05-30-2020, 07:26 PM | #1 |
Rep 59
Tire pressure
Have 22inch summer Contis dealer installed on my M50i checked pressure today and it reads 40psi on front and backs. What is optimal pressure ? I mostly drive solo but occasionally with wife and 7 yr old.
05-30-2020, 10:33 PM | #2 | |
Rep 2,415
We use different metrics so can't help you with the figures It is also written in the manual. It is not included in the app version. It refers to the badge in the door. |
05-31-2020, 05:27 AM | #3 |
Rep 59
Thanks yes I did see that but my understanding was that those pressure numbers are for maximum load as I am the primary driver was wondering if there's a more optimal number
05-31-2020, 06:43 AM | #4 |
Rep 4,246
Found earlier and relevant questions on 22" and PSI:
Correct Tire Pressure https://g05.bimmerpost.com/forums/sh....php?t=1668176 Thread above for 22", 38-39F/45R for 5 passengers. You can lower depending on your comfort or less than 5 passenger load. For example, I'm running 33F/41R on 20" A/S. I wouldn't run 22" less than 36F/42R or equal pressures front and back.
05-31-2020, 11:40 AM | #5 |
Rep 2,415
05-31-2020, 04:43 PM | #6 |
Rep 59
Thanks doesn't show on my M50i maybe it's because it's a Canada based vehicle? Does anyone have a picture they could post showing the different pressure options for the 22s
05-31-2020, 08:30 PM | #7 |
Rep 4,436
Drives: 2022 iX xDrive50, DGM
Found this (I assume maximum cold inflation loaded):
06-01-2020, 03:13 AM | #8 |
Rep 2,415
This is the badge in my car. The lower values printed in italics are psi.
Three figures= normal Five = fully loaded These are the values for the 45e which has a 250 kg battery on the rear axel. I don't know if they would advise a different pressure for other engines. So your 40 psi seems quite high if you are driving alone on the 22 inch summers. I also added pictures from Idrive. I can chose the type of tires (bandensoort) winter vs summer and load (belading). And it displays this in the picture (vereiste druk) in this case 2.3 bar in front and 2.5 in the back Strange that the car doesn't follow the advise on the badge by the way. Both 0.1 bar higher. |
06-01-2020, 07:54 AM | #9 |
Rep 4,436
Recommended pressures are usually listed on a sticker inside the driver's side door. If not there, then the owners manual will have a chart, and BMW helpfully shows a chart in iDrive for OEM tires for a specific vehicle. Nothing wrong with using the loaded pressure recommendation as a starting point (you'll get better mileage, but a potentially harsher ride), and adjust down from there - underinflation is worse than oveinflation with respect to tire life, fuel economy, braking or acceleration. That's what I use, because sometimes the car is loaded, sometimes it's not, and my label doesn't even have a partially-loaded pressure recommendation:
Just never use the maximum inflation pressure listed on the sidewall as a guide - you're in dangerous territory if you're at or above that. |
06-01-2020, 08:40 AM | #10 | |
Rep 2,415
Do you live in Canada? Or do all cars in the us have English and French stickers? |
06-01-2020, 08:54 AM | #11 |
Rep 2,415
On my sticker you would need 35 psi in front and 38 psi in the rear for 22 inch driving alone. If you are ok with the comfort it should be fine if not you can lower it a bit.
06-01-2020, 09:22 AM | #12 | |
Rep 4,436
Nope, US. I think the default is bilingual for NA. The values for the door stickers are for maximum load if no other values are indicated in the US also |
06-01-2020, 09:57 AM | #13 | ||
Rep 2,415
I also have 20 inches but in Europe they are staggered 275 and 305. For me the best choose. I like the look and the comfort is good. |
06-01-2020, 10:32 AM | #14 | |
Rep 4,436
Paragraph S4.3 of FMVSS No. 110 requires manufacturers to affix a placard to each passenger car’s glove compartment door or an equally accessible location showing the vehicle’s capacity weight, designated seating capacity, the manufacturer’s recommended cold tire inflation pressure for maximum loaded vehicle weight, the manufacturer’s recommended tire size designation, and, for a vehicle equipped with a non- pneumatic spare tire assembly, the non- pneumatic identification code required by FMVSS No. 129, New Non- Pneumatic Tires for Passenger Cars. Most US cars manufactured since 2003 have the placard located on the driver's side door pillar, but it can be located elsewhere. Sounds like European regulatory requirements may be different, but as long as ranges are within manufacturing tolerances shouldn't matter. |
06-01-2020, 10:52 AM | #15 | ||
Rep 2,415
The only thing is that I have a 45e which is a heavier car. Maybe that can explain the difference. I don't know. I can't explain the difference either. |
06-01-2020, 12:29 PM | #16 |
Rep 4,436
It is confusing! Also noted that some of the recommended pressures on your sticker (I couldn't decipher whether for 20, 21 or 22 inch tires) exceed the max pressure recommended on the sidewall of my tires, but mine are squared vs staggered (20" Bridgestone, 44 psi). Probably the best bet for the X5 is to go by the OEM pressures for specific tires listed in iDrive in the TPM Reset menu.
06-01-2020, 12:59 PM | #17 | |
Rep 2,415
The sticker is a bit hard to read. |
06-01-2020, 02:38 PM | #18 |
Rep 4,436
06-12-2020, 12:46 PM | #19 |
Rep 242
My M50i also has the 22 inch with staggered pressures. I think it recommended 39 front and 44 rear in the idrive display menu. First car I ever owned that suggests different pressures for front and rear.
