      10-09-2021, 06:37 AM   #1
walkday
Drives: BMW X5 xDrive45e
Angry Help: ProTool messed up my BDC
Purchased the latest ProTool to decode anti-dazzle. After VO coding (removal of 5AP) and during factory coding of the BDC module, it failed and reported corrupt CAFD. My X5 lost its headlights, turn signals, etc.
I installed E-sys and took a screenshot of the BDC module. It shows strange CAFDs, which cannot be read. Could someone tell me how to fix it, please? This is a 2022 xDrive45e with all available options.
      10-09-2021, 10:19 AM   #2
Roch M4
I /// M FAN
424
Drives: M4 SS/SO 2016 / X5M C 2023
If missing or corrupt, in your case, you cannot load saved NCD. You must inject:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired FRM => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom) => Select OK => Right-Click on FRM (the ECU itself not the underlying CAFD) => Select CODE.
      10-09-2021, 10:29 AM   #3
Roch M4
I /// M FAN
424
https://www.bimmerfest.com/threads/h...d-file.927245/
      10-09-2021, 01:39 PM   #4
walkday
Thanks. However, on both E-Sys 3.27.1 (via Launcher PRO 2.8.2) and E-Sys 3.36.2 (by direct launch), the "Read SVT (VCM)" step failed -- I was clicking on "Read (VCM)" under SVT Actual. E-Sys 3.27.1 returned a 433 error. E-Sys 3.36.2 returned 0 ECU. Was my VCM also damaged?
      10-09-2021, 10:53 PM   #5
Roch M4
I /// M FAN
424
I think that your version of Esys and Launcher Pro is not compatible with G05
      10-10-2021, 12:46 PM   #6
maximking
108
Drives: F10
pm me i can help you restore data for free
      10-11-2021, 04:44 AM   #7
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
462
Drives: 2021 X5
2021 BMW X5  [10.00]
Were you able to keep a backup before coding attempt?
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
      10-12-2021, 06:34 AM   #8
alizandru
automotive enthusiast
Romania
32
Drives: G20 M340i 2021
2021 BMW M340i  [0.00]
  [0.00]
Hi, i am also using Protool a lot, and had a few issues with it. But everytime, the support helped me put my modules back online.
To recover it you have to inject standard CAFD's manually, select all the CAFD's and then factory code the module. After that recover the coding backup, if you have it.
      10-14-2021, 01:51 AM   #9
walkday
Thanks to everyone above! I sent my car to the dealer, and they fixed it and of course told me not to mess up with the software again. Imagine the moment I thought I broke down an $88k toy (after tax). I don't know if I will be brave enough to fiddle with Protool again.
      10-15-2021, 06:23 AM   #10
alizandru
Romania
32
  [0.00]
Protool is fine. As long as you code in diagnostic mode, put the phone in airplane mode and have a good battery, everything will be fine.
      10-15-2021, 03:40 PM   #11
walkday
I did exactly this. In particular, I was using ENET with a USB-C ethernet adapter. The Android 11 device had more than 50% of the battery. After the airplane mode is enabled, I turned ethernet tethering on.
      10-16-2021, 08:36 AM   #12
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
Except you can't turn on ethernet tethering when airplane mode is active.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      10-16-2021, 04:57 PM   #13
walkday
First of all, I did, so I know you can.
Second, check BimmerCode's Manual at https://bimmercode.app/manual/ . Click on Android, look up for ENET cable connection (Android 11):
3. Enable the Airplane mode on the Android device.
4. Enable “Ethernet tethering“ in the Android settings (“Settings“ > “Connections“ > “Mobile Hotspot and Tethering“ > “Ethernet tethering“).
