05-03-2020, 04:06 PM | #177 |
Rep 1
Step by step
Can someone please give me a step by step on how to use the Esys Launcher and where to get the codes for 2020 X5 with park assist pro.
I am sorry I am a novice with all this and dont get it but want to do it all. |
05-05-2020, 10:36 AM | #178 | |
Rep 99
My car hasn't moved for a month so not sure what level the battery is at before I make any mods. I guess I can do with the engine running.... Going to see if this available in my car; Keep us posted. |
05-05-2020, 12:05 PM | #179 | |
1198
Rep 1,587
yans29.00 |
05-05-2020, 12:42 PM | #180 |
Rep 99
I have the latest E-sys 3.27x and v.4.22.41_PSdZData_Lite.
But I also have E-Sys_Setup-3.33.4-39276e2 and v.4.22.31_PSdZData_Full I am using a est_token.est token and ESysLauncherPROSetup_2.8.1_Build_155 This sound OK? I dont have E-SysX. Please do let me know thoughts Thanks. |
05-05-2020, 04:03 PM | #181 | |
1198
Rep 1,587
You need either latest launcher or esysx. I recommend buying official esysx |
05-06-2020, 08:37 AM | #182 | |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Is there a way to attach the default drive mode at startup to a driver profile? I just setup the second key to my wife's profile. It works as intended and it is nice to have the car "set up" for the individual driver based on the profile/key assigned to that driver (seats, radio presets, etc). However, it would be even nicer to have the default drive mode assigned to a driver profile as well. Thoughts?
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
05-09-2020, 11:51 AM | #183 |
267
Rep 345
Drives: 2019 X5 40i M
Help with Logo at top of Cluster
Does anyone have the coding for displaying a logo at the top of the cluster like the M///. I have the welcome and goodbye coded but cannot find the logo.
Thanks
2019 X5 X40iM
05-09-2020, 11:17 PM | #185 | |
Rep 272
https://g05.bimmerpost.com/forums/sh....php?t=1637597 I was able to code Comfort Plus mode by referring to this sheet. |
05-10-2020, 03:43 PM | #188 |
267
Rep 345
Change Ambient Lighting -Dome BDC_BODY 3070 GROUP_0_FARBE_ENSEMBLE_1 orange orange, white
- Dashboard BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_1 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.) - Door's BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_2 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.) - Floor's BDC_BODY4 3070 AMBIENTE_FARBE_ENSEMBLE_1_LAYER_3 orange hellrot (there are 12 colors to choose from/ blue, green, violet ect.)
2019 X5 X40iM
OzJedi107.00 |
05-10-2020, 04:41 PM | #189 |
1198
Rep 1,587
It's really not easy to do.
I couldn't be bothered, but there is a method documented here. I haven't tried it. You will need to be a member to get the file: https://cartechnology.co.uk/showthre...2216#pid552216 |
OzJedi107.00 |
05-10-2020, 04:47 PM | #190 |
1198
Rep 1,587
Here is the xml for a cheat. You can use the coding to apply directly in esys, or add to an existing cheat.
If anyone wants to test and confirm if it works, I'll ask jk to update the G05 cheat. Looks to be some nice new colours in there... <?xml version="1.0" encoding="utf-8" ?> <FDL> <cafd id="000051DD" name="BDC" author="jaimeen" series="S18A"> <code description="PINK,RED,OCEANBLUE,ORANGE,MAGENTA,LIG HTGREEN"> <group id="360A"> <function start="32" end="183" mask="11111111b" comment="LIC_LCI_COLOR_LIBRARY_DATA">00, 1A, 01, FF, 02, FF, FF, 02, FF, 02, FF, 00, 03, FF, 02, FF, FF, 01, FF, 00, 0A, FF, 02, FF, 00, 0A, 00, 03, FF, 00, 0A, FF, 01, 17, FF, 8F, FF, 02, 17, FF, 8F, 00, 03, 17, FF, 8F, FF, 01, EF, EF, 00, FF, 02, EF, EF, 00, 00, 03, EF, EF, 00, FF, 01, 1D, 00, FF, FF, 02, 1D, 00, FF, 00, 03, 1D, 00, FF, FF, 01, 29, FF, 00, FF, 02, 29, FF, 00, 00, 03, 29, FF, 00, FF, 02, 00, 00, 00, FE, 01, 96, 00, 00, FF, 02, 96, 00, 00, 00, 01, 00, B0, 60, FF, 02, 00, B0, 60, 00, 01, 00, 00, 00, FF, 02, 00, 00, 00, 00, 03, 00, 00, 00, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF </function> </group> </code> <code description="360D"> <group id="colour combination"> <function start="3" end="24" mask="11111111b" comment="LIC_LCI_COLOR_PROFILES_DATA">00, 00, 01, 01, 02, 02, 03, 03, 04, 04, 05, 05, 00, 01, 04, 01, 05, 03, 00, 02, 02, 04</function> </group> </code> </cafd> <!--End--> </FDL> |
OzJedi107.00 |
05-11-2020, 02:05 AM | #191 | |
Rep 2,609
For those that want to do custom ambient colours and colour combinations, I don't think this will be possible without ESys and a Launcher (ESysX or Launcher Pro) as it is a) FDL coding (not VO), and b) requires access to a BDC ECU variant that I don't believe is in Bimmercode at this time (neither iOS, nor Android, neither production nor beta).
ifr1198.00 |
05-11-2020, 02:21 AM | #192 | |
Rep 2,609
05-11-2020, 05:39 AM | #193 |
1198
Rep 1,587
05-11-2020, 05:40 AM | #194 | |
1198
Rep 1,587
05-11-2020, 07:52 AM | #195 |
Rep 2,609
Maybe ... but I also couldn't find any of those parameters in any of the many G05 BDC ECUs on a quick (but not exhaustive) search.
05-11-2020, 09:04 AM | #196 |
267
Rep 345
Ignore the 4 and just do a general search for the file name. Once you locate you can add new colors if you wish. Note: it will still show up in you car as the original color. In other words - you can switch magenta for blue.
05-11-2020, 09:49 AM | #197 | |
Rep 2,609
05-11-2020, 01:36 PM | #198 |
267
Rep 345
Am away from computer and car. Original files came from the F15 sheet but others had confirmed for me. I will report back when I return home in a few days.
