02-06-2020, 08:46 AM | #1 |
Rep 210
Excited for the car to arrive...BUT...one concern...
Currently driving a 2014 vehicle and i realize tech has jumped a long way since then, but surprised to see the issues people have in simply playing music. i think i've read pretty much every post here and can't believe the histrionics people have to go thru to get their music to play. reformatting this, resetting that, etc.
the other thing i've noticed is that what works for one person doens't work for someone else. it seems as though idrive 6 was better than 7? I prefer to use one device and just keep it in the car. I'm guessing i shouldn't even bother trying to get my old ipod classic with it's 30 pin connector to work lol? |
02-06-2020, 09:01 AM | #2 |
1053
Rep 1,952
I've had the car for about a month. There were some minor issues getting car play to connect consistently. I simply removed the car from my phone bluetooth and car play and did the same from the car. Started from scratch and it has worked flawlessly since then. There has been some minor things, but nothing consistently wrong. Most of the issue at first were just part of the learning curve.
My music setup is as follows - iPhone connected wireless carplay - play Amazon HD and Spotify with no issues || Micro USB drive in the USB-A port with about 40 GB of music on it. Works like a charm. No issues with that setup currently. I did have an issue with the USB drive not picking up a song where I left off when I shut the car down. I simply just bought a different USB drive (brand) and now it works great. |
02-06-2020, 09:33 AM | #3 |
Rep 210
Good to hear and thanks for the info. I would prefer to go connected/wired rather than bluetooth so happy to hear USB drive is working for you.
Any chance you think my old ipod classic (the one with the wheel lol) would work with a 30 pin to usb adapter? or should i just start transferring my library now |
02-06-2020, 09:43 AM | #4 | |
1053
Rep 1,952
02-06-2020, 09:54 AM | #5 | |
Rep 1,075
A lot of the stuff you reading here - is user errors and people learning how to use features. I have had the car for more than a year - and nothing but smiles. For USB - try iPod Classic to car's USB port - 30-pin cable from iPod dock connector to USB port on car. Car stereo input mode is USB It should work if it recognizes that as storage. But might be easier to transfer music to a USB 3.0 - faster and smaller I have a tiny 128 GB device with all my HD music on it and it sounds great on regular HK system. |
02-06-2020, 11:03 AM | #7 |
Rick James
305
Rep 784
It might be user error, but when a good majority of people are having issues, it is something BMW needs to fix. tellch00 there are bugs with every release. This is on par with using beta software. It works, but it doesn't seem polished. The car drives well, music (for the most part) play, and there's plenty of other intricacies you will learn. Ilyam5 is correct that there's a learning curve, but coming from iDrive 6, you should have an easier time than someone who has never used iDrive.
If you can just be ok with the fact that you may or may not have the latest software and/or features...you'll be fine. My only piece of advice, other than this forum, your best friend will be the power knob. I would practice holding in a button for 30 seconds. Then, you'll be ready to go! Overall, love the vehicle though, but have to give BMW a hard time given the price tag and (minor) shortcomings. |
02-06-2020, 11:27 AM | #8 | |
Rep 198
Are you referring to hard reset of idrive7? If it is a hard reset, does it mean all customizations and settings are lost? Or is it just a soft reset. |
02-06-2020, 11:43 AM | #9 |
Rick James
305
Rep 784
I don't know what you would want to call it exactly? It's a hard reset, but you keep all your settings. I think the software gets goofed up sometimes and you need to do it every now and then. I mostly noticed it when using my phone to stream music. However, with the Spotify streaming directly to the car now...it's PERFECT!
02-06-2020, 12:12 PM | #10 | |
Rep 116
Drives: 2024 X5 50e LCI
02-06-2020, 12:49 PM | #11 |
Rick James
305
Rep 784
USB interfaces:
• Type A in the center console, max 1.5 A charging, capable of charging and data transfer. • Type C in the center armrest, max 3 A charging, capable of charging and data transfer. • Type C charging only 2x in the backrests, max 1.5 A charging, capable of charging only. Doesn't appear to be any information on transfer speeds that I can see, but I think Ilyam5 was referring to using the type c for transferring. I'll bet that the USB Type B is a 3.0, as that seems to be the norm these days. My friend's 2019 Ford takes a 3.0 drive, so I think it's safe to say BMW would be on par. |
02-06-2020, 11:00 PM | #12 | |
805
Rep 1,790
On a computer you can tell if the port is USB 3.0 vs previous versions by the color of the blade on the port. Blue indicates 3.0. Additionally, the symbol for USB 3.0 and previous versions are different. See the following link for a down and dirty picture of the two symbols. https://www.addictivetips.com/window...-next-to-them/. If you want even more information on USB take a look here. https://www.intel.com/content/www/us...fications.html |
randybobandy304.50 |
02-07-2020, 12:02 AM | #13 |
Rep 88
Dont worry about randy’s comments he’s very upset about his car and BMW . I’ve used iDrive reset once and only because I wanted to check how it works.
02-07-2020, 04:59 AM | #14 | |
Rick James
305
Rep 784
I understand that, but can we for sure say that it is or isn’t in either vehicle? Without plugging into the vehicles and testing, it is tough to determine. At the end of the day, in the X5 at least, it’s probably safe to assume the USB C up front will it bout a doubt give you the fastest transfer speed. How much more would it cost to put 3.0 vs 2.0 in these cars? I just never take notice, since I only use the ports for charging, which is rare given the mat. Good info on the links! |
02-07-2020, 05:01 AM | #15 |
Rick James
305
Rep 784
02-07-2020, 11:37 AM | #16 | |
Rep 198
I am thinking a re-install if the OS er.. CarOS if I may say so might help? ( sorry, apple fan boy here) |
02-07-2020, 12:29 PM | #17 |
Rick James
305
Rep 784
I think the only problem with too much tech (phone, car, etc) is do we need it? Nope. Is it awesome? Yes.
As vehicles get more and more features, there's more to go wrong as far as these creature comfort features. Everyone is playing catch up and one-upping each other. I made fun of the fan-boys for loving their analog gauges, but maybe they're on to something? Nah, imma stick with my tech and complain lol. |
02-07-2020, 09:38 PM | #18 | |
805
Rep 1,790
I will do some research and see if I can find what's in the 2019 X5 as well as my 2020 X7. |
02-08-2020, 07:49 AM | #19 |
Rick James
305
Rep 784
mitch57 never knew what the "SS" was for, so it makes sense now. I only use the USB-C, and given that I have the MBP with Thunderbolt 3 only, I had to get a dongle (shocker from Apple). I just use the dongle with a thumb drive if I have to. All we need now is apple to put usb-c on their iPhones and all the iPads, not just pro. Lucky for the Europeans going after apple for changing their chargers versus universal.
Other than music, what are people using the USB port for in relation to data not charging? |
02-09-2020, 01:18 PM | #20 | |
805
Rep 1,790
02-09-2020, 01:21 PM | #21 | |
Rick James
305
Rep 784
02-09-2020, 01:35 PM | #22 |
Big Beaver Smile
2101
Rep 3,791
I've done exactly what you do since 2004 and left an iPod with all of my music in the car. I was kind of bummed when it wouldn't work the way it always did, there were so many glitches.
Now, I get in my car, hit Apple play and all the same songs that were on my iPod and are also on my iPhone are there and just start playing seamlessly. If I want to create a station from Apple Music, it's 2 hits of a touch screen. My phone never leaves my pocket, it's like magic. After letting go of the old ways, I don't look back or miss the old way one bit.
