04-30-2023, 08:02 AM | #1 |
Generalissimo
641
Rep 1,392
US 50e Usable Battery Capacity
Can any of the US 50e owners run the vehicle telematics report as per the steps below? I am afraid that BMW is screwing us in the US again by putting a lower limit on usable capacity just like on 45e to make sure the battery can withstand the 8 year warranty period.
1. Log into https://mygarage.bmwusa.com 2. Go to vehicle profile. 3. At the top menu choose CarData and “Request BMW CarData Report”. 4. It will take around 24 hours to get generated. Just check in the same place for your CarData report. 5. Usable battery capacity is under “Energy content of the high-voltage battery” in the main HTML file of the report. Thank you. |
05-01-2023, 10:17 AM | #2 | |
Rep 87
https://g05.bimmerpost.com/forums/sh....php?t=1979361 |
Heavyd865.00 |
05-01-2023, 10:24 AM | #3 | |
Generalissimo
641
Rep 1,392
05-01-2023, 11:47 AM | #4 |
152
Rep 302
USA 50e usable capacity per advertising is supposed to be 25.7 kwhr yet BMW also says full charge should take 3.25 hours. Well 7.4 kw x 3.25 hrs is 24 kwhr. Doesn’t add up….
05-01-2023, 12:08 PM | #6 |
Generalissimo
641
Rep 1,392
05-01-2023, 12:22 PM | #8 |
Rep 440
Ugh this is lower than expected and I am a bit pissed to say the least at BMW. I am buying an 80k plus SUV and expect to get the full capacity battery and I wish I didn't hear about this lower capacity... What is wrong with BMW.
05-01-2023, 12:30 PM | #9 |
Rep 8,690
Drives: eVeRyOnE mAD!
the full capacity is 29.5kWh. BMW never claimed all of it was usable, just 25.7kWh. it’s only one report of 20kWh usable in the U.S. 50e, though it could be different (higher) for EU 50e but it’ll be a while until they receive theirs. as more chime in, we’ll get more definitive numbers.
rexus300153.50 |
05-01-2023, 12:50 PM | #10 | |
Generalissimo
641
Rep 1,392
05-01-2023, 02:24 PM | #11 | |
Rep 517
05-01-2023, 02:37 PM | #12 |
Rep 3,681
have anyone charge their 50e from "---" to full? If so, you should be able to see how much kWh is used. Take that number x 0.87 = about the the usable capacity. 0.87 is because for my 45e, my average charge lost with L2 is 16% over 10 month of ownership. Meaning for every 1kWh used, 0.87 make it into the battery. Assuming L2 charging efficient remain similar, maybe this is another way for a sanity check.
Correction, I relooked at my average kWh used to charge battery from --- to full, efficiently is 87%.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 05-01-2023 at 03:55 PM.. |
ScaldedDog338.00 |
05-01-2023, 02:47 PM | #13 | |
Generalissimo
641
Rep 1,392
05-01-2023, 02:48 PM | #14 |
152
Rep 302
My 2022 45e with 14800 miles on electric out of 23000 total has 15.92 kwhr capacity which at 75F will go 32 miles. So the 50e 40 mile BMW stated range with a 20 kwhr battery seems about right. Sure wish it really had the 25.7 kwhr available.
Also, with a 0.84 input to charge ratio, 3.25 hours 7.4 kw charging equates to 20 kwhr. Also note that 45e’s 16 out of 24 kwhr is the same ratio as 50e’s 20 out of 29.5 |
05-01-2023, 02:54 PM | #15 | |
Rep 8,690
05-01-2023, 02:57 PM | #16 |
497
Rep 328
Here’s that screenshot
05-01-2023, 03:03 PM | #17 |
497
Rep 328
FWIW the Juicebox app says it supplied 23.05 kWh during that session. Juicebox app is terribly unreliable but thought I’d share for additional reference.
05-01-2023, 03:24 PM | #18 |
21
Rep 49
Yes, these lower capacities are very dissapointing. I expect it to be reduced but to 20 kWh seems a bit extreme. So I assume we are safe to charge the 50e to "100%" on a daily basis as BMW has already limited the available battery capacity??
05-01-2023, 03:25 PM | #19 |
Rep 542
05-01-2023, 03:28 PM | #20 |
Rep 8,690
yes. that being said, the 50e doesn’t even have a setting to limit the charge level; it’ll always charge to 100% of its usable capacity
05-01-2023, 03:31 PM | #21 | |
Rep 8,690
20kWh of 29.5kWh is ~68% |
05-01-2023, 03:52 PM | #22 |
Rep 3,681
Putting 20kWh into battery require 23kWh from wall sounds about right. It is 14% lost.
If I grab all the 0% to 100% charging for my 45e from juicebox, the average 19.6kW. 13% lost.
2022 G05 B58/PHEV
+ a few very old BMWs |
