11-15-2023, 07:51 PM | #1 |
Rep 260
Rain rain go away!
Looking for paint care tips for your parked car covered in rain. Wipe it off, let it be? Would single water drops be damaging to the paint vs a streak from wiping rain off with a towel for example? Is a garage without airflow better than leaving outside? Take care of windows differently than body panels? Any and all best practices welcome!
11-16-2023, 08:35 AM | #3 |
Rep 8,033
Drives: 2024 X5 M60i
Get your car ceramic coated, then just use a leaf blower to blow the water off the car after you pull it into the garage if it bothers you that much. Then wash the car whenever the next opportunity arises.
I wouldn’t go wiping the rain water off the car unless the car had just been washed, otherwise you’ll just be pushing dirt/dust around on the paint along with the water.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
11-16-2023, 10:56 AM | #6 |
Rep 3,681
It is a car, design to be outside and take on elements just like any other cars you have before. BMW is NOT fragile. So however you take care of your car before, it will work the same way with this car.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-16-2023, 11:42 AM | #7 |
Rep 1,354
Drives: 2022 X5 m50i
If you have an indoor garage, then you can use a silicon squeegee when you pull your car in.
I use the Hydroglide 14" Waterblade Silicone Y-Bar Squeegee (https://www.amazon.com/One-Pass-Hydr...ps%2C73&sr=8-5). It does not scratch the surfaces and help me get rid of the water quickly. I use it after I wash the car as well to quickly dry it. But the most important part is to have some sort of protective and hydrophobic coating. You can coat it with a ceramic coating or I use Turtle Wax Ceramic Spray Coating after every wash that gives a great shine and since it is hydrophobic, it also helps with the water beading.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
Duke2429.00 |
11-16-2023, 04:17 PM | #8 | |
Rep 275
'24 X5 M60i Tanzanite Blue II/Coffee
'21 X5 M50i Tanzanite Blue II/Coffee (RIP) '21 M240ix Long Beach Blue Metallic/Red '14 X5 s35i Lux Line Mineral White/Mocha (re-homed) |
LDT1539.50 chicagofan0019147.50 |
