10-16-2023, 09:23 PM | #1 |
Rep 260
Gesture Control tips
What are some tips on making the most of gesture control? Can it actually save time and be convenient? Will be they adding more recognized gestures down the line?
10-16-2023, 10:15 PM | #3 |
Rep 2,488
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
You can assign the 5-0-5 gesture to almost anything by pressing and holding on something and then you can assign it to a gesture. For example, max AC can be turned on with this gesture
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
10-17-2023, 12:33 AM | #4 |
Rep 4,335
Drives: 2020 M850i Coupe
Yep and by default the gesture controls in iD8 are limited unless you assign them to shortcuts. On iD7 5-05 is directly capable of assigning to NAV home. Figured it out on iD8 via shortcuts to work the same in iD8 but now setting that for max AC. 👍
10-17-2023, 01:55 AM | #5 |
Rep 415
We turned it off on our 45e, as it was constantly going off. The only thing we used it for was volume control, and it wasn't worth the hassle.
Mark |
1230vani652.50 SwissBeemer301.00 |
10-17-2023, 09:05 AM | #7 |
Rep 8,700
Drives: eVeRyOnE mAD!
I mainly use the track fwd/backward gestures since my right hand is already in the camera’s view as it rests on the gear lever. I also assigned the open-close-open gesture for Home navigation. sometimes I’ll use the volume up/down gestures if I need a quick, rough volume adjustment. I turned off the index pointing gesture because pointing the finger towards the screen is too common, such as when touching the screen. I haven’t heard of new gestures in the works
WagonFan271.50 |
10-17-2023, 09:32 AM | #8 |
Rep 81
Drives: 2024 X5 50e M-Sport
I used the gesture controls for volume adjustment in my 2019 40i but with my new LCI 50e with iDrive 8.5 it does not recognize the gestures very well and I tend not to use it anymore.
10-17-2023, 10:03 AM | #9 |
Rep 82
I also have the 2024 50e and I’ve noticed the gesture control isn’t that responsive. It doesn’t catch my hand a lot of the time. What can be done about this?
10-17-2023, 11:01 AM | #10 |
Rep 1,155
+1 easier to use buttons (pre LCI)
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
10-17-2023, 09:46 PM | #14 |
Rep 260
I wonder if they could improve the functionality through OTA updates in the future. Seems like the system should be able to learn a lot.
10-17-2023, 10:49 PM | #15 |
Rep 85
I use it mainly for the "mute" and "unmute" function for the stereo.
The rest are quite hit and miss so I don't really bother.
Maut aur tatti, kabhi bhi aa sakte hai
10-19-2023, 02:12 AM | #16 |
Rep 1,145
Drives: 2022 x5 40!
