06-02-2023, 08:41 PM | #1 |
Rep 766
Steering wheel groan when positioning
When I turn the car (45e) on and the wheel is lowering into position it makes a grunting/groaning sound. Seems like it only happens when the interior is hot (i.e., not when the car is preconditioned). Has anyone else had this issue?
06-02-2023, 09:25 PM | #2 |
20
Rep 37
Mine has since day 1. I had bmw look at it one day. They said they didnt notice anything.
Its my wife’s primary car, so im not in it every day but pulled it into garage yesterday and it made the noise. Im Definitely having them Look at it next time. Even if you cant hear it you can fee it! The whole steering wheel shakes |
cellarrat517.00 |
06-03-2023, 09:06 AM | #3 |
Rep 537
This started happening after about a year of ownership. Only at startup as the wheel extended and lowered into position. No sounds any other time. The weather and temperature didn't seem to matter.
I couldn't find any helpful posts about it. Just as I was about the schedule a service visit, it stopped. This was about three weeks ago. It was about the time my iDrive updated. I don't know if they were related but it hasn't occurred since. |
cellarrat517.00 |
06-03-2023, 12:29 PM | #5 |
Rep 8,688
Drives: eVeRyOnE mAD!
there is an SIB for this. it happened on my wife’s MY20 G30 also only when it was really hot. I believe there were some that got the steering wheel column fixed or replaced on their G05 under warranty. try doing a forum search
cellarrat517.00 |
06-03-2023, 01:07 PM | #6 |
Rep 75
I had the similar issue, but the noise appeared when steering wheel is extending, not lowering. Replicated about every fifth start or stop of the engine. Seems to be a common issue for g05. The dealership confirmed the problem and replaced steering wheel column. No noise since then.
06-03-2023, 01:23 PM | #7 | |
Rep 766
Thanks to all for the feedback. |
06-03-2023, 02:09 PM | #8 |
Rep 4,330
Not just yours Try using the advanced search as I think it can be a bit more accurate otherwise the results bring up stuff with seemingly no relation to your search and you spend a lot of time sifting through it all till your frustration level triggers the...oh crap, forget it, emotion
cellarrat517.00 |
06-03-2023, 02:20 PM | #9 |
Rep 8,808
This has been an ongoing with BMW. My 2020 started doing it after a year. I brought it in and the dealer replaced the whole steering column.
Alan |
06-03-2023, 03:46 PM | #11 |
Rep 8,688
06-04-2023, 10:00 AM | #13 |
Rep 766
Guy Fleegman400.50 |
06-05-2023, 09:29 AM | #14 |
Rep 583
Drives: F10 535i, M2 LCI, G05 X5 40i
Mine only does it when extending and the car has been sitting out in the sun. Even then, it doesn't happen all the time. And of course every time I've told the dealer, they say they can't replicate it. So now they've asked me to take a video.
06-05-2023, 09:39 AM | #15 |
Rep 537
06-05-2023, 09:52 AM | #16 |
56
Rep 47
Well, at least your wheel is still moving. My steering wheel will go up, but not down. Well, it will eventually, but I have to keep hitting the switch. It will only move down a fraction of an inch each each time.
Very frustrating. I would be happy if it just stayed in one position. |
06-05-2023, 01:37 PM | #17 | |
Rep 766
06-08-2023, 02:48 PM | #18 |
Rep 12
Take a video of it happening and take it to your SA. My MY20 x5 started making shrieking noise when the column was moving in and out and the dealer attempted the SIB but the noise returned so they ended up replacing the steering column under warranty at 30k miles.
cellarrat517.00 |
06-08-2023, 03:30 PM | #19 |
1067
Rep 1,942
Mine started making the sound- I found a small spray from called Ozium- freshens air. Sprayed in area it was groaning and quieted it. Rather than silicone or a real spray. Problem is definitely some material rubbing.
cellarrat517.00 |
06-08-2023, 05:25 PM | #20 |
Rep 233
Hi
I Had 7 X5s all had same issue, starts with intermittent issue and progresses, initially dealers just lubracate, but after 3 visits they actually do some thing. I on my third visit it’s been resolved for about 3 weeks and it’s back! I be booking it in again for the column replacement! Good luck! |
cellarrat517.00 |
06-08-2023, 06:53 PM | #21 |
Rep 64
This exact issue under the exact same conditions just started happening to me four years into ownership on my 2019 40i — ugh. Guess I’ll take it in soon because my warranty is up in two weeks.
