08-03-2020, 06:15 AM | #1 |
S65 FTW!!!
59
Rep 285
Drives: 2011 E90 BMW M3 Silverstone
Poor wet traction?
Recently took the m50i with stock 22 oem tires through some rain; it was not confidence inspiring; def lost some grip and hydroplaned a few times; I’m not talking a heavy rainfall either; anyone else have grip issues with the stock Conti summer tires? I usually find Contis to be solid but now thinking of a new set
08-03-2020, 07:38 AM | #3 |
Rep 457
You must have been mashing the throttle hard as my M50i on 22's sticks to the road like glue in the wet. Was saying only yesterday that I can hammer it now in scenarios where my M4 would have killed me behaving the same.
08-03-2020, 07:40 AM | #4 |
S65 FTW!!!
59
Rep 285
Doing 50-70 mph; hydroplaning during coasting; not even pushing it hard
08-03-2020, 08:02 AM | #5 | |
Rep 4,246
New tires should be driven a few hundred miles on dry roads to rid the tread of parting agents and antioxidants applied during production. When tires are cured, a release lubricant is applied to prevent the tires from sticking to the mold. By driving on the tires for a few hundred miles, these lubricants will wear off and allow the tire components to begin working together.
08-03-2020, 08:46 AM | #7 | |
161
Rep 342
Drives: 2019 BMW M760li
08-03-2020, 08:50 AM | #8 |
Rep 236
The premium contact 6 were rated about 6th in the wet with auto express. There is a video on you tube comparing wet handling down to 0,C and the con tis were much better than nearly all the winter tyres on test. In snow it was obviously very different, but the con tis are normally quite good.
08-03-2020, 09:17 AM | #9 |
PANIC!
482
Rep 823
It's because BMW chooses such a wide tire, especially in the rear. Wider tires are just more prone to hydroplaning because there is more surface area of the tire contact patch, which means there is more water that has to be displaced (and hence, more prone to hydroplaning).
08-03-2020, 09:38 AM | #10 | |
S65 FTW!!!
59
Rep 285
08-03-2020, 09:41 AM | #11 |
S65 FTW!!!
59
Rep 285
08-03-2020, 09:42 AM | #12 | |
S65 FTW!!!
59
Rep 285
08-03-2020, 09:45 AM | #13 | |
S65 FTW!!!
59
Rep 285
08-03-2020, 09:54 AM | #14 | |
Rep 4,246
Also as other forum members have mentioned above, the combination of high speed, new tires and wider rear contact patch will contribute to the uneasy sensation of hydroplaning. Go easy and safe driving!
08-03-2020, 11:45 AM | #15 |
Rep 3,507
If the road has pour drainage no tire matters too....
2022 M8 Comp Convertible
08-03-2020, 01:40 PM | #16 | |
Driver
163
Rep 447
I think it more likely that the tires aren’t worn in or that BMW did not choose tires that deal well with wet weather. |
Tenac4538.50 |
08-03-2020, 03:06 PM | #17 |
PANIC!
482
Rep 823
08-03-2020, 04:05 PM | #18 | |
Rep 1,147
Frenetic482.00 |
08-04-2020, 07:06 AM | #19 |
42
Rep 105
08-04-2020, 07:07 AM | #20 | |
42
Rep 105
THIS! |
08-04-2020, 07:46 AM | #21 |
Rep 112
More likely to be the road surface than the tires. Sometimes the very worst traction is light rain on a road that’s been dry for a bit. Brings all the oil to the surface.
