12-07-2022, 10:11 AM | #2 |
Rep 7,519
What brand and how old was the replacement battery? I've read the same thing happening across multiple BMW forums. Also make sure that there isn't a protective (clear) cover on the back of the cell battery.
12-07-2022, 10:15 AM | #3 |
Rep 519
Put in a new Energizer battery last night and still got the message. The key works fine.
The BMW service tech this morning told me that it won't happen if you use a BMW battery. Whatever. |
MJBradley1967195.00 |
12-07-2022, 12:50 PM | #5 |
821
Rep 1,790
If you keep the fob close to the vehicle when it's parked I've read that the battery may be discharged more rapidly due to constant communication with the vehicle.
12-07-2022, 12:52 PM | #6 |
Rep 626
I was in your situation just last month. My original battery only lasted me 12 months.
Use a Panasonic battery and it’ll resolve your issue. I previously read that the Energizer battery produced a slightly different voltage. Our key fobs are really picky |
12-07-2022, 01:12 PM | #7 |
Rep 519
I'll try a Panasonic and see if that does it. Thanks!
12-07-2022, 04:03 PM | #8 |
Rep 176
I had one that got very low before any messages were displayed. I put a CVS battery in it, works fine, also have used other brands, not Panasonic or BMW. I would say a module is going out.
12-07-2022, 06:13 PM | #9 | |
Rep 7,519
Check your owners manual to see if it is the same for the G05 (there’s an owners manual built into iDrive that has a great searchable feature):
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-07-2022 at 06:28 PM.. |
X3_Alaska145.00 |
12-07-2022, 07:49 PM | #10 |
Rep 3,940
BMW doesn't make batteries. Most keyfobs come from the factory with a Panasonic.
12-08-2022, 05:30 AM | #11 |
1037
Rep 1,527
If your X is still under warranty the dealer will replace the fob battery for free if you ask them. I change all mine yearly regardless. No issues with energizer as well.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
12-08-2022, 08:17 AM | #12 |
Rep 7,519
Found a G05 X5 PDF version owners manual online...and appears it follows the same procedure as the previous gen F15 X5 if battery dies in remote and you get Check Control messages:
12-09-2022, 09:56 AM | #13 |
Rep 519
The key works fine from a distance. Also, while in the car and after the car is turned on it is still gives me the Battery Empty message. Just wierd.
12-10-2022, 08:09 PM | #14 |
Rep 7,519
The info was posted to show that the manual mentions multiple scenarios where you will get a Check Control message…and placing the remote next to the icon on the steering wheel is part of the solution.
Have you placed your remote next to the icon yet? If not, see if doing it will stops the check control message.
12-10-2022, 09:58 PM | #15 | |
Rep 519
aussieintexas222.00 |
12-10-2022, 10:12 PM | #16 |
13447
Rep 20,003
Figured that would do it, Energizers are known to cause problems with the fobs. Glad you got it worked out.
12-11-2022, 12:45 AM | #17 |
Rep 78
Maybe the battery that was not working was covered with a bitterant coating?
Garmin has recommendations for that. https://support.garmin.com/en-US/?fa...Dy8fDGEXYxtMM9 https://www.zdnet.com/home-and-offic...x-the-problem/ |
2heeldrive58.50 |
01-19-2024, 09:59 AM | #19 |
Rep 19
Drives: BMW X5 30d X-line
I had the same problem. With a new Duracell battery it said "battery empty". I tried the VARTA battery and it works fine.
2022 BMW X5 X-line 30d Phytonic Blue
Detailingshop.cz www.detailingshop.cz |
01-19-2024, 10:21 AM | #20 |
Rep 830
Energizer Li-ion here. I do not use Duracell in anything, worse batteries made. Any electronic device gets Energizer Li-ion
Two is One and One is None
02-02-2024, 04:31 PM | #22 |
19
Rep 43
Im having the same issue right now. I held the key fob next to the steering column and that fixed it for one trip and now it's back. Besides the error message, the key fob works as intended.
