11-25-2020, 01:39 PM | #1 |
Rep 3,411
Tire Chains
I've got a G05 with 275/45/R20 tires. I know I signed a tire chain disclosure that the G05 as equipped cannot be operated with tire chains.
Has anybody come up with a cable chain that actually works with a G05 with my tire size. I've searched like crazy and cannot find anything. |
11-25-2020, 02:27 PM | #2 |
Rep 185
Just make sure that they are All-Season and not Summer tires:
https://www.amazon.com/TireChain-com...N6R1KEBKQSY90S https://www.tirechain.com/275-45-20.htm |
sygazelle11338.50 |
11-25-2020, 04:47 PM | #3 |
Rep 8
I got this just in case for 2020 M50i with 275/45-20, never used yet, but haven't found any issue to put this on just for trial.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 maybe you can check here for more option. https://www.etrailer.com/chains-2020...-275%7C45%7E20 |
sygazelle11338.50 |
11-25-2020, 07:55 PM | #4 |
Rep 3,411
I appreciate your responses. I too found those chains by doing an internet search.
Let me be more specific: When I bought the G05, I was told I could not put tire chains on it and I had to sign a disclosure agreeing that I know the vehicle is not set up for tire chains. (I've attached this disclosure). I know there are many tire chains that fit the 275/45/20 tire, but I'm reluctant to try them because of this disclosure and the BMW Manual. With that background, I have a two-part questions: 1) Have you tried regular tire chains on your G05 with success? (proper clearance, no banging, no damage to rims) or, 2) 1) Have you tried cable chains on your G05 with success? (proper clearance, no banging, no damage to rims) Thanks. |
11-25-2020, 07:58 PM | #5 |
Rep 3,411
BMW Manual on chains
A bit more background: Here is language from the BMW Manual on chains.
Fine-link snow chains The manufacturer of your vehicle recommends use of fine-link snow chains. Certain types of fine-link snow chains have been tested by the manufacturer of the vehicle and recommended as road-safe and suitable. Information regarding suitable snow chains is available from a dealer’s service center or another qualified service center or repair shop. Use Use only in pairs on the rear wheels, equipped with the tires of the following size: 255/55 R18. 265/50 R19. 275/45 R20. Follow the snow chain manufacturer's instructions. Do not reset the Tire Pressure Monitor TPM after mounting snow chains, as doing so may result in incorrect readings. When driving with snow chains, briefly activate Dynamic Traction Control DTC to optimize the forward momentum. Maximum speed with snow chains Do not exceed a speed of 30 mph/50 km/h when using snow chains. |
11-25-2020, 08:03 PM | #6 | |
Rep 3,411
I plan to buy cable chains that fit my 275/45/20 all season tires. According to the BMW manual, I should be only putting these "fine link snow chains" on the rear, even though the G05 is AWD. I do not plan to ever have to actually put these on the car. I am a fair weather skier avoid going to the condo when there is a storm. It is mostly to get past the CHP checkpoint when they require you to carry chains. |
11-25-2020, 08:07 PM | #7 |
Rep 185
That is this style... https://www.tirechain.com/images/2000-3000-Cable.jpg
sygazelle11338.50 |
11-25-2020, 08:19 PM | #8 | |
Rep 3,411
I ended up buying this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Fennario153.00 |
11-26-2020, 07:24 AM | #9 |
1037
Rep 1,526
just curious, are you driving on 100% pure ice, as in a frozen lake? Not sure why you would need tire chains for just driving in snow unless you only have rear wheel drive or summer tires?
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
11-26-2020, 07:35 AM | #10 | |
Rep 802
CGG170.00 |
11-26-2020, 09:36 AM | #11 | ||
The Dark Knight
420
Rep 1,262
11-26-2020, 11:36 AM | #12 |
Rep 185
OP lives in the Bay Area like I do. If you go to Tahoe then you are required to have a set of chains in the car regardless of 4x4, snow tires, etc. There are 3 levels of chain controls and R2 is common on I-80. R3 is rare for interstates but can happen on local highways/roads.
Chains are required under the following conditions: Requirement 1 (R-1): Chains are required on all vehicles except passenger vehicles and light-duty trucks under 6,000 pounds gross weight and equipped with snow tires on at least two drive wheels. Chains must be carried by vehicles using snow tires. All vehicles towing trailers must have chains on one drive axle. Trailers with brakes must have chains on at least one axle. Requirement 2 (R2): Chains or traction devices are required on all vehicles except four-wheel/all-wheel drive vehicles with snow-tread tires on all four wheels. NOTE: (Four-wheel/all-wheel drive vehicles must carry traction devices in chain control areas.) Requirement 3 (R3): Chains or traction devices are required on all vehicles, no exceptions. |
11-26-2020, 11:44 AM | #13 | |
Rep 3,411
Thanks for spelling it out. People from outside California have no idea what we deal with. I have been skiing for many years and I understand why CHP has such tough requirements. There are a lot of people who go up to the snow unprepared and get into trouble. CHP has never made me put chains on when I was in an AWD vehicle with at least all-season tires with M+S designation. But, if I didn't have chains in the car, they would have turned me around. |
11-26-2020, 11:49 AM | #14 |
Rep 3,411
I bought the ZT741. According to the fitment guide, this is the size that fits my 275/45/R20 tires. Here's the link: https://www.streetsideauto.com/shop/...er-z-lt-chains |
11-26-2020, 11:53 AM | #15 |
Rep 3,411
I never expect to have to put them on. In California, the CHP requires vehicles to carry chains. If you get to a checkpoint and don't have chains, they will turn you around. For 90 bucks, I can avoid this situation.
11-26-2020, 11:57 AM | #16 | |
Rep 3,411
11-26-2020, 04:42 PM | #17 | ||
The Dark Knight
420
Rep 1,262
11-27-2020, 01:49 AM | #18 |
Rep 160
Drives: G05 M50d 2020
how about these:
Thule K-Summit XXL K67 Snow Chains, 2 Pieces: https://www.amazon.com/Thule-K-Summi.../dp/B009NPLFDY That's what I get when I enter my X5 G05 on thule.com |
11-27-2020, 11:21 AM | #19 | |
Rep 3,411
Interesting design since the chains don't go on the inside of the tire at all. The $400 price is a non-start. |
11-27-2020, 11:37 AM | #20 |
Rep 160
Has anyone tried fitting Michelin Easy Grip tire chains?
11-27-2020, 01:17 PM | #21 | |
Rep 15
One other time we got past Truckee just before chains were required and I80 was closed. They closed the road behind us and I remember how peaceful and quiet the drive was with no other cars on the road and the snow coming down. Keep the suggestions coming as I need to get chains for an incoming X5 (Colorado is getting as anal with chains as California now and am starting to look for options). |
11-30-2020, 06:01 PM | #22 | |
Rep 485
