      10-12-2021, 09:03 PM   #1
R34L15T
Drives: 2019 BMW X5 30d M Sport
Recently got myself a Spigen Magsafe vent phone holder which also charges the phone.
I somehow want to know if it's possible feed the cable through the air vent where the holder is placed and get it to the cigarette lighter where the cupholders are.
Something possible or am i dreaming?
BMW X5 30d M Sport
      10-13-2021, 02:51 AM   #2
Kas63
Kas63's Avatar
United Kingdom
80
Drives: 2020 X5 M50d
Just a word of caution. Some of the air vents are quite weak and flimsy. I used an air vent phone holder and when I was trying to remove it the air vent mechanism and direction fins broke. Fixed under warranty but looked an expensive repair if the warranty hadn't covered it.
Having said that I'm sure there are others here that have had no issues, just my personal experience.
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
      10-13-2021, 06:59 AM   #3
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
i doubt there's an outlet from within the vent tubing for the cable to come out unless you drill a hole. then you'll be venting out of that hole.
      10-13-2021, 04:39 PM   #4
R34L15T
Thought if i take the whole vent trim off completely i can place the wire behind the vented itself/or on side.
Yes already had an issue with a holder. The whole vent came off. Took me a good hour to put it back to how it was - but luckily nothing was broken 🤞🏼
BMW X5 30d M Sport
      10-13-2021, 05:43 PM   #5
nZtiZia
nZtiZia's Avatar
i haven't seen the Spigen MagSafe charger, but if you could attach it to the ProClip mount designed for the G05, you can avoid stressing the vent fins altogether. i did this with a MagSafe charger from Amazon.
      10-14-2021, 10:09 AM   #6
R34L15T
The holder is pretty good. I don't think it causes too much stress on it and i've tried shaking it around with the phone on and it's solid so far. I have a iPhone 13 Pro Max. So quiet heavy too.
[IMG]https://ibb.co/VprKFqP[/IMG]
[IMG]https://ibb.co/8DgbRKY[/IMG]
BMW X5 30d M Sport
