      03-08-2020, 07:40 PM   #1
kmarei
kmarei's Avatar
Egypt
685
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Exclamation Anyone with spacers on 20” wheels?
Does anyone have spacers on the 20” wheels?
Dying to see pictures before I buy spacers
I’ve seen a lot of pics on 21 and 22” wheels
But those have different offsets.
The front wheels are 9.5” instead of 9”, the rear wheels are 10.5” instead of 9”
According to my calculations
I’d need 20mm spacers in the front and 30mm in the rear
That would match 15/20 on the 21/22” wheels
      03-09-2020, 10:40 AM   #2
Bigskyinminnie
Drives: 2020 X5 M50i
IÂ’d need 20mm spacers in the front and 30mm in the rear
kmarei - I just installed 10mm front 20mm rear on my 20" wheels. I'll get some photos later today and post up.
bhe104.50
      03-09-2020, 10:48 PM   #3
Bigskyinminnie
Not the best photos. Rear looks more aggressive than in the photos but I'm also not looking for constant crud on my lower fenders.
      03-10-2020, 07:42 PM   #4
kmarei
kmarei's Avatar
Egypt
685
Thank you very much
Looks good
But I think I need more aggressive than that
Maybe 18F and 25R
      03-10-2020, 09:29 PM   #5
Bigskyinminnie
Thank you very much
Looks good
Maybe 18F and 25R
No doubt you'll likely be happy with bit more push out. This is my winter set in nasty Minnesota winters so I'm not too picky with how they turned out. Good luck!
      03-21-2020, 07:11 PM   #6
kmarei
kmarei's Avatar
Egypt
685
I finally installed the spacers
18mm front
25mm rear
1st pic before
2nd rear with 25mm spacers
3rd pic front with 18mm spacers
This is with the oem 740m 9” wheels front and rear
      03-23-2020, 10:44 AM   #7
Mikli
88
Drives: G05F36F16F82E90E86E46E36E30
The spacers looks good
      04-08-2020, 09:35 AM   #8
ADY282
Drives: Ford Mustang, BMW Z4 and X5e
Spacers
18mm front
25mm rear
1st pic before
Do you need new bolts etc or just straight fit ?
      04-08-2020, 09:40 AM   #9
kmarei
kmarei's Avatar
Egypt
685
The 18mm in front front came with extended bolts
The 25 for the back are the ones that come with short bolts
You attach spacer to the hub using these
And then you use the oem bolts to attach the wheel to the hub
I much prefer this kind
But the thinnest you can get them is 22.5mm
Was worried it would be too much for the front
The advantage of this kind ifs you are not using longer (weaker) bolts
And to all intents and purposes you treat the wheels the same way as if you didn’t have a spacer
You undo bolts, remove wheel
Reattach wheel and tighten bolts
As opposed to trying to match the whole in the spacer with the hole in the hub when you put in the wheel bolt
      04-08-2020, 01:27 PM   #10
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
I have on the 748M wheels which are 20x9 et35.
Running 11 MM on the front and 30 MM on the back.
I think it looks good.
      04-08-2020, 04:14 PM   #11
MystroX5
MystroX5's Avatar
6284
Drives: 2020 X7 M50i/ 911
Have you noticed any additional water/dirt fanning up on the back fender?
      04-10-2020, 08:50 PM   #12
Jevi Javi
Dominican Republic
80
Hmm, i’ll check and report back
MystroX56283.50
      04-11-2020, 01:38 PM   #13
Really_fat_ninja
Really_fat_ninja's Avatar
404
Drives: 2020 X5
Looks nice
Instagram @really_fat_ninja
http://www.instagram.com/really_fat_ninja/
      04-13-2020, 11:17 AM   #14
Jevi Javi
Dominican Republic
80
Nope. Normal, i would say. But really it hasn't rained much around my area lately...
      11-25-2020, 04:15 PM   #15
bimmerwerks
Drives: G05xdrive40I
18mm front
25mm rear
1st pic before
This is with the oem 740m 9" wheels front and rear
18mm front
25mm rear
1st pic before
Do you have side view picture of the whole car?
      11-26-2020, 12:23 PM   #16
kmarei
kmarei's Avatar
Egypt
685
You mean like a profile pic?
As in facing the side of the car?
      11-26-2020, 02:42 PM   #17
Portocale
Portocale's Avatar
Netherlands
59
Drives: BMW X5 2020
18mm front
25mm rear
1st pic before
Sorry for the silly question, is 18 mm per axle or per wheel?
      11-26-2020, 03:16 PM   #18
bimmerwerks
Yea like from side of the car
      11-26-2020, 03:50 PM   #19
taybo20
Drives: 2021 X5 xdrive45e
This is lifting the car right?
      11-26-2020, 10:01 PM   #20
Galion
Drives: X5 - 750iL
Do you have a link? Any vibrations at high speed?
      11-26-2020, 10:05 PM   #21
kmarei
kmarei's Avatar
Egypt
685
Per wheel
So 18mm per wheel, 36mm per axle
      11-26-2020, 10:06 PM   #22
kmarei
kmarei's Avatar
Egypt
685
Sure
Will take some pics tomorrow
