01-20-2021, 11:50 AM | #1 |
Rep 170
Stains on Merino leather
No it’s not the wrinkle gate this time...
While checking the leather with the car internal lighting at night, I noticed stains on the Merino leather. This comes from a pre-delivery issue / misconception and a bad quality check. As I could see on pictures I took before delivery, stains were already there. But with the flash of the camera it’s like a punch in your face. I could get part of it replaced under warranty today but just discovered some more on the seat back before leaving the dealership... You can barely see these in day light. grrr Did any of you face the same issue? |
01-20-2021, 12:24 PM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
Before you take apart your car you should dry interior detailing spray. NextZett cockpit cleaner or BMW interior wipes.
01-20-2021, 12:42 PM | #3 |
Rep 4,515
Drives: 2022 iX xDrive50, DGM
iconoclast7265.50 |
01-20-2021, 01:15 PM | #4 |
Rep 170
The car is new - just took delivery a month ago and didn't pay for that. When you have those type of stains, it should be covered. If I try to clean it myself, I risk to void the warranty, no?
01-20-2021, 02:05 PM | #5 |
7266
Rep 6,561
No. Cleaning your vehicle with proper interior cleaner does not void your warranty. Especially if it is a BMW product sold at the dealership or through BMW Lifestyle.
01-20-2021, 02:29 PM | #6 |
3235
Rep 1,661
The discoloration reminds me of the residue that alcohol (from hand sanitizers) may leave behind.
Another option is to (politely) insist your dealership clean the leather with whichever product(s) they choose and will stand behind. But like others have suggested, simplest solution is to clean it yourself (Leatherique is another reputable leather cleaner/conditioner not already mentioned.) |
iconoclast7265.50 Paladin15566.50 |
01-20-2021, 05:17 PM | #7 |
PANIC!
484
Rep 823
There's another long thread about this with other owners experiencing the same thing. I almost wonder if those stains were formed during the leather production or staining process either by poor quality control or just some natural leather anomaly, with some stains being more visible than others and/or become more apparent after some slight use and/or wear.
01-20-2021, 05:34 PM | #8 |
1037
Rep 1,527
You ought to complain about the stitching pulling apart in the corners as well.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
01-20-2021, 11:07 PM | #9 | |
Rep 459
I think there was another thread on this as well...Given the breadth of the issue and how it looks, often times appearing at some point after taking delivery, it looks to me like it's a "processing" issue/defect with the leather and BMW got a bunch of seats that had the defect.
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 11/2022.63
01-21-2021, 12:47 AM | #10 | |
Rep 170
06-15-2021, 12:42 AM | #11 | ||
Rep 4,246
Just a follow-up for any other members who has leather exhibiting similar issues. I was going through BMW AIR and pulled a couple service bulletins: SECOND ROW SEAT LEATHER CLOUDY/DISCOLORED B52 02 21 [SI] April 2021 Complaint Situation Milky-white stains (discolorations) in the leather are observed in the second-row seat bottom, backrests and/or headrests. Refer to attachment for details. Cause Cause An unfavorable leather tanning process can result with isolated cases of grease residue accumulating in the second-row seat leather surfaces. The stains or discolorations are not harmful to health. Measure Model F95 X5 M Sports Activity Vehicle F96 X6 M Sports Activity Coupe G05 X5 Sports Activity Vehicle G06 X6 Sports Activity Coupe G07 X7 Sports Activity Vehicle Correction Only for the specific issue identified in the attachment, remove the tanning process-related residue in the second-row seat leather as outlined in the PROCEDURE section below. This cleaning process can be repeated a second time during the same workshop visit if necessary. If the vehicle returns because the stain formations reoccurred in the same locations that were previously cleaned, the affected leather seat covers can be exchanged on a case-by-case basis. Procedure A. Proceed as follows. 1) Using a hot air blower held at 4" to 8" from the affected area, heat the leather surface with circular movements at a temperature above 160 °F/ 70 °C until the greasy residues disintegrate completely. Ensure that the temperature of the affected area does not get warmer than 195 °F/ 90 °C as otherwise the leather can be damaged. 2) Wipe the treated surface with a clean, absorbent cleaning cloth. 3) Use a microfiber cloth ( yellow 6 pack, part number 51 91 2 466 423 or blue 6 pack P/N 51 91 2 466 842) soaked either with leather cleaning foam (P/N 83 12 2 298 210) or with the leather and upholstery cleaner (P/N 83 12 5 A16 459), clean the surface with circular movements. 4) Wipe the treated surface with a clean, absorbent cleaning cloth until it is dry. 5) Apply a leather lotion (included in kit P/N 83 19 2 339 687 ) using a leather care cloth included in the kit until the surface has a uniform appearance. The above-mentioned treatment steps 1 to 5 must be carried out directly one after another without interruption. B. If the stain formation occurs again during the same workshop visit, repeat the cleaning procedure. C. If the stain formation occurs in the same location again, then the affected leather can be exchanged on a case by case basis. If you are replacing the leather upholstery for returning stains, please submit an INFO ONLY TSARA case with pictures of the stained pieces.
05-23-2022, 08:06 PM | #12 |
Rep 2
Drives: 2021 X7 M Sport 40i
Hi everyone
For those who've had this issue, did the stains come back after treatment by the dealership. I have a 2021 X7, all the stains came back, second time grey and greasy, rather than white, but very much back. Thanks! |
05-24-2022, 04:53 AM | #13 |
7266
Rep 6,561
I have little to no faith in the dealership executing that process correctly and suspect that most Technicians do not follow those steps correctly or do not do it at all. The dealership most likely has the prep center simply wipe down the seats with OEM Leather cleaner but bill for the entire warranty job.
