12-01-2022, 04:20 PM | #155 | |
Rep 185
Yes very short trips, 1-5 miles most of the time, and thats round trip. If my trips worked I would show more. But for instance morning run to HS is 3.2 miles round trip. Trip to train about 2 miles. Little trips that add up to a lot eventually…. And usually filled with stop sights and lights and lots of stupid small streets traffic. Wow .5 for kW? And I thought we had bad prices here, the gas right now is actually 3.29$ for regular and 3.99 premium. Havent been to gas station with this car so far. Thats another good question, whats the gas recommendations? I see it says 89/91 on the cap. |
12-01-2022, 04:32 PM | #156 |
Rep 8,814
Drives: eVeRyOnE mAD!
12-01-2022, 04:56 PM | #158 |
Rep 6,893
It can take a fair amount of energy to warm the vehicle, especially if you're using seat, steering wheel, mirror, arm rests, and rear window heaters...remember, all of that is electrical, along with the cabin heat. Throw in maybe it's early or later, and you may have the lights on, too. If you're going to be doing lots of short trips, you may want to look into a battery maintainer, as you'll be putting a lot of stress on the 12vdc system that may not be fully replaced on a regular basis.
12-01-2022, 05:00 PM | #159 | |
Rep 185
Are you saying this because of the use of electric ? and 12vdc does not get regenerated ? Because i never had an issue before like this due to short trips. |
12-01-2022, 05:07 PM | #160 |
13609
Rep 20,238
There are differing opinions on that. I think you will be fine. In fact your battery should be charging more on those short trips than if you were taking longer highway drives but that is assuming the 45e uses the same logic for charging the 12v battery that it uses in its other models.
12-01-2022, 05:08 PM | #161 | |
Rep 3,708
Keep in mind, when charging, there is a charge lost of 14% for L2, and 21% for L1 from my observation So whatever the "electricity used" column said, more are drawn from plug. Using your input from above, $3.99 for gas, $0.3 for kWh. I got $0.22/mile for ICE, and $0.23/mile for EV (including 14% charge lost). Under this small margin, I i will still charge at home with L2. Because i believe if you do this kind of short trips with ICE, MPG will be below 17.8. Oh, and maybe I ask wheel/tire setup? I am trying to see if there is correlation between the significant difference between mi/kWh to wheel/tire setup.
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 12-01-2022 at 05:14 PM.. |
12-01-2022, 05:14 PM | #162 | |
Rep 185
12-01-2022, 05:35 PM | #163 | |
Rep 145
So 50/33.7 is 1.48 miles per kilowatt. So it's not bad in fact it's exactly what 45e is rated at. And typically very rarely you get what the manufacturer rates their vehicles at when it comes to EV range and efficiency (true for mpg in ICE world as well) |
12-01-2022, 05:42 PM | #164 | |
Rep 3,708
Maybe rare, but it seems 45e is well beyond 1.48. I would guess average will be above 1.81 too, but my sample size isn't big.
2022 G05 B58/PHEV
+ a few very old BMWs |
12-01-2022, 06:32 PM | #165 | |
Rep 199
https://www.fueleconomy.gov/feg/Find...n=sbs&id=42807 |
12-01-2022, 06:33 PM | #166 | |
Rep 6,893
The ICE versions of BMW use a clutch on the alternator, and it allows the state of charge on the AGM battery to often be less than 100%. The PHEV's DC-DC converter requires the HV system to be on, and that only happens when in READY state, or actively charging. If you plug in when you get home, and it doesn't need to charge much, not much gets into the 12vdc system, either during that potentially short time. The DC-DC power supply doesn't seem to have a huge excess capacity, IOW, it can run normal functions, with some smaller amount available to recharge versus maintain the 12vdc system. It's worse in the winter when all batteries have degraded capacity. If you regularly drive a decent distance, you may never experience this. If your regular use is short trips, you might, as you might with an ICE as well. What that magic distance is, I've not yet discovered, but it appears to be more than I regularly use mine! |
12-02-2022, 07:30 AM | #167 | ||
Rep 145
0.1 gallon / 100 mi of gas + 63 kwh/100 mi? I don't even understand this equation If you use 0.1 gallons that will reduce the overall 33.7kwh/100 mi to 33.7-0.1*33.7 which is 30.33kwh. But why plus a 63kwh/100mi?? Can someone who understands this please explain? |
12-02-2022, 10:20 AM | #168 | |
13609
Rep 20,238
12-02-2022, 10:49 AM | #169 |
Rep 185
Ok, so this morning I did try preconditioning for the first time and I'm a bit confused on how it works or what it supposed to do.
So I put in for 7:15am departure, as I understand the conditioning turned on 30 min before that ? When I go to the car around 7:17 the heat and my seat as well as wheel were hot and it was all going, (not the passenger seat ?). Anyway, I unplugged the L2 charger before getting in the car and when I got in it was all still running, is this what supposed to happen ? I'm supposed to turn it off my self when I get in ? Cuz that seems like its still wasting electricity after unplugged.. |
12-02-2022, 11:24 AM | #170 | |
13609
Rep 20,238
12-02-2022, 12:10 PM | #171 | |
Rep 3,708
For 45e, let’s give a shot to see what EPA did here. Assumption: 1. Ice combined mpg: 20, or 5gal/100miles 2. EV MPGe: 31miles/17.1kWh, using 33.7kWh=1gal, we get EV MPGe = 61.1MPGe, or 1.63galE/100miles. To archive 50MPGe or 2galE/100miles, as claimed by EPA, let’s estimate EV and ICE portion in term of percentage, x, here. 5x + 1.63(1-x) = 2, => x = 0.11, let’s call it 0.1 or 10% I think this is where that 0.1 gal in the epa chat is from. This means if you do 10% driving with ice and 90% in EV, you get 50MPGe. But then we should ask ourselves, why 10/90 split? Seem arbitrary to me. |
Scientifix81.00 Jrg317022.00 |
12-02-2022, 12:15 PM | #172 | |
190
Rep 367
(Just kidding, but your math makes my head hurt a little. ) |
12-02-2022, 12:35 PM | #173 | |
Rep 8,814
i scheduled preconditioning for 5:50am departure M-F. I notice it begins around 5:20, so 30 minutes prior to the departure time. I actually don't leave until 6:10, so it's not running anymore by the time I get in. I start the car and drive away. in your case above, it probably hadn't timed out yet by the time you got in (it runs for 30 minutes). I don't know what your HVAC settings are, but if that happened to me, I would just let it run, start the car and go. with HVAC on AUTO, it knows what to do. |
12-02-2022, 12:39 PM | #174 | ||
Rep 145
12-02-2022, 12:59 PM | #175 | |
Rep 185
So the automation for the heating of passenger seat with preconditioning and with just automation is based if passenger seat is occupied, that's good to know. |
12-02-2022, 02:04 PM | #176 |
13609
Rep 20,238
It won't heat the passenger by default but you can code it to do so if you need it. Personally I think if you have the cabin precondition it will receive some warmth from that and the passenger can just turn on the seat heaters if needed.
