10-23-2021, 08:32 PM | #375 | |
Rep 4,665
As I type this I might be a pzdata issue. I thought the file I downloaded was 4.31.31, but this may not be correct. The zip file is listed as 4.28.21, which would not be correct for the 3.21.55 istep. I'll download the latest PZdata and see if it fixes things. Egg on face
10-23-2021, 09:36 PM | #376 | |
Rep 8,364
10-28-2021, 10:09 PM | #377 | |
Rep 8,364
12-18-2021, 01:53 AM | #378 | |
Rep 272
12-18-2021, 02:48 AM | #379 | ||
Rep 51
12-18-2021, 12:24 PM | #380 | |
Rep 8,364
12-19-2021, 12:30 PM | #382 |
Rep 272
12-20-2021, 10:16 AM | #383 |
Rep 2,609
Not clear what specific "this" is referring to on an 18 page thread, but G06 and G05 are essentially the same electronics platform, so anything referring to G05 applies to G06. There are more variations between software versions and car build dates than there is between G05 and G06.
has1287.50 |
12-20-2021, 11:06 AM | #384 | |
Rep 11
And thanks for the answer. I will give it a go and check. |
Bambazonke210.00 |
12-21-2021, 09:56 AM | #385 |
Rep 272
Thanks. Just did coding today and aSLA + TLA work again
12-21-2021, 04:12 PM | #387 |
Rep 133
I have this coded on MY2019 G05, and works well. I coded this using EsysX. My iLevel is at 11/2021.30.
I also have TLA, but it does not work as intended in the US. I think that it's because of the placement of traffic lights in the US. In Europe they are placed on the side of the roads before the intersection, and in the US they are on the opposite side of the road and towards the middle of the intersection. Just my opinion tho. |
12-21-2021, 07:20 PM | #388 | |
146
Rep 337
12-21-2021, 07:37 PM | #389 |
Rep 133
It works, but no the way it's intended. It stops in the middle of the intersection, which makes it very dangerous. The other features work such as the light recognition, and also the reminder when the light turns green.
01-11-2022, 05:04 AM | #390 |
Rep 18
Hello I guys, im quite new with coding..
During the weekend I tried to do some first codings to my G05 I have: E-Sys 3.27.1 E-Sys Launcher PRO V2.8.2.162 PSdZData Lite 4.33.11 My G05 is 06.2020 I succesfully coded ASS tl last position Ive tried to code M/Alpina dash, M Logo but without success I was able to read ECU, read coding data but than im not able to find for example: GLOBAL_LAYOUT_VARIANTE to change dash to M I can see some folders with numbers and than only folders without name like on attached picture: |
01-11-2022, 03:24 PM | #391 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 01-11-2022 at 04:00 PM.. |
01-12-2022, 04:03 PM | #393 |
Rep 451
ESys 3.34 or greater to do FA editing & VO coding only. PszData must be same release as your current iLevel or younger PM Shawn Sheridan for links to the latest ver of ESys & PszData. He also has a contact for Launcher Pro 3.7x which does NOT have the latest NCD mappings but you can use it to code aSLA only in conjunction with BimmerCode that has the latest mappings for the BDC & MGU_HU ECU's. Launcher Pro 3.7x is missing or does not have the correct FDL mapping for TLA & other MY21 features in the SAS3, BDC & MGU_HU ECU's.
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 02-18-2022 at 08:12 PM.. |
Resjudicata1603.00 |
03-20-2022, 09:00 PM | #396 |
Rep 606
whats needed to be coded for:
- to have angel eyes at 100% with headlights? - delete sidemarkers? - automatic braking when reversing too close to something? - automatic braking when coming close to something when going forward? 2019 G05 xDrive50i have BT OBDII (MX+) with Bimmercode ordered esys cable and have all software downloaded but no clue how to use it as of yet, though, but want some instructions ahead of time any help would be appreciated |
