11-15-2021, 08:49 PM | #1 |
Rep 104
Update: Touchscreen Retrofit is NOT Plug-and-Play
Really, this thread belongs in the Build subforum, but I'm putting it here because it's of greater value to you all.
UPDATE: I did get the touchscreen to work. I will write up a tutorial over the weekend. I took delivery of my touchscreen-delete X5 over the weekend. Today, the touchscreen I ordered from a 2019 X5 arrived. So I installed it. Installation was pretty straightforward, if a bit fiddly in practice (you do end up having to unseat the instrument cluster). Unfortunately, while the screen works just fine, it did not add touchscreen functionality. That tells me that whatever software update BMW did for these cars has both UI (removes prompts and options that reference the touchscreen) and functionality (removes the "touch" operation from the software's consideration, so that it literally isn't listening for or registering touch events). I am not giving up, though. I think the retrofit will require coding. I have the tool to do it, but can't get to it until tomorrow. I suspect that, with the software update, BMW added a new configuration parameter in the car's software, something like "Touchfunction Delete" (but in German). If that flag is set to inactive, the software allows touch input. If the flag is set to active, it disallows it. We shall see...
'22 X5 45e (Phytonic/Cognac/M Sport/Touchscreen Delete)
'16 535xi (Alpine/Black Nappa/M Sport) -- SOLD '11 X5 35i (Bronze/Sand Beige) -- SOLD '22 Outback Touring XT '06 XJ Vanden Plas Last edited by kplatinum777; 11-19-2021 at 09:51 AM.. |
10
bastula183.00 3Wagon129.00 dananelson1226.00 GrussGott18116.50 hulu106.00 DJVG243.00 Nuke888.00 Mckelvie37125.00 b1st49.50 CarFreak60.00 |
11-15-2021, 09:05 PM | #3 |
Rep 266
Drives: 2019 M550i xDrive
Yes waiting to hear back for good news! Crossing our fingers for you! Thanks for documenting all your hard work and efforts!
M550i xDrive
Mediterranean Blue with Ivory White Nappa, Gray Poplar, Driving Assistance Plus, Premium, Exec, Parking Assistance, Heated Steering, Front+Rear Heated Seats, 20" Individual V-Spoke wheels 759i, 19" Style 786M winter wheels, Euro Amber Rear Turn Signals 335i Coupe - Retired |
11-15-2021, 09:08 PM | #4 |
13187
Rep 19,669
I think you are going to have to at least remove the 6UY in order for it to work. Search for the thread with the coding for the anti-dazzle and it should have the steps in there that need to be done to remove 5AP, the code for deactivating the anti-dazzle.
11-15-2021, 10:45 PM | #7 |
Rep 33
Great to see someone take the initiative! Will that work with gesture controls as well? Also, curious if that will enable you to reactivate the back up assistant.
Keep us posted! |
dananelson1226.00 |
11-15-2021, 11:59 PM | #8 | |
13187
Rep 19,669
11-16-2021, 09:45 AM | #9 | |
Rep 104
'16 535xi (Alpine/Black Nappa/M Sport) -- SOLD '11 X5 35i (Bronze/Sand Beige) -- SOLD '22 Outback Touring XT '06 XJ Vanden Plas |
11-16-2021, 01:28 PM | #10 | |
Rep 132
i think there is a special version, the one they patched to the stop-sale vehicles.
11-16-2021, 01:37 PM | #11 | |
13187
Rep 19,669
11-16-2021, 01:54 PM | #12 | |
Rep 155
Long term, we’ll get the same updates as those w/ touchscreen, but then idrive will just run in whatever mode based on hardware. That’d be SOO much easier to maintain than trying to send out 2 different updates - just 1 update that runs in 2 modes. |
c12h231.00 |
11-16-2021, 02:04 PM | #13 | |
Rep 132
Yes. That's what I mean.
This is not even a normal release, more like a hotfix. Quote:
11-16-2021, 02:05 PM | #14 |
13187
Rep 19,669
That is not how BMW has operated in the past and highly unlikely they did it that way in this instance. They usually create a version every week, sometimes multiple ones, so this would just be part of that normal delivery.
11-16-2021, 02:22 PM | #15 |
Rep 155
Then I’m confused why they have to install it separately with the dealer. If it’s just a mainline release, then the software should just update normally. To me, that more suggests hotfix, but to your point, ya, we’ll just get the same release as everyone else,
11-16-2021, 02:25 PM | #16 |
13187
Rep 19,669
What do you mean by "update normally"? There is an OTA process but the software that is downloaded with that process is one major release behind. Anytime that the latest update is needed to solve an issue you must go to the dealer to have it installed.
11-16-2021, 03:10 PM | #17 | ||
Rep 3
Aliendrive96.00 |
11-16-2021, 07:34 PM | #19 |
Rep 104
UPDATE: I used Esys and removed option code 6UY from my car's VO list, but that doesn't seem to have done anything.
As I'm not trying to brick my three-day-old car, I'm going to pause and see if I can get an expert to assist.
Mckelvie37125.00 |
11-16-2021, 07:36 PM | #20 |
13187
Rep 19,669
I think that may just be one of the things to do. If it follows the pattern of the anti-dazzle, now you will have to check the ECUs to see if there is a parameter turning off the touchscreen functionality.
11-16-2021, 08:17 PM | #21 |
Rep 153
Maybe connect with the tech who applied the software update at time of delivery and see what other changes were made.
If this truly is a global update, meaning applicable for both touch and non touch screens, there could be a toggle to tell the software that this is a car without the touch screen And thanks for trying this out. A lot of folks are watching this closely |
11-16-2021, 10:11 PM | #22 | |
Rep 155
