      07-11-2022, 01:25 PM   #111
IllSic_Design
IllSic_Design's Avatar
Drives: 09 E92 335i
Originally Posted by StradaRedlands View Post
Very hypothetical, but how would this affect 330i tunes on someone that swapped on a two stage intake? I'm vaguely considering one of those in the future, so????
If you install a tune to take advantage of the 3 stage intake manifold then yes when you go to smog you will need to revert back to the stock tune in order to smog it and pass
      07-11-2022, 03:03 PM   #112
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Yes, three stage, glad you know what I meant! Well, guess I can scratch that from my to-do list!
      08-12-2022, 04:44 PM   #113
toy4two
12
Drives: BMW 328i
revert
"ECU has been tampered with".
The above is one of the 3 codes set when a 32X is flashed to a 330. The other 2 are for missing DISAs unless you actually have the 3SIM
Is that message generated from invalid checksum hash or failure to lock an ECU?
Do LCI+ e90's have locked ECUs unlike pre-LCI?
I guess the bottom line is, has anyone with a 328i who flashed up to 330i and then back down to 328i (with or without 3 stage intake manifold) actually passed smog in CA?
      08-12-2022, 11:23 PM   #114
StradaRedlands
2006 Mazda3  [5.50]
So I asked earlier as I have a three stage intake I was going to rebuild. Now it's just sitting in the garage, making me sad. I need to put up for sale, but if anyone is interested LMK...
      08-13-2022, 07:42 AM   #115
Marcoose
Marcoose's Avatar
Drives: 2016 sDrive35is
Another confirmation here that MHD flash back to stock(NOT stage 0) will pass CA smog inspection no problem, no CVN / checksum issues. Just had my car smogged yesterday, no problems with my inlets/outlets or intercooler left on, just made sure to throw on stock down pipes and air box to make it look stock
MHD customer here. How much time or how many miles did you let the engine run between flashing to stock and getting smogged? Thanks.
      08-15-2022, 03:53 PM   #116
IllSic_Design
Drives: 09 E92 335i
idk, I do it a week or two before it needs to be done to not have to worry about it.
540iSUP704.00
      08-29-2022, 02:23 PM   #117
McGyv3r
Drives: 1989 325i & 2014 335i
2014 BMW 335i  [0.00]
1989 BMW 325i  [0.00]
Where are the mods to delete all the off topic bullshit in this thread?!?
For everyone who wants to understand the checksum, I wrote about it and have pictures from my car:
https://f30.bimmerpost.com/forums/sh...5&postcount=25
The simple answer is that piggyback systems (like JB4) do not change the ECU's tuning, so they will not impact the checksum. These will likely fail a visual inspection (which can be ignored) and may throw engine codes and/or prevent emissions readiness monitors tests from completing.
ECU flash tuning will pass the visual inspection. However, any changes to the ECU's code will fail the plug-in inspection. This cannot be overlooked by the tech since the smog computer is reading the VIN and transmitting it to the CA DMV.
      08-29-2022, 02:25 PM   #118
McGyv3r
It's not about the miles, its about meeting the conditions for all the tests to occur. Check my link above, it has a (small) screenshot of how BMW describes the readiness monitor tests.
      08-29-2022, 08:46 PM   #119
Marcoose
Marcoose's Avatar
Hi. The only ‘engine’ mod I have is the MHD map. In addition to reverting to stock map (and obviously making sure the car is running clean), what else is needed to pass the smog test? Thanks.
      08-30-2022, 08:14 AM   #120
McGyv3r
Revert to the stock map and lock the ecu. This will give you the correct checksum. Then do the drive test from my link to reset the monitors. You can use a bluetooth OBDII adapter and an app to check them prior to going to smog. Assuming they all set, you pass smog.
A generic app may not tell you which monitors your car actually has. My link has the ones present on my car, which should be the same for yours.
      09-01-2022, 12:54 PM   #121
AmuroRay
AmuroRay's Avatar
2314
Drives: M235i
15 Shipping tankers create more pollution in one year, than all cars on EARTH - Combined.
This has nothing to do with emissions and saving the environment, and everything to do with making vehicle ownership more expensive by pushing the consumer to electric cars.
https://www.dailymail.co.uk/sciencet...ars-world.html
Mods: Yes.
      09-25-2022, 08:29 PM   #122
Homerus
Drives: BMW X5
Originally Posted by FCX5 View Post
Originally Posted by Patton250 View Post
Originally Posted by E92inPHX View Post
Add this to the list of reasons I'm glad I don't live in CA. A few day trip can be fun but I couldn't put up with that state full time
No doubt. These legislators are freaking nuts. at this point all I can do is laugh. It's not like these residents are stuck there like the poor Cubans or North Koreans. I can't believe anyone would live in that state at this point.
Higher quality of life and a better economy in CA compared to most of the other states in the US is probably what makes it a popular state. Highest GDP and highest GDP per capita among the big states. CA 'per capita' GDP is almost 50% higher than Florida for instance.
So the Cuba and North Korea analogy does not work for CA. Economically it is the most successful state.
As a Californian I disagree. It's got to be one of the most oppressive states. They claim great prosperity, but keeps raising taxes at every turn. Either they're are liars or they are thieves. Taking my income taxes, and my X5, to Florida.
      09-25-2022, 08:59 PM   #123
El Wray
Drives: AW X6M
I had to smog for the first time a couple months ago. Dinan tuned X6M with K&N filters. Passed on first try and was out of the station in less than 20 minutes. Received sticker in less than a month.
      09-26-2022, 04:02 AM   #124
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Dinan has a CARB number so it's legal,
      09-27-2022, 11:22 AM   #125
EezyBeezy
EezyBeezy's Avatar
271
Drives: 2018 BMW F[am]80 M3
Which tune in particular?
      09-27-2022, 07:11 PM   #126
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
go on to the dinan webpage and look by year make and model. It's listed on there.
      09-29-2022, 08:14 PM   #127
FCX5
FCX5's Avatar
Drives: X5 50i
Still love CA. This week I am in San Diego on work…enjoying the beautiful weather (and cars) LOL.
Tags
california, ecu, ecu bmw tuning, n54, n55, piggyback, smog, smog check, tune, tuning
