03-07-2023, 09:56 AM | #1 |
Rep 112
Integrated Universal Remote Control
Hey guys,
I have question about an add-on called "Integrated Universal Remote Control" for garage and garden door. Searched the forum but couldn't find much. Does anyone has it in their X5s? How is your experience in terms of: 1. Its usability 2. Range 3. Compatibility with Major garage door lock manufacturer? Also feel free to mention if you have faced any issues? Thanks in advance! |
03-07-2023, 10:28 AM | #2 |
Rep 8
I have it on my '22 45e and works fine with our garage doors. Not sure of the exact range, but I usually press the open button on the bottom of the rearview mirror 2-3 houses away, so I would estimate a range of 100-150 feet (could be longer but I've never tried). The garage door opener I use it with is a Liftmaster at home and an Overhead Door one at the lake (you can link up to 3 doors/gates).
MadMaxed72.50 |
03-07-2023, 10:38 AM | #3 | |
Rep 163
I also have it on my 45e and is way more convenient than searching for the remote in the car. |
MadMaxed72.50 |
03-07-2023, 12:48 PM | #4 |
Rep 104
Drives: 2021 x5 45e
Has it on my 21’ 45e
1. Its usability Very convenient, use it every day. All you need to do is following the instruction and pairing the device 2. Range I usually use it at about 100 ft distance from my garage door 3. Compatibility I paired it with Liftmaster remote and it works fine
2021 BMW X5 XDrive45e (G05) Phytonic Blue Metallic / Coffee Merino Leather
2017 BMW X4 XDrive20i (F26) Jet Black / Coffee Nevada Leather 2015 Ford Mustang Ecoboost Preimum (S550) Ebony (Retired) |
MadMaxed72.50 |
03-07-2023, 01:01 PM | #5 |
Rep 6,805
The pairing instructions didn't seem to be the greatest, but once I got it to work, it was and has been fine.
Just as an aside, when you sell the vehicle, remember to clear that, along with all of your personal information that's stored in iDrive like your addresses, contacts, etc. |
03-07-2023, 03:13 PM | #6 |
Rep 1,075
I use the garage door / homelink receiver on my 45e and it works pretty good. Much better than keeping another garage door opener in the car, might as well use what's integrated in the vehicle. Range can be a bit hit or miss if I'm backing the car in, but it'll still open so long I'm near enough.
Here's a vid of configuring it in case you need it: |
MadMaxed72.50 |
03-07-2023, 07:41 PM | #7 |
Rep 8,696
Drives: eVeRyOnE mAD!
MY21 45e
1) i use it everyday even though i have the original remote 2) range is well over 100 feet as i activate it when entering our cul-de-sac 3) paired with a proprietary garage opener that's HomeLink compatible. easy programming. no issues. |
MadMaxed72.50 |
03-07-2023, 08:08 PM | #8 | |
Rep 3,681
2022 G05 B58/PHEV
+ a few very old BMWs |
MadMaxed72.50 |
03-07-2023, 08:46 PM | #9 |
Rep 849
Drives: BMW Z4 M40i, BMW X5x40i
They work well. The newer Security+ 2.0 openers are a bit more finicky than the older ones. When I had to replace my GDO last year I could definitely tell the difference. They have less range than the older models and it takes a bit longer for it to work. Occasionally it takes a second punch of the button to operate the door.
I have them in most of my cars over the last 10-15 years and find it annoying that my truck doesn't have it. So there's a remote in it. That sometimes gives me a bit of concern, because if someone breaks into the truck they can use the remote to get in the garage. With the integrated remote, it doesn't work if the car isn't running. A valuable safety feature if you ever park it outside. Gerry
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
MadMaxed72.50 |
03-07-2023, 09:08 PM | #10 | |
Rep 849
The only compatibility "issue" people have is one that doesn't apply to newer cars like the G05. About 10-12 years ago, they switched to a new protocol, Security+ 2.0 (round yellow learn button). Homelink universal openers designed for the older Security+ (purple, yellow, or green learn buttons) won't work with the newer openers using Security+ 2.0. Newer Homelink openers will work with both. If you have a vintage Exx chassis BMW (like my E89 Z4), it won't work directly with Security+ 2.0 openers. You have to buy a Homelink repeater and plug it in an outlet in your garage. You then program the car to the repeater and the repeater to the opener. And if you have a really old opener that uses dip switches to set the code, you're SOL. Gerry
MadMaxed72.50 |
03-08-2023, 06:06 AM | #11 |
Rep 96
Drives: BMW - 2023 X5 40i
I have it and it works well with the garage door openers that I have.
With one door opener brand, Liftmaster it was quick and easy to program. With a Genie opener it was a little tricky to set up, having to use both the remote and programming button on the opener to set it up. But with both openers it works well from a good distance, probably at least 80-100 feet, between the opener and the car. |
MadMaxed72.50 |
03-08-2023, 07:01 AM | #12 | |
Rep 8,696
03-08-2023, 07:24 AM | #13 | |
Rep 112
This means I wont be able to replace them just in case they create an interference. |
03-08-2023, 07:27 AM | #15 | |
Rep 112
03-08-2023, 10:14 AM | #16 |
Rep 1,302
I was hoping I could add this option on my new 50e I ordered. But the dealer said my garage door isn't listed on the Homelink website so it probably won't work.
My garage door installer said it sometimes won't work with every car brand. Too bad because we installed a new garage door 2 years ago. It's a Select-Line (Berger?), 868 Mhz. Maybe some obscure brand that isn't listed? Could it be possible that it works or will it definitely not work when it's not listed on Homelink? I could still add this option but if it doesn't work this would be pointless. Some ideas if I should take the risk of taking that option or will it be waste of money. |
03-08-2023, 09:52 PM | #17 |
Rep 1,354
Drives: 2022 X5 m50i
Using with Liftmaster w/o problems. My Driveway is about 150 feet and sloped. I hit it at the gate and have no issues. Any further, works intermittently, especially when there are trees in between the car and the garage door. The only issue I had was that I could not pair with an older model Liftmaster at the office.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
MadMaxed72.50 |
03-08-2023, 10:35 PM | #18 |
Rep 6,805
You can get an idea of compatibility by the color of the LED used on the opener.
https://support.partner.liftmaster.c...earn%20buttons. |
03-08-2023, 11:18 PM | #20 | |
Rep 3,681
03-09-2023, 08:28 AM | #21 | |
Rep 539
But I did put LED lights in the opener box about the same time I got the car. The other lights in the garage are CFLs that have been there forever. I'll swap the LEDs out today to see if it improves. |
MadMaxed72.50 |
03-09-2023, 08:38 AM | #22 |
Rep 114
I have a 23 45e, and use this feature daily. One button controls my Chamberlain door, and the other controls the Liftmaster door at a family member's house. I hit the button when I'm two or three houses away from my house and it works great.
This is my 4th or 5th car with this kind of feature, and I found it easiest of the bunch to program. Range is as good as any of the other vehicles I've had. It's a very nice feature. |
MadMaxed72.50 |
Tags |
garage, garage door, integrated remote control |
