07-08-2020, 12:21 PM | #1 |
Rep 294
Programming req'd for Crafted Clarity retrofit?
I was able to get a complete shifter/center console and radio with the crafted clarity crystal/glass components.
My question is can I install the new parts and have them work without and theft protection re-coding? If I swap and do need programming, will I still be able to drive the suv or should I get bmw dealer to install and program? Is it easier (or even possible) to just swap the crystal parts to my existing components? Has anyone done this swap? Looking for advise on how to upgrade/retrofit. Thanks!!!
Shawzy44
2023 BMW X3 M40i 2019 BMW X5 40iX 2019 BMW 440iX M Performance Cabriolet |
07-08-2020, 01:46 PM | #2 |
265
Rep 345
Drives: 2019 X5 40i M
I believe changing out the module requires complete reprogramming. The shifter itself is an easy switch. Once installed you have to add 4A2 to the FA and then VO code several modules to get the lights to work properly but it is easy. As far as the dial, Car Analysis sells an after market one that works with the Non clarity Module. They also make a start stop button that will work as well. Neither of the clarity versions will work on a non clarity module.
Good luck. JP
2019 X5 X40iM
Shawzy44158.00 |
07-08-2020, 01:46 PM | #3 |
Rep 133
I believe you can just install the parts, and add FA/VO S4A2 and code the BDC ECU to have the light on the shifter turn on. There was another post on this same retrofit, but I can't find it.
Hope this helps Armando This is the post: https://g05.bimmerpost.com/forums/sh...Clarity&page=5 Last edited by mandomedic122; 07-08-2020 at 01:53 PM.. Reason: added link |
Shawzy44158.00 |
07-08-2020, 07:29 PM | #4 |
265
Rep 345
It was me that posted how to do it and it was more than BDC. I went down the line until I hit the ECUs beginning with I and skipped DME
2019 X5 X40iM
Shawzy44158.00 |
07-23-2020, 07:54 AM | #5 |
Rep 294
I was able to get the OEM shifter coded so the X lights up.
Coded BDC and Gws2 module and voila! Thanks to all who offered advice along the way. The guys at https://www.codemybimmer.ca/ can code this easily for those requiring that service.
Shawzy44
07-23-2020, 02:06 PM | #6 | |
Rep 113
07-23-2020, 02:22 PM | #7 | ||
Rep 294
Shawzy44
1coolF15D201742.50 |
07-23-2020, 06:38 PM | #8 |
265
Rep 345
The arrows light up on the Car Analysis version available on Amazon. The OEM does not light up.
2019 X5 X40iM
10-16-2021, 05:31 PM | #9 | |
Rep 97
I understand that the shifter knob itself requires coding to allow the light on top to work, but do any of the other modules require coding or is it all plug and play? I have already sourced the shifter module and buttons, just looking to source the multimedia controller and would like to swap the whole lot, which I believe I need to do anyway to fit the OEM start stop button. I seemed too recall in one post a mention of the shifter itself being able to security immobilise the the car, so a replacement would need to be coded to allow the car too start, or did I mis-understand? Last edited by veearrsix; 10-16-2021 at 05:32 PM.. Reason: typo |
10-22-2021, 06:22 AM | #10 | ||
Rep 294
Shawzy44
10-22-2021, 07:21 AM | #11 |
Rep 8,650
Drives: eVeRyOnE mAD!
i believe coding with retrofit addresses the 'X' that lights up inside the gear selector, not its function
10-24-2021, 07:10 PM | #12 | |
Rep 294
Shawzy44
02-24-2022, 10:46 PM | #14 |
Rep 72
Hey guys, hoping to get some answer so can i use a oem glass shifter on a non glass equipped x5? Can i walk in to a dealer and even order one? The glass start and stop button can i buy a oem one from dealer and swap it over?
02-27-2022, 07:26 PM | #15 |
Rep 294
Shifter yes. Start/stop no.
Shawzy44
03-02-2022, 07:55 AM | #17 |
Rep 294
The button not a 1 to 1 replacement. The button is a different design and requires a different console. At least it was my experience on an X5 xline.
Shawzy44
06-08-2023, 08:52 AM | #18 |
Rep 12
For anyone looking to do this on their X5 or X7, beyond the "X" logo lighting up and changing from white to orange, the hill descent control may also not work. For cars equipped with air suspension, the ride height control will also not work (level will still change in Sport mode). The VO code fixes it all. I didn't want to mess with VO coding so had the dealer code for me for $300 ish.
