      08-30-2023, 09:43 AM   #1
FatHulk
FatHulk's Avatar
128
Drives: F82 M4 zcp, G05 x40i
2019 X5 40i 20" set up question
Looking for some advice or info on a square set up for winter.
Know this has been talked about quite extensively but just thought if anyone knows I can get a quick answer
Have a 2019 X5 40i with msport brakes
Currently have 742M wheels and looking to get a winter set
Wondering if I can go square with a 20x9.5 offset +25
Load rating 690 Kg/ 1521 Lbs
Tires 275/45R/20
https://www.superspeedwheels.com/flowform-rf05rr
It seems like it would be okay without spacers but let me know if anyone has some insight
Thanks!
      08-30-2023, 11:22 AM   #2
Matt 335is
Matt 335is's Avatar
646
Drives: SMB 50e | e92 n54
Tires 275/45R/20
Thanks!
Yes, those would work, here is how they would compare to your current setup with the 742M wheels...
Front = 12.0mm further out
Rear = 5.3mm further out
You could put something like 10-15mm spacers on the rear for better appearance.
FatHulk127.50
      08-30-2023, 11:47 AM   #3
FatHulk
FatHulk's Avatar
128
Thanks appreciate the response!
