10-13-2021, 10:03 PM | #1 |
Rep 64
No More Hitches?!?
Has anyone heard about the trailer hitch option getting removed? I'm about to order an X5 M50i and the sales person just emailed me and said that everything X3 and above is getting the option removed due to supply issues. Say it ain't so…
10-21-2021, 04:26 PM | #2 |
Rep 64
Production question. It looks like I have a VIN assigned in My BMW Garage and it says the car is in "Production Begins" status. Looking through the options listed, I can confirm it matches my order. BUT, when looking at the BMW website configurator it appears the trailer hitch isn't an option anymore. Given where the car sits currently in production, is there still a high probability my build will get adjusted? Or is VIN assignment a good indicator the build is locked?
10-21-2021, 04:32 PM | #3 | |
Rep 512
if it's there...i'd say youre in the clear |
10-21-2021, 06:47 PM | #4 |
Rep 127
10-21-2021, 06:52 PM | #5 |
Rep 6,789
If it shows on your build sheet once production begins, that generally means that all of the parts for your order have been allocated and should arrive to be incorporated into your vehicle. If there's a supply issue, the build sheet (should have been) would not show it on the vehicle as I understand things.
10-21-2021, 07:03 PM | #6 |
Rep 810
I assume this is the factory option, but that doesn't mean the dealer or aftermarket approach is going away, and BMW know this.
So I am guessing they are trying to simplify and consolidate their options. Here's the dealer installed version I am getting, with BMW OEM controller/harness and coding. Last edited by James_G0540i; 10-21-2021 at 07:08 PM.. |
10-21-2021, 07:18 PM | #7 |
Rep 155
My m50i JUST went into production begins status yesterday and has the tow hitch.
10-21-2021, 07:43 PM | #8 |
Dude man
164
Rep 329
Parts shortages, namely chips for the electronic part of the hitch control.
Strangely, I also have a Ford Bronco on order, and the tow pkg is also one of the packages that is in short supply. |
10-21-2021, 07:51 PM | #9 | |
Rep 512
My wife works in logistics for her company and it's been an utter nightmare for her finding out where her containers are (off the coast of Los Angeles in most cases) and opting to find space on cargo flights for hypercritical items where inventory falls to near shutdown levels and they want to keep the production wheels turning to keep meeting demand |
10-21-2021, 07:57 PM | #10 | |
34
Rep 30
This was the primary reason for me switching back to BMW after years of Mercs. Glad to have had mine built & delivered. Hope yours comes through as you spec'd. |
10-22-2021, 12:16 AM | #12 |
146
Rep 337
I've just installed stealth hitch to use with my bike rack. It's nice that it's hidden and the trunk door operates with a foot (if you order tow option from BMW - this is not working).
10-22-2021, 12:34 AM | #13 |
Rep 6,789
I had the predessor of the STealth hitch on my last vehicle, and it worked well but, because it comes out below the bumper, rather than IN the bumper, depending on what you're trying to carry, I had it hit on occasion if there was say a drainage channel going into a sloped driveway at the roadside. Until you get familiar with it, you may need to lay on the ground to remove and or replace the receiver or ball assembly in the socket, then lock or unlock the keyed latch (the spring loaded one can be awkward to unlatch, too, as the spring tension is significant). Cutting the under cover means that water, slush, and sand, crud can get in behind the bumper cover over time. On the older version, that could lead to corrosion on the parts...the newer one is supposed to be better at this, don't know, don't have one.
If you ever do want to tow something, while you can get an interface to make the lights work, there's a lot more that the oem towing package provides like new camera views, stability logic, trailer light monitoring, bigger brakes, and (I think) more robust cooling. Mostly irrelevant if you're not going to tow something. Retrofitting the OEM electronics can get expensive, and the Stealth hitch by itself is more expensive than the OEM package if you can get it, at least when you're talking about the receiver and not the automated gooseneck version sold elsewhere. |
10-22-2021, 02:10 AM | #14 | |
Rep 127
But that won’t matter if the magnesium supply cut off comes to manifest… there won’t be new cars at all for a while LoL |
10-22-2021, 11:45 AM | #15 |
Rep 19
I got confirmation today from my dealer that the trailer hitch option was removed from their ordering system too.
Current BMW - '21 X7 M50i CB/Ex Merino Coffee Retired BMWs - '14 528i, '15 X5 35i, '17 X5 40e, ‘20 X5 M50i, ‘22 X5 45e |
10-22-2021, 11:48 AM | #16 | ||
Rep 65
Could you tell me where you bout the Stealth Hitch from? How much to install? |
10-22-2021, 12:17 PM | #17 | |
Rep 8,670
Drives: eVeRyOnE mAD!
install prices vary. can do an installer search on the site and also peruse this thread: Stealth Hitch https://g05.bimmerpost.com/forums/sh....php?t=1580904 |
10-22-2021, 02:27 PM | #18 | |
Rep 262
Me and several others are in this exact boat too and I "think" we are Ok. But, it does make me nervous! The other day, I attempted to ADD another option and my SA said, NO Changes can be made once Production status starts and VIN is locked. This would imply all parts are already qued up for the car. I just went into my garage multiple times to ensure it was showing still....
10-22-2021, 02:32 PM | #19 | |
Rep 512
My guess is the part supplier for the hitch assembly prob told BMW Manuf "hey guys...umm...so our latest shipment of hitches is still stuck on a container ship off the coast of Charleston and we're kinda effed right now" |
10-22-2021, 03:06 PM | #20 |
Rep 155
If you want to have fun, go play with the options on other country sites and you can see what you’re missing. If you go to Australia, for example, they get almost all options curently for a m50i, including air suspension, B&W, soft close, heated/cooled cup holders, full merino, anti dazzle exterior mirrors (I didn’t know this existed!), rear seat infotainment, display key, acoustic glass, luggage package, m seat belts, ambient air, night vision, M carbon mirror caps, Qi charger.
The list is pretty complete - almost every option. No 20” tires though, and you CAN get a tow hitch as of this morning. This has to be due to market size. BMW can get parts, just not in quantity. If you live in a smaller market, congrats, you are likely to get a much more kitted out BMW for a few years. ugh. |
10-22-2021, 03:54 PM | #21 | |
Rep 512
10-22-2021, 04:36 PM | #22 |
Rep 6,789
FWIW, factory cost isn't a big part of it. It's availability, and that plays into how big the market is along with the 'take' rate for that option or feature. Imagine what it would be like if the option was a randomly available item so one customer gets it, and the next is denied...really messy for customer satisfaction. Much easier to just decide not to offer it, and then, not get people bummed out if they order it, then find out it needs to be nixed.
If the situation resolves itself, people may be happy to get something they didn't expect, but it's quite the opposite if you order it then find out you can't get it later. |
