      11-15-2020, 01:13 PM   #1
TechnoSeanSK
TechGeek / Foodie / BMW Fan
TechnoSeanSK's Avatar
21
Drives: 2019 F83 M4 / 2016 F15 X5
G05/iPhone 12 pro max/digital key
Has anyone tried setting up a digital key with the new iPhone 12 pro max? I cleared out the previous key from my iPhone 11 and the phone throws an error trying to add the key to the new one. Genius thinks it may be a compatibility issue so I'm hoping someone else here can try it.
      11-15-2020, 02:14 PM   #2
pho
pho's Avatar
Belgium
116
Drives: X5 xDrive45e
Same here with a 12 pro max; getting this error message.
Also a message that "the key can not be released" or something along those lines in iDrive (it's in Dutch in my iDrive)
Have an appointment next Friday at my dealer to look at it with the sales guy.
      11-15-2020, 03:02 PM   #3
Osheatwo
Drives: BMW M3 Comp Xdrive
2021 BMW X5 M50i  [10.00]
2023 BMW 330E  [10.00]
Just added it on my wife phone with no problem. We have ATT if that helps. My wife has 12 pro max and I have the 12 pro and the digital key works on both with no problem.
Go into the iPhone settings, then wallet settings and make sure the old keys are not showing. If so, remove them
You also will need to go into Apple Watch app, then Wallet setting and remove the old keys from there.
Once removed, then try and add the keys through the BMW Connected Drive app.
      11-15-2020, 05:18 PM   #4
daddymalu
Drives: M5
I am having same issues. New phone old bmw key is not there. I tried using the code from bmw and through the connected app. I also have both keys in my pocket.
      11-15-2020, 09:35 PM   #5
Whitebb
Drives: BMW X5 45e M Sport
I also had no issue of having the key into iphone 12 pro and 12 pro max. My wife is primary user, used her phone to get the key. She shared the key to my phone and also transferred to my apple watch.
      11-17-2020, 04:24 PM   #6
TechnoSeanSK
21
My wife has an iPhone 11 Pro so I will try to add it from hers and send me the key.
      11-19-2020, 01:29 PM   #7
TechnoSeanSK
21
Will you let me know what the dealer says?
      11-20-2020, 06:54 AM   #8
pho
pho's Avatar
Belgium
116
Well, the dealer knew as much as me. It was the first time he ever played with that feature himself, so... He also had no clue why it was failing.
We made an appointment to bring the car in next week for 2 days; they will open a case with the team in Germany but the car needs to be connected to their system while it's being diagnosed.
Will let you know if/when it ever gets sorted out :-)
      11-20-2020, 11:02 PM   #9
daddymalu
Drives: M5
My issue was that I had the engine on. Once the engine is off my phone was accepted as the digital key. Thanks.
      11-25-2020, 02:19 AM   #10
pho
pho's Avatar
Belgium
116
So. I got it working. I'll sketch the timeline of the events that led to the success:
- this morning, got into the car and went into the menu to "reset" the digital key. this causes you to get a mail from ConnectedDrive with some info about how to set it up - didn't do anything with the mail, figured I could just forward this to the dealer later so he can use the link to try it.
- dropped of the kids at school (made 2 stops that included shutting off the car and walking away)
- drove to the bmw dealer
- shut down the engine (pushing the start/stop button)
- figured I'd try it one last time, "just in case": I clicked the link in the mail from ConnectedDrive I got earlier this morning, this opens the Wallet app. Followed directions, put the phone in the tray, and it paired succesfully.
So obviously just drove home again after informing the dealer it's no longer needed
I don't know what prompted it to work as I tried all different kinds of pairing before, also together with the dealer; with the link from the mail, from the connected app, manually, ... And I've reset the digital key multiple times before.
My phone updated from iOS 14.2 to 14.2.1 in the mean time, maybe that has something to do with it.
Hope you get it working too!
Rodrick34.50
      11-25-2020, 12:47 PM   #11
WhereItsAt
Constantly Learning
WhereItsAt's Avatar
Drives: Four Wheels
Can two phones have the digital key?
nZtiZia4635.50
      12-23-2022, 05:38 PM   #12
mediopogi
Drives: 2006 BMW 330i
Reviving this thread instead of creating a new one.
I’m setting this up using iPhone 14pro with iOS16.2 on MY23 X5 xdrive 45e (whew) and I’m having the exact same error. I tried as far as resetting iPhone to factory defaults and setting up as new iPhone to no avail.
      12-23-2022, 06:06 PM   #13
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
no, only one phone can be assigned as a Digital Key
      12-23-2022, 06:22 PM   #14
nZtiZia
nZtiZia's Avatar
i just received my iPhone 14 Pro today also on iOS 16.2.
- brought my iPhone and key fob inside the vehicle.
- deleted my old iPhone.
- ensured both wifi and bluetooth were on (blue) in my iPhone 14 Pro.
- went to COM > + New device.
- as the vehicle was looking for my iPhone, i found that going into its Settings > General > CarPlay would show the vehicle ID for pairing quicker.
- once my device was found and showed on the vehicle screen, i tapped on its name and followed screen prompts on both the iPhone and iDrive
- done!
then i set it up as Digital Key
- opened MyBMW app and tapped on Set up Digital Key
- followed the on-screen prompt to place phone in the NFC tray
- went to Car > Settings > Doors/vehicle access > Digital Key > Activate Main Key and followed the on-screen prompts.
-done!
**ensure no other iPhone is already assigned as the Digital Key because there can only be one.
      12-23-2022, 06:26 PM   #15
mediopogi
Thanks! My I had no issues with CarPlay. I’m having problems with the BMW Car key adding to Apple Wallet.
      12-27-2022, 10:40 AM   #16
mediopogi
- done!
-done!
Glad it’s working for you. I still have an issue and I think it’s on the Apple wallet side. I’ve reset my iPhone several times but I had no luck. will try again when software update becomes available.
      12-27-2022, 11:20 AM   #17
nZtiZia
nZtiZia's Avatar
is your engine running while trying to add Digital Key to Wallet?
      12-27-2022, 11:29 AM   #18
mediopogi
No. The car is in standby state (only instrument and center display on); not drive ready state.
I’ve done several ways including this cycle: Turn to drive ready —> turn off —> open the door —> step out/in —>close door —> the with 2 keys inside the cabin perform digital key activation. I’ve tried 3 different procedures as well: (1) the myBmw app (2) email link (3) manual code entry (uncommon) and I keep getting iPhone error that says BMW key cannot be added.
I’ve searched online and apparently others have issues as well and it seems the activation is finicky.
