08-01-2020, 11:29 AM | #2 |
Rep 4,246
I'm not aware if anyone has tried yet and you'd be the first, since the F95 and parts aren't up on at least two of the online catalogs - RealOEM and Bimmercat.
Most likely it should fit if the trim openings are the same. The X5M F95 air duct side trim are a bit longer but follow the same surfacing as G05 X5.
08-01-2020, 11:34 AM | #3 |
Rep 457
No no no no no! Even if it does fit leave it alone. Nothing worse than M parts added to non-Ms. Ruins an otherwise loverly car in its own right.
12
stein_325i25073.50 Thawke163.50 bmr760139.00 Luminor5131243.00 codex57214.00 Russ103308.00 iconoclast7262.50 BMWFLYNN54.00 volodp196.50 eelnoraa2016.00 Llarry15407.50 Bottom1615.50 |
08-04-2020, 06:12 PM | #4 |
Rep 279
Drives: 2023 BMW X5 M Competition
Yes they fit. I purchased from ind-distribution and installed myself. They look so much better than the stock side grilles. I removed the x5 ///m badge but don't pay any attention to what those people say about it being a non-m. it's your vehicle, you bought it, do what you want to it.
tvasica70.50 IftiBashir108.50 ed41367.50 Cure4All2cX53.50 CT335xi684.00 X3rd Time Is a Charm2783.00 AndyWR0.00 |
08-04-2020, 07:42 PM | #5 | |
Rep 8,801
08-04-2020, 08:25 PM | #6 | |
Rep 4,246
Similar to the G01 X3/4, there's an actual hole there. You'll need to pop 3 clamps at the points indicated. View of OEM G05 Side Air Duct Vent Trim from back BMW G05 51 13 045 Removing and installing/replacing front side panel trim on left or right https://www.newtis.info/tisv2/a/en/g...rip/1VndRegBtG Visual example - X3 side vent trim removed showing hole in front quarter panel
GlennC321.00 |
08-05-2020, 07:55 AM | #7 | |
Rep 158
08-07-2020, 06:03 AM | #8 | ||
Rep 23
Pictures would be awesome. Same for the X5M front grill you installed and mentioned on another thread. Thanks! |
08-08-2020, 02:50 PM | #11 |
Rep 195
Now I know I may take some heat for installing these on my Carbon Black 2020 X5 M50i but I think they look great and fit perfectly. 5 minute install. I may remove the X5M label. Wanted to ensure they fit first.
9
tvasica70.50 mnavis295.50 pavloPL54.50 Russ103308.00 Mtn2Srf276.00 Cooltones241.00 Cure4All2cX53.50 AndyWR0.00 username_mi_los0.00 |
08-08-2020, 07:08 PM | #15 |
150
Rep 365
In the UK, people who impersonate M cars on non M cars have a very special name...
Absolutely nothing wrong with the vents, not my taste personally. I have horn style M mirror caps on mine, but please, remove the X5M badges |
codex57214.00 |
08-08-2020, 08:12 PM | #16 |
Rep 195
Since I have already said that is my plan twice already now I'm not sure why you found your post necessary especially the first sentence. If you want to call me a name, go ahead dude, whatever....
Apex Missing Ape103.50 |
08-08-2020, 10:49 PM | #17 |
Driver
161
Rep 447
Elitism at its best? Come on people, let’s be positive. Does it hurt anyone to put M parts on non-M cars? Does doing so somehow reduce the value of someone’s X5M? I didn’t think so, so what’s the problem. What does it matter? Honestly, from some of the reactions you see, you’d think that someone modifying their car with an oem part from a more expensive version caused physical harm to others.
If you’re in the camp that one should not modify one’s car to look like something it’s not, I hope you’re also in the camp where you don’t tint windows, fit aftermarket wheels or spacers, etc. Otherwise I cannot begin to understand the hypocrisy. This is a forum for people who own and love the cars, isn’t it? |
9
tvasica70.50 GlennC321.00 KrisV208.00 Bambazonke210.00 VetteZ0662.50 mandomedic12240.50 KRS_SN13430.00 Cooltones241.00 AndyWR0.00 |
08-09-2020, 01:52 AM | #19 |
The Dark Knight
418
Rep 1,260
I am also interested to know where did you buy the vents from and where to get the decal you are considering
GlennC321.00 Cure4All2cX53.50 |
08-09-2020, 05:20 AM | #20 | |
Rep 195
PS - Interestingly, unless one is looking at the vent at eye level from within a foot or two away, one cannot even see the "X5 M" on the vent because it's black. It's really just the stripes that are clearly visible. Having said that, I will be giving it a go to remove them anyway. Last edited by GlennC; 08-09-2020 at 05:28 AM.. |
08-09-2020, 07:35 AM | #21 | ||
Rep 279
GlennC321.00 |
08-09-2020, 10:46 PM | #22 |
The Dark Knight
418
Rep 1,260
Are you saying that's the price on IND? Are you referring to the prices that you mentioned as per piece or a set of 2? IND is at $395 + shipping -
The fact that they charge shipping for such a high priced item in this day and age is unfathomable but that's another topic for another day! |
