11-12-2023, 09:33 PM | #23 | |
Rep 3,681
I am not say bmw cannot be nasty. But really proof ist there. The output range ecu parameters can as well be software bug
2022 G05 B58/PHEV
+ a few very old BMWs |
weinerbarn734.00 |
11-13-2023, 07:22 AM | #24 |
1228
Rep 1,350
The subject of tuning ususally evokes lectures where the finger of wisdom is wagged directly at those of us who dare to even discuss the possibility using these devices. God forbid and "you better not do that or you will lose your almighty warranty because I said so!".
How about you do you, I'll do me as I have yet to have a single problem doing it my way over several decades. |
nog0odd3ed@gmail.com42.50 RedATX1.50 |
11-18-2023, 07:30 PM | #25 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
guys there is a torque model in modern ecms, they are all torque based, used to be airflow based. this means the driver demands a torque value with the pedal and the ecm picks the air, spark, and fuel it takes to acheive that torque request.
if the factory calibration max demanded torque is, let's say, 500 ft lbs, at WOT and the torque model calls for 18psi of boost (more typically mg of air or cylinder charge), 15 degrees of spark lead, and an AFR of 12.0 to get there and someone is running a piggyback that pushes boost (or some other criteria for combustion) higher than the factory calibration calls for BMW will absolutely deny the warranty claim as the vehicle was operating outside of it's intent. yes, if there is no problem and the engine hasn't blown already, you can remove the piggyback and get your oil changed. if the engine is blown and won't run, it doesn't matter if you're running a flash or a p/back, you're toast. so what I am saying is, if the engine hasn't blown already and you have a flash, BMW can notate your flash but there is no claim to deny anyways. if you are running a PB and the engine hasn't blown already you have to go through the trouble of removing it when you take the car in so you feel better about your pretend powertrain warranty which doesn't even do anything until you break it and when you do it won't matter anyways because it will be too late. it doesn't matter what BMW rates the car at vs what it dynos at, that has zero to do with how a torque based ECM functions and records data. |
njfoses290.50 |
11-18-2023, 09:53 PM | #26 |
Rep 3,681
The way I read it, correct me if I misunderstood, bmw log parameter such as boost, spark timing, AFR …. And compare to max torque generation parameters, then determine which one exceed?
But then boost is really the key, right? Stock b58 run max boost 8-10psi?? If ecu log see 15 or 18, sure some turning has happened. Spark timing and AFR are not a good indication of engine exceeding torque spec. Yes if engine blown, and log says max boost is 18, bmw will definitely deny engine/turbo warranty, maybe transmission too.
2022 G05 B58/PHEV
11-19-2023, 07:56 AM | #27 | |
In the Details
1810
Rep 867
Drives: Yes
Anyways, yes on these cars, more boost is the most obvious and easiest way to increase power but spark lead and AFR dialed in is also important for increasing torque and if the signs of a lean mixture and/or preignition are evident you will be in the same boat. Let's face it, modern cars and calibrations are built well and calibrated well. If you maintain them they are not going to lean out, preignite the mixture or overboost the mechanical limitations of the powertrain without a non factory calibration or at least many miles of abuse and lack of maintenance. <--- All my cars are tuned (no piggybacks, lol) and modded except for the X5M50 my wife dailys, I don't think she has ever had it over 3000 RPMs. I am not expecting free parts or labor if anything pops. That's on me. |
11-20-2023, 02:58 AM | #28 |
Rep 125
Absolutely.
Noticed a diff whine at about 5000kms but didn’t repot it to dealer - my stupidity. Femto unlock BM3, turbo blah blah. Diff now sounds like an old taxi and BMW won’t honour warranty (replacement diff) because it is flagged as modified. Now have lawyers looking into it. Considerable more cost than new diff. It’s the principle. Before all the keyboard warriors pipe in read your warranty papers. I’m sure different in many countries. I’m in Australia |
nog0odd3ed@gmail.com42.50 |
11-29-2023, 08:46 PM | #29 |
Rep 1,143
Drives: 2022 x5 40!
I’ve done the same and never had an issue. I’m one that never returns to the dealership for any service work. It’s either done by myself or by a local shop. I don’t even get the free oil changes I prefer to do myself.
11-30-2023, 04:44 AM | #30 |
Rep 113
Since I also own a few tuned vehicles, I had the dealer explain how it works and what the warranty is about.
Determining whether the vehicle is tuned actually has 2 stages. If it has been flashed, you will see it immediately when the diagnostic device is connected (number of flashes, checksum, etc.) -> the car will be flagged. With a PiggyBox you don't see it directly, so this is where "suspicion" first arises. According to the service manager, over 20 parameters are logged and if these deviate significantly from expectations, then it becomes suspicious (regardless of whether it is a box or flash). He mentioned the simplest ones, such as: exhaust gas temperature, or deviation between air mass and turbo pressure (this is especially true for piggy, where the boost pressure is faked but the MAF sensor shows the real values). The guarantee is more interesting. They can reject any warranty for the affected parts (engine, transmission, differential, etc.) because of the tuning. From this point on, you have to prove that the damage has nothing to do with the tuning, but that will be difficult. He said it could only work if it affects parts that have been replaced under warranty on several cars, but no one will give out this information voluntarily. By the way, he recommended to block the OBD connection (e.g. Theft protection) so that you can't connect the diagnostic device. It worked fine and they were able to update the service history via OTA and my car is not flagged (yet). |
Alan l.5453.00 |
11-30-2023, 10:57 AM | #31 | |
Rep 8,815
If you tune the car you have to be prepared to pay when you break it instead of trying to commit fraud.
11-30-2023, 12:19 PM | #32 |
1228
Rep 1,350
I know someone who has run a JB4 with very aggressive maps on a late model BMW and had a tranmission replaced under warranty with no questions or problems what so ever.
11-30-2023, 12:59 PM | #33 |
In the Details
1810
Rep 867
Drives: Yes
I know someone who ran a JB4 with aggressive maps on a late model BMW and had a transmission claim denied.
11-30-2023, 04:28 PM | #34 | |
Joint Chiefs of Staff
24199
Rep 190,807
11-30-2023, 05:29 PM | #35 |
1228
Rep 1,350
11-30-2023, 07:16 PM | #36 |
Rep 3,681
I kind of agree, if BMW can prove you run tune, and you have an engine/turbo or related components issues, they are entitled to deny warranty on these components. It is almost impossible to prove the tune isn't related to the problem. I guess the minutes you mod certain components, do expect warranty is gone for that components. If BMW still honor warranty, call it luck.
2022 G05 B58/PHEV
11-30-2023, 08:14 PM | #37 | |
In the Details
1810
Rep 867
Drives: Yes
I've done some dirty dirty things to about 300 various engines and none of them failed. But tunes vs failure isn't the thread. It's failure with a tune vs warranty. |
11-30-2023, 09:05 PM | #38 | |
24199
Rep 190,807
if you tune the car and break the engine, expect to pay for it. If you tune the car and your dashboard stops working, BMW will fix it under warranty. The odds of damaging the engine with a proven tune and the recommended maps are nearly zero. You probably have a higher odds of dying of a car accident on your way to the dealership. To me, the entire conversation about it is useless since its an endless back and forth on a scenario that will not happen.
12-01-2023, 07:10 AM | #39 | |
1228
Rep 1,350
The subject of tuning invariably brings out the gang who has no intention of ever utilizing an after market power enhancer of any kind but paint a dire picture of blown engines, warranty denials etc. Most of these guys have never changed a tire and posses little to no understanding of how current a ECM/PCM controls the engine and transmission. "OMG, you are going to lose your warranty", how many times does that need to be said and most often by guys who never get their hands dirty and don't have a clue. |
12-01-2023, 09:04 PM | #40 |
Rep 8,815
Pretty interesting read. There are way more guys that tune the M5 platform so they know a thing or two about blown tuned motors.
https://f90.bimmerpost.com/forums/sh...t=blown+engine
12-06-2023, 10:08 PM | #41 | |
Rep 1,143
Drives: 2022 x5 40!
eelnoraa2032.50 |
12-06-2023, 10:56 PM | #42 |
Rep 3,681
Me too. Everyone of mine has a bit of something. Never other to take off when visiting dealer either. I wonder they even know or check unless related components have issue. I also fully prepared to eat consequences.
2022 G05 B58/PHEV
12-06-2023, 10:57 PM | #43 | |
Rep 1,143
Drives: 2022 x5 40!
