04-05-2019, 06:36 PM | #1 |
173
Rep 391
Phone numbers through iDrive?
So, in my previous X5s, I was able to search for a business and would be given the address as well as the phone number, which I could call. Used this all the time for things like restaurant reservations. When I search for a business now, I seem to only get the address. Am I missing some way to get the phone number too?
04-06-2019, 06:01 AM | #2 | |
Rep 294
'13 Raptor (sold); '14 Raptor (sold); '15 A6 Quattro (sold); '19 X5 xDrive 40i (sold); '20 4Runner TRD Pro (sold), '22 MDX A-Spec (sold); '22 MDX A-Spec (sold); '24 X5 M60i
wrickem2101.00 |
04-06-2019, 05:21 PM | #3 | |
173
Rep 391
"Hey BMW, what is the phone number of Sister's Thai?" iDrive displays a list of its results, including the correct result I see #2 is correct, so I say "#2" to iDrive's query to select a number from the list. iDrive says "Okay, calling Starbucks" Starbucks wasn't even one of the results. Even more annoying, oddly, is that it didn't even attempt to call Starbucks. It just did nothing. I tried manually clicking on the results but then the entry was entered into the nav. Anyway, I'll give it another try. Thanks for letting me know it's supposed to work. |
04-07-2019, 03:43 PM | #4 | ||
Rep 294
04-09-2019, 06:52 AM | #5 |
173
Rep 391
Thanks!
I tried a few things yesterday like "Hey BMW... what is the phone number of can I have the phone number for please call Nothing worked. I then called BMW Genius. The first genius I spoke with said whether a number is there depends on whether the company provides it. Terribly dumb answer. I next tried looking up a restaurant in the POI under the Nav menu. If you drill down to the correct category, you can get to a place where you can filter results, including by name. This helps. If you select the restaurant from there, the phone number is displayed and you can call the restaurant. Apparently the numbers are provided (see first genius above). Problem solved but it takes 12 steps instead of just using Hey BMW. Annoying. So, I called BMW Genius back to let them know. Second Genius I spoke with said this is a known problem and people have been complaining about it. Anyway, thought I'd share the results of a little digging. If anyone has a better solution, please post. |
