08-29-2020, 02:12 PM | #1 |
Rep 11
45e charging rate
My 45e keeps changing its charging rate from 16A to 6A as the maximum charge power.
I have a Pod-Point wall unit that is rated at 7kw ( I know that the car will only charge at 3.7kwh, but I wanted to be a little more future proof). I was wondering if anyone else has had this problem and/or has any advice on how you determine if the fault is with the car or the charger. Thanks in advance. |
08-29-2020, 02:24 PM | #2 | |
Rep 2,420
I think it is some kind of in build protection setting it back to 6A if something is wrong with the electric system. If it does it all the time there might be something wrong with your charger. The 7kWh shouldn't be the problem. Maybe you can try the BMW standard charger on 220 and see if it does the same? If it doesn't it is probably the Pod point. I have observed that with public chargers it switches automatically to 16A max and switches back to 10A again when I plug in at home. |
08-29-2020, 03:43 PM | #4 | |
Rep 10
I have same issue and bmw say it's a bug |
08-29-2020, 04:34 PM | #5 |
Rep 63
I charge my car daily with my wall charger (Zappi v2, 7kw) and never have experienced this issue.
I have used an i3 220v home charger once or twice at my dad's house, and it switched to 10A automatically, and when i came home and plugged my regular wall charger, it switched back to 16A. Works perfectly all the time. |
08-29-2020, 05:10 PM | #6 |
Rep 11
Thanks all.
It does sound that it’s likely the fault is with the car rather than the charger then. I have asked if I can swap cars (for charging purposes only!) with my neighbour’s I-Pace to see if I get the same issue with his Chargemaster charger. |
08-29-2020, 05:37 PM | #7 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Thanks for sharing this. Very helpful for those of us considering getting the 45e. I am eagerly waiting to see how BMW implements the technology in iNext.
My electrician friend isn't too keen on the inverter of 45e, plus the fact that North American models are limited to 17 kWh, and can't use the battery during camping, no 110 outlet ?!? I wonder why BMW is still catching up, can't get my head around it
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
09-02-2020, 03:23 PM | #8 |
199
Rep 353
Would people share what chargers they are using at home and what capabilities people should look for in a charger?
Some questions I have are:
09-02-2020, 04:45 PM | #9 | |
Rep 80
I use a Keba P30 C-Series, mainly because it is a seamless fit with my home automation system from Loxone. 1. Only you can decide whether the features are worth it. You can use the app or key to set departure and charging if you want to and the car will manage charging and pre-heating for your departure time. 2. In that case, the car "wins" and will only draw power a 6A. Much as it can be annoying (and I have had the same experience as others) if I plug in when I get to work, it will be charged when I leave and the same if I plug in when I get home. BMW should have put a 7KW or bigger charging capacity in the car if the speed of charging was a something they were concerned about. I think that is one area where Mercedes is better with the 350de; not only did they manage to get a larger battery, to get you 60 miles of range, but it will charge at 60KW, so you can pick up plenty of charge if you take the car out to a mall etc. But that is a whole other discussion and the BMW wins out in so many other areas. 3. Not that I know of. PHEVs just have smaller batteries, as far as charging goes. The clever bit doesn't come from the charger, but rather how the car manages the flow of electricity to the batteries and between and amongst the batteries. I have an i3S as well as a 45e and when you read up about how BMW manages energy around those battery cells it is pretty amazing (I think). |
09-03-2020, 04:59 AM | #10 | |
Rep 1,302
In that time the car switched from 16A to 6A. So even without charging the switch occurs. |
09-03-2020, 05:33 AM | #11 | ||
Rep 2,420
And because you are driving on fuel you won't see a switch from electric to hybrid. |
09-03-2020, 06:10 AM | #12 | |
Rep 1,302
Several engine tuners advised me to use E98 I checked the charging settings in the car yesterday and it was back at 6 amps. I don't have a clue what causes it to go from 16 to 6 amps after a while. Just like the sunroof not working. Almost 2 weeks without an issue now. Last time it was 2 days in a row when it gave a problem. Those damned Gremlins |
11-03-2020, 07:52 AM | #13 | ||
Rep 24
11-03-2020, 08:41 AM | #14 | |||
Rep 2,420
But I have been charging like that for 10 months now without any issues. I also have it set to 10A. This is the max amp for the home charger. |
11-03-2020, 08:47 AM | #15 | ||||
Rep 24
11-03-2020, 08:51 AM | #16 | |||||
Rep 2,420
Just make sure your home electrical system is ok. Don't do this with 20 year old cables. And just to be sure check if the wall socket is getting warm after a couple of hours and when done charging. Or let an electrician confirm it is ok. |
11-03-2020, 08:58 AM | #17 | ||||||
Rep 24
11-03-2020, 09:12 AM | #18 | |
Rep 2,420
There is a lot of current going through for 10 hours. If you are not sure better keep it at 6A. I don't want to be responsible for burning your house down. |
volodp198.00 |
11-03-2020, 09:15 AM | #19 | ||
Rep 24
11-03-2020, 09:36 AM | #20 | |||
Rep 2,420
I hope it will be solved with 11/2020 update. |
11-03-2020, 09:44 AM | #21 |
Rep 268
I just picked up my car and I'm experiencing the same charging issue. The car by default is set at 12A. I have a 30A charger but it is charging at ignoring the 12A limit and charging at 16A.
11-03-2020, 09:52 AM | #22 | |
Rep 2,420
I have mine set to 10A for charging at home with the normal BMW charger. I don't have a wall charger. However when I plug in to a public charger it automatically switches to 16A. When getting home a plugging in with my normal charger it is back to 10A. Sounds like this is what you experience? |
