05-30-2023, 06:31 AM | #1 |
Rep 509
Paint Worn Off Is This A Warranty Claim? ** UPDATE **
Hi all,
When I was giving my 2022 X5 40i a wash earlier on today I noticed that some of the matt black paint around where the exhaust tip is has worn off and the silver underneath is showing through ( see attached photo ) My X5 isn't even 1 year old yet and it's only done 2,426 miles. I am in the UK. Is this a warranty claim? Last edited by malvern_man; 07-06-2023 at 04:38 PM.. |
05-30-2023, 06:42 AM | #2 |
13247
Rep 19,752
A number of folks have had them replaced under warranty, it is wort a try. In just ignored mine given it would likely happen again.
05-30-2023, 07:02 AM | #3 |
Rep 3,552
the new ones are no longer black coated on the inside, i think they just gave up.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
MJBradley1967192.00 |
05-30-2023, 07:57 AM | #4 |
Rep 96
I had mine replaced under warranty, and now the replacement looks like below, after 1 year. My dealer will be replacing again under warranty, this time with the updated part, which is no longer flat black on the inside. They replace them in pairs so both sides match. Both times, my dealer didn't flinch, and just ordered the parts under warranty. The LCI X5 M-sport with extended shadowline have these revised outlets, and the inside portions are now unpainted.
CGG171.50 |
06-03-2023, 05:14 PM | #5 |
Rep 509
** UPDATE **
I went to the dealership today and yes the flaking paint is covered under warranty pending a visual inspection ( the service guy just looked at the photos on my tablet ) and a, as he put it, a 'box ticking exercise' He said they'll replace both sides with the latest part numbers. |
gdurhamski32.50 |
06-03-2023, 05:25 PM | #6 | |
Rep 208
gdurhamski32.50 |
06-03-2023, 06:49 PM | #7 |
Rep 474
Drives: 2022 BMW X5 xDrive 40i
There are some high-temp black paints out there (a few for grills). I wonder if one of those would do the trick.
You'd just have to prepare the surface properly.
2022 X5 xDrive40i
Black/Black/Black |
2heeldrive55.50 |
06-03-2023, 07:39 PM | #8 |
Rep 4,331
FYI. .. Most high temp paints I've seen require heating the thing you've painted with it to around 400 - 500 degrees before they become high temp tolerant themselves. Disappointing when I found out, which of course was after I bought them and was about to paint and started reading the fine print My wife put the no-no on using our BBQ grill to do it and a friend of mine who has an oven in his garage did the same
06-03-2023, 07:58 PM | #9 | |
Rep 474
2022 X5 xDrive40i
Black/Black/Black |
06-03-2023, 08:05 PM | #10 |
Rep 4,331
Well, 500F isn't much for metal but it would certainly be an experiment. I don't recall how long the paint needs to be baked, half hour maybe, it says it on the can though. I don't think the exhaust bezels actually see much heat so probably ordinary paint would be ok. The most important part is as you said in your post, that is.. . part preparation. Proper preparation when it comes to painting is everything! The parts need cleaned, then possibly sanded with fine grit, then cleaned again and then degreased. Certain easy enough to do but many people skip the proper cleaning and then end up with flaking paint and complain
06-04-2023, 06:19 PM | #11 |
Rep 204
I'd appreciate if someone can post a picture of the new updated replacement part. I never asked the dealer since I also thought it would just repeat so didn't see the point.
06-04-2023, 07:44 PM | #12 | |
Rep 101
Pretty much looks like this |
06-05-2023, 01:15 PM | #14 |
Rep 624
06-05-2023, 08:01 PM | #15 |
Rep 298
To be sure I understand, are you saying just the tip?
06-05-2023, 10:03 PM | #16 |
Rep 16
Hey, so I have the Maxton design rear diffuser for the F95. I have a trailer hitch so I gave up looking for a diffuser made for this option, since there’s really not a whole lot out there. On a hunch I looked at the set up of this one and figured I could make it work, so I custom installed it.
mmm50i403.50 |
06-06-2023, 01:40 AM | #17 |
Rep 1,075
I have these new tips on my ‘23 45e. Since my car is carbon black with the shadow line trim and I also have black wheels, the silver inner trim bugged me as it was an eyesore on a blacked out vehicle. So I ended up painting them instead. Looks soooo much better IMO.
P111572.00 |
06-06-2023, 06:43 AM | #18 | |
Rep 16
06-06-2023, 06:56 AM | #19 |
85
Rep 317
Drives: MY19 X5 40i
+1 as well. Sigh……..I painted mine with plasidip on the outer rim(chrome part) and was trying to replace the inner part where the paint fell off, the dealer wouldn’t do it, they say because I paint the outer rim therefore is no longer cover under the warranty. FML……..
Brandan
What?s next ? BMW X5 40i Audi Q3 Toyota Corolla S Nissan Murano |
06-06-2023, 01:13 PM | #20 |
Rep 1,075
I used VHT “very high temp” spray that I got from a buddy of mine who used it on his X5 inner exhaust trim and also on the headers / exhaust for his motorcycle. I did a few passes on my trim and went through what was left in the can. He was adamant about following the prep and curing process and said he hasn’t seen any peeling / flaking, or rust on his motorcycle exhaust or the inner trim of his X5 to date (pics below are of his X5, it's been over a year since he did it). Only time will tell if I did a good enough job on mine too
You can buy the stuff at autozone or similar auto shops. https://www.vhtpaint.com/high-heat/v...eproof-coating https://www.autozone.com/paint-and-b...E&gclsrc=aw.ds Last edited by rundeyvoo; 06-06-2023 at 02:00 PM.. |
Emersonrod10.50 SKBSY885.00 |
06-06-2023, 01:57 PM | #22 |
Rep 1,075
