10-20-2023, 04:00 AM | #1 |
RichyX5
Rep 4
BMW X5 E53 2006 Battery drain
Hi Everyone, thanks for the add
My first post My car was all okay for a year, has a near brand new battery It now goes flat after 2 weeks, so I hooked up amp meter to the negative terminal off battery and to the negative battery post Draws 5.3 amps initially then something goes into sleep mode and drops to 3.3 amps I traced to the panoramic sunroof fuse 58 without this fuse only draws 0.3 amps But the drain isn't on the feed in side it's actually after the sunroof ecu on the pale brown wire next to the red / green strip wire ( the 2 thickest wires) I have headlining and seats out atm so thought I'd try to track down The pale brown wire looks like it goes down the Right hand Drivers side A pillar, I found a wire that goes under the seat to somewhere but I'm really not sure if it goes anywhere else or if its the same wire. Can pull all other fuses out and it doesn't make any difference on Amp draw Hope someone can help me trace it Last edited by X5Richy; 10-23-2023 at 05:03 PM.. |
10-20-2023, 05:54 AM | #2 |
Rep 8,698
Drives: eVeRyOnE mAD!
X5Richy hi and welcome. note that you posted in the X5 G05 forum (2019 to present). may get better help in the appropriate forum year. good luck
10-20-2023, 04:07 PM | #3 |
RichyX5
Rep 4
Hi nZtiZia
I can't navigate to that section, up the top it only shows G05/GO6 then previous versions of F15/F16 and below that E70 E71 E72 so there is no E53 that i can find, Am i missing something Ill have a look at the E70 i suppose that's the closest, Thank you |
10-21-2023, 06:56 PM | #4 | |
257
Rep 332
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024) |
