12-17-2023, 10:53 PM | #1 |
Rep 12
SRSNVR: Misalignment – Side Radar Sensor Short Range Front Right
Hi Everybody,
I really can use some help here. I have been getting those lane departure warnings, active blind spot detection warnings, side collision warnings and intersection protection malfunction. As speed increases, these warnings start coming up. The malfunction warnings come up at 5 mph, 20 mph and 40 mph, which make sense. We don't really need lane departure at 5 mph. Used a scanner and got: 481CFB - Intermittent SRSNVR: Misalignment – Side Radar Sensor Short Range Front Right I could try getting a used radar sensor black box and see. Am I supposed to perform an alignment or re-calibration? Anyone can share a procedure on this? Much appreciated! |
12-18-2023, 10:28 AM | #3 |
Rep 12
The controller/module was loose and I put it back in place. This controller/module is mounted on the side of the bumper behind the reflector.
If this is the radar at the bottom center of the bumper, I would be super worry. It's like $5k for replacement. Only BMW makes it. |
12-18-2023, 10:52 AM | #5 |
Rep 12
Tried a used part this morning. Error did not go away. Tried erasing the error codes with the scanner and error came back.
I can't think of why a loose controller would cause error. It just holds the controller in place and does not appear to have actual sensors on the controller. They are wires connecting to the sensors (round dots x 4) on the bumper. I hate to remove the front bumper for inspection, but that might be the case. Any suggestions? Thanks for your help. |
12-18-2023, 11:29 AM | #6 |
Unapologetic Tool Hoarder
736
Rep 966
12-28-2023, 11:08 AM | #7 |
Rep 78
Check installation of sensor
Try re-calibration sensor with ISTA
F30 : Bowers Wilkins, ID6 Touch, RSE , 3AG, 6WB, 508, 322
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9, 3AK |
