorwizz
Robot
doctorwizz's Avatar
30
Awesome thank you!!
      05-02-2024, 03:10 PM   #15
doctorwizz
Robot
doctorwizz's Avatar
30
Did you get the one with the LOC? Or the other?
I have the S676 HiFi Speaker System. This show 3 options. 2 have the LOC. LOC 50i and LOC 100i.
I think I just need the harness with no LOC?
Thanks!
      05-02-2024, 06:36 PM   #16
Diirek
Diirek's Avatar
106
Thanks!
I ordered mine with the LOC150. This ties into the harness and has the remote wire that tells the amp to turn on/off and where you connect the RCA's that provide the sound source to the amp - Pretty sure there's a level adjustment on there as well. I'd reach out to technic and I'm sure they can point you in the right direction.
      05-02-2024, 07:10 PM   #17
doctorwizz
Robot
doctorwizz's Avatar
30
Yep. I sent them a message. Thx again!
Diirek106.00
      05-03-2024, 12:32 PM   #18
doctorwizz
Robot
doctorwizz's Avatar
30
Where did you get those parts to screw it down? Does the sub kit come with anything like those?
I have no spare. There is a screw hole under the cover. Not sure what to get.
Havn't heard back from Technipnp yet.
So you plug that harness into here somewhere. Do you have to remove anything in there to plug it in? Mine looks like this:
      05-03-2024, 12:50 PM   #19
Diirek
Diirek's Avatar
106
This looks different than mine, but pretty sure it will tie into this plug. The mounting posts for the spare tire area came with the subwoofer.
      05-03-2024, 02:05 PM   #20
doctorwizz
Robot
doctorwizz's Avatar
30
I just got the CerwinVega delivered. It came the 2 bolts. Hope one fits. Will try later.
      05-03-2024, 03:04 PM   #21
doctorwizz
Robot
doctorwizz's Avatar
30
Yes the 8mm fits! And I can close the cover with clearance.
I contacted Technic PNP again. This time by email. '
How long do they take to ship?
      05-03-2024, 03:37 PM   #22
doctorwizz
Robot
doctorwizz's Avatar
30
Ah FML I bought the passive version! That is a return then.
Tech replied instantly to my email.
Edit: I ordered the active sub. And the Harness for 676 with no LOC per support. BBL
