View Poll Results: what is a poll
something I don't know 3 100.00%
something I don't care about 0 0%
Voters: 3. You may not vote on this poll
      04-22-2024, 08:11 PM   #1
a320ron
Drives: 2021 x5
servicing transfer box
Trying to change the oil in the transfer box in my 2021 x5 40i, using the foxwell nt530, the oil temp shows 0.00 it needs to show over 20c. So it wont open the fill port. No faults on scanning. Any ideas.
      04-24-2024, 09:12 PM   #2
aerof16
Drives: 2017 540i
I did the same exact thing two weekends ago. My NT530 just kept reading 0.00 C. I eventually just bought some small diameter tubing and shoved it down in there. Was able to get about 550ml out of old fluid and put in a full 700ml of new fluid and called it good.
maher116.00
      04-28-2024, 09:44 AM   #3
maher
116
Drives: X5 40i
So you didn’t have to open the ports to get the 550ml out?
      04-28-2024, 08:35 PM   #4
aerof16
Drives: 2017 540i
No. There should be 700ml in there (that’s what the FSM calls for when refilling). I was able to get 550ml of that out but it wasn’t fun.
Something is directly in the way when you try and stick a hose in there to transfer the fluid out, so you have to have something sturdy enough and thin enough to snake down the case and get fluid out. Not sure if it’s any easier once you open those valves or if they’re just releasing more fluid.
I just called it good enough at 550ml, I’ll do it in another 50k.
maher116.00
      04-28-2024, 10:50 PM   #5
maher
116
Drives: X5 40i
No. There should be 700ml in there (that’s what the FSM calls for when refilling). I was able to get 500ml of that out but it wasn’t fun.
What kind of pump/tubing did you use?
      04-29-2024, 09:16 AM   #6
aerof16
Drives: 2017 540i
I always buy cheap one when I do fluid like this so I can just throw them away when I’m done instead of cleaning them haha.
I used the transfer pump to get the fluid out, then I like using the pumps that screw into the bottle to pump the fluid back in.
https://www.harborfreight.com/multi-...ump-63144.html
https://www.autozone.com/test-scan-a...B&gclsrc=aw.ds
maher116.00
      04-29-2024, 09:24 AM   #7
maher
116
Drives: X5 40i
Thank you! I’m on the verge of performing this oil change as well and would like to be as prepared as possible for that tight space.
      04-30-2024, 12:19 PM   #8
Alan l.
Alan l.'s Avatar
5507
Drives: 2020 F95 X5M Competition
Is it hard to reach under the car? I read some people said you need to reset the adaptation values after changing the fluid.
      05-11-2024, 04:34 PM   #9
g05x5b58
Drives: bmw x5
Same thing happened to me as well with the Foxwell scanner. It did not work so, I couldn’t manage to open the valve inside the transfer box.
But, it is very surprising for me to hear that you can get that much of an oil without doing so. Cause, when I did I could only get 50-100ml.
Then I used ISTA for opening the valves and doing the recalibration.
But, even after opening the valves, it is not the easiest task in the world as you said. There is not so much space to insert the tube and feels like something is on your way.
For calibration, as far as I feel, after the oil change recalibration is a very important and necessary step.
      05-11-2024, 09:42 PM   #10
aerof16
Drives: 2017 540i
One thing I did was use some small wire and bend it into shape as I fished it down into the transfer case. Then, I pulled the wire out and ran my tubing over the wire, so the tubing would take the shape of the wire and that made it slightly easier to guide the tubing down into the transfer case and get the fluid out.
