01-04-2021, 06:24 AM | #1 |
Techie
16
Rep 105
Brakes squeaking
Hearing some squeaking as I brake the car. Have about 10k miles in 10 months on it. I don't break hard when I drive. I'd be surprised if brakes are worn so soon. Just did my 1 year oil change service. Noise only appeared after the service which may be a coincidence. Thoughts on what the squeaking means?
01-04-2021, 07:40 AM | #2 |
Rep 85
Well, I had a similar problem, with my brakes squeaking at about 9000 kms, and when the car went in for it to be looked at, I was told that they had to clean the brakes as there was too much brake dust on it.
It seems to have resolved the problem. |
Kripster15.50 |
01-04-2021, 10:16 AM | #3 |
Rep 8,689
Drives: eVeRyOnE mAD!
truth be told, I was a long standing Audi customer (11 years) and switched to BMW to avoid the squeaky brakes (3 Q7s and they all squeaked). say it ain't so!!!
01-04-2021, 10:34 AM | #4 | |
Rep 2,070
A good run with some hard braking can help, not like 'breaking in' type breaking, just a fairly aggressive drive usually resolves it. |
Kripster15.50 |
01-04-2021, 02:18 PM | #5 |
Rep 185
Couple of factors at play with respect to squeaking brakes in general:
1. Brake Pad/Rotor selection. Certain compounds or pad/rotor combinations. Carbon Fiber brakes are notorious for squeaking until properly warmed up. 2. Rust/Dust build up. Rusty or dirty rotors can squeak until the surface is cleaned off by a couple of stops from highway speeds. 3. Improper bedding of pads and rotors. Certain pad/rotor combinations require break-in and bedding of the compounds to each other. No hard braking for the first couple of hundred miles followed by a quick series of hard but smooth/even deceleration from 70mph ->5mph (5-6 times to get the brakes red hot). This ensures proper pad to rotor contact. In general this typically applies to sport brakes which have a more aggressive pad and larger rotors to burnish. 4. Grit/pebble stuck between pad and rotor. Not good and will damage the rotor. |
Kripster15.50 |
01-04-2021, 02:20 PM | #6 |
1176
Rep 1,502
Do you have the M sport brakes? Those are made by brembo and have been notorious for squealing.
Its normal for them. Its because of the massive amounts of brake dust they make. Replace the pads to powerstop or R1 concepts and it should be fine. |
Kripster15.50 |
01-04-2021, 07:22 PM | #7 |
Techie
16
Rep 105
Yes I have M Sport brakes. Not sure what this means: "Replace the pads to powerstop or R1 concepts"
01-04-2021, 08:12 PM | #8 | |
1176
Rep 1,502
They will stop about 95% as well as the brembos but your wheels wont be caked in dust nor will they squeal. |
01-21-2021, 03:25 PM | #9 |
Techie
16
Rep 105
The dealer told me the same: brake dust cleaned.
01-21-2021, 03:33 PM | #10 |
Rep 6,799
OFten, if you are in an area without traffic, at least one and maybe a couple hard stops will clean things off enough to quiet the brakes. This is more important with a PHEV or EV as with regen, you may not actually be using the brakes as much or as hard. Rust is a possibility, and if it's not pitted too deep, the same thing will fix it, otherwise, it may require new rotors.
01-30-2021, 04:24 PM | #11 | |
Techie
16
Rep 105
01-30-2021, 05:05 PM | #12 | |
Rep 174
Kripster15.50 |
