05-03-2024, 03:51 AM | #1 |
Rep 130
50e Questions
Hi,
I'm considering a 50e (yes, I have read all the horror stories!) and have a couple of questions. 1. If I set off on a long journey (say 200 miles) fully charged and drive in hybrid mode, what will happen to the battery by the end. Do I expect to arrive with it empty, full, somewhere in-between? 2. If I want to listen to music and be cooled/heated when parked how long can that happen before the car turns itself off? My current 30d insists on powering down after a few minutes unless the engine is running making it painful to try and listen to the radio when my kids doing football training or whatever. Would the 50e be better, assuming it had some charge in the battery Thanks |
05-03-2024, 04:54 AM | #2 | |
Rep 8,859
Drives: eVeRyOnE mAD!
2) the vehicle idles ~15 minutes then goes into standby |
05-03-2024, 09:07 AM | #4 |
Rep 549
You can conserve some battery capacity for your arrival which will allow for a bit of conditioning or electric-only driving at your destination. On my 45e it's the Battery Control function.
05-03-2024, 10:11 AM | #5 |
Rep 8,859
regardless of range, the vehicle won’t idle very long after ending the trip and go into standby mode after ~15 minutes
c_hri_s the only ways to prolong your music enjoyment while sitting in the vehicle are: 1) as long as you have battery capacity available, keep the vehicle on (don’t press the Stop button), and it will remain in the drive-ready state (see Guy Fleegman comment above) 2) if you don’t have any battery capacity available, you’ll have to sit idle with the engine running |
Major-Zebra58.00 |
05-03-2024, 10:53 AM | #6 | |
182
Rep 335
If your priority is to listen to music and use the AC after the 200 mile journey, I would reserve a 5 percent or more of battery for that. Depending on the speed at which you will travel through those 200 miles you can use the battery or not. Try not to use all of it and use it to cool down and chill. |
05-03-2024, 11:31 AM | #7 | |
Rep 8,859
05-03-2024, 12:23 PM | #8 |
Rep 638
I sometimes park and choose ‘pre-condition’ to keep the heating or a/c running and this seems to keep it running for 30min after which you can do pre-condition again in the climate menu.
I don’t like sitting with it in drive ready mode as the lights are on and it makes the ‘fake engine sound’ so might irritate people nearby etc |
nZtiZia4751.00 |
05-03-2024, 03:08 PM | #9 | |
Rep 8,859
can’t you also activate preconditioning via the key fob on the 50e? (three clicks of some button…) BUT does doing this also keep the electronics on so he can listen to music, etc? I wanna say it doesn’t because I’ve run preconditioning in my 45e to air out interior moisture from a leak recently, and I recall the electronics turning off after only a few minutes (much less than 15 or 30) |
05-03-2024, 04:12 PM | #10 | |
Rep 638
I’ll have to keep an eye on the electronics shut down, I’m sure I’ve had pre-condition on and the radio playing but I may have done something else to make this happen! |
05-03-2024, 07:33 PM | #11 |
Rep 6,935
If you have sufficient battery capacity, when the radio shuts down, you can just press the power button and it will run for about another 15-minutes…preconditioning runs for 30-minutes, and you can repeat as long as you have HVB capacity. The non-PHEV limit preconditioning to two times, and it’s shorter. If you keep things in READY state, you can keep things on as long as you have HVB or fuel in the tank…it seems to cycle the engine on/off from what I hear, depending on the HVB level, just like it does when you’re moving, regardless of the HBV level when needed.
05-04-2024, 01:53 AM | #12 |
2JZ-GTE
3070
Rep 4,020
Battery Hold can be your friend.
05-06-2024, 11:07 AM | #13 |
209
Rep 338
In addition to Battery Hold, what I do is enter my destination on the map but also add a second destination of my home. This way it keeps more of the charge for the return trip.
05-06-2024, 12:34 PM | #14 | |
Rep 897
05-06-2024, 12:38 PM | #15 |
Rep 6,935
There are two aspects to the sounds the PHEV can make…when moving below about 20km/h, that safety one is mandated by the US regulations (and in some other countries)…a fake engine sound continually can be disabled.
