04-25-2019, 11:25 AM | #155 |
Rep 6,121
My volume speed compensation stopped working via the 03/2019.37 software for the record, I'm going to make a new iDrive profile and see if that fixes things so you guys know.
04-25-2019, 01:55 PM | #157 |
Rep 6,121
That's what I had before but wanted cornering lights. It might work again with a new user profile, I'll have to make one and see. I have a decibel meter which could help me see but it's tough when you can't truly isolate other sounds
04-26-2019, 08:53 AM | #158 |
Rep 65
Anyone having "crackling" sounds coming from their B&W speakers?
I noticed this on Satellite radio, especially during talk radio (news, sports talk, etc.). I first thought it was a 3-D sound setting, but still hear this when I select the "studio" setting. Any thoughts?
2017 Audi Q7 Ink Blue/Beige 2015 BMW X5 50i Carbon Black/Tartufo 2012 BMW X5 35d Silver/Black |
04-26-2019, 10:34 AM | #159 | |
Rep 6,121
04-27-2019, 11:10 AM | #160 |
Rep 3,479
I have to pile on, along with everyone else. "Listening to lossless audio via bluetooth" simply does not make sense. Make a physical connection via audio jack or USB.
07-07-2019, 10:57 PM | #161 |
Rep 11
Thank you Tenac, iconoclast, davramic and magbarn for your comments. I finally got a chance to go back and check out the system. Unforntunately it did not start well - used a usb stick with lossless audio.
The system sounded "bland" and nothing I did to change settings would make a difference. Finally, the SA tried to change the volume using gesture control and after a few tries the system started to react. Switched off the gesture control on this vehicle and then the system came alive. Yes, it is good as I would expect. Now, hope fully software gremlins would go away soon. Using my iphone (lossless files) via a cord also sounded great. |
iconoclast7265.50 |
07-07-2019, 11:38 PM | #162 | |
191
Rep 353
Once you used gesture control to increase volume the sound changed ? can you discribe this a bit more? |
07-08-2019, 06:35 AM | #164 | |
Rep 4,246
"The X5 and X7 with Bowers & Wilkins Diamond Surround Sound system features 20 exactingly placed speakers powered by a 1475-watt 20-channel amplifier, with QuantumLogic® Immersion processing, full-active output stage technology, dynamic equalizing..." https://news.harman.com/releases/har...eva-motor-show Harman (a Samsung company) owns B&W automotive audio.
Thumbs27.50 |
07-08-2019, 10:10 PM | #165 |
Rep 11
Initially the system did not sound good at all. I could change the fading from back to front and also from left to right but nothing would change in how the system sounded even when I changed the bass/terble vis equalizer. The volume knob did work. Once SA changed volume via gesture control the system came alive .... meaning I could hear clarity and fineness of the system. I decided to turn off the gesture control and not waste any more time/ run into issues so I could listen to varying music and check out the sound. Hope this clarifies.
07-08-2019, 10:12 PM | #166 | |
191
Rep 353
07-17-2019, 11:18 AM | #167 |
Rep 72
volume spike
Do any of you have the volume spike upward then downward when you change the soundstage preset? I have noticed that no mater the source and am trying to determine if it is normal or I need to have them look at it.
I have also had the volume oscillate when listening to XM and my phone which I would think would be a signal issue until it happened on multiple sources. I am lookin to recreate but it seems very sporadic? Lastly, has anybody run a sound stage sweep to determine the true output range (20 - 20k)? I like the tight base, but still feel it could be a little deeper. Thoughts? Thanks! |
07-17-2019, 12:22 PM | #168 |
Rep 414
Distortion
Has anyone experienced distortion from the front middle speaker on the dash? Especially when listening to podcasts, I'm getting quite a bit of distortion from that speaker, and I'm not really sure what to do, short of taking it into the dealer.
I tried to "Reset" through the Settings menu but that has not helped. Any assistance would be helpful. May just have to take it in. |
07-17-2019, 01:13 PM | #169 | |
Rep 414
07-20-2019, 04:23 PM | #170 |
Rep 414
Update
UPDATE: Took it into the dealer and they noticed the crackling in the front speaker pretty quickly. The part has been ordered, but it's in Germany so will take around 2 weeks to get here.
Hopefully that will resolve the issue. |
07-20-2019, 08:01 PM | #171 |
Rep 599
No distortion or cracking noise at all and I play it loud. Still waiting for someone to share their EQ settings.
I do have to turn the volume down every time I change a song. Next song plays louder, etc. Kind of annoying maybe just me |
07-26-2019, 10:44 AM | #172 | |
Rep 72
From an EQ point of view, that is much more subjective and I find myself questioning everything. This song should have more this, that song a little more that. It is fun to play around with different setting as the type of music changes. So my wish for the system is more low volume bass. I find that the Bass is really good, tight, and voluminous at higher volumes. It can run some rap with the best of them. But on songs that don't have a heavy bass line, at lower volumes it could be a little more pronounced. For this reason I really like the Lounge setting, but that starts to mess with the front sound stage that is second to none in this system. So what I do most of the time is keep it on Stage, and bump the base up 3 clicks.... and will sometimes go to 4 or 5 if I am playing some classic rock where the bass line is not very robust. I like bass and with the awesome mid and highs this system puts out, the current settings will never overpower that aspect. I would love to run a sine wave through the system and have a spectrometer read it to really see if it is a flat response or if the bass rolls off two quickly to my ears. Ultimately I love it, think it is awesome, but given the price and the fact that my ears having me guessing a bit, I find myself second guessing a bit. What say you? |
07-26-2019, 10:59 AM | #173 | |
Rep 684
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
Supraman6618.00 |
07-26-2019, 11:21 AM | #174 |
Rep 3,507
Recently I have been noticing strange things with SiriusXM as well. I was able to confirm the same weirdness with audio also happens in the X3 and X5... I think it is something on the SiriusXM side.
2022 M8 Comp Convertible
gpitts247.00 Supraman6618.00 |
07-26-2019, 11:24 AM | #175 |
Rep 602
Have you tried the app? The sound quality, especially on the Mac bandwidth setting is leaps and bounds better than the sat version.
07-26-2019, 11:28 AM | #176 | |
Rep 684
