02-09-2020, 01:57 PM | #23 | |
805
Rep 1,790
"USB 3.2 is not USB Type-CŪ, USB Standard-A, Micro-USB, or any other USB cable or connector." |
02-09-2020, 04:28 PM | #24 |
Rep 210
For those that transferred your itunes library to a USB stick, do you have to do any conversion to the songs? I believe itunes is AAC. do i have to convert everything to MP3 for it to work?
02-10-2020, 05:32 AM | #25 |
Rick James
305
Rep 784
Hmm. I guess I live in a land of unicorns and rainbows. I thought the whole point of USB Type C was faster transfer speeds? I know they didn’t go with fast charging, but seems like they screwed the pooch if the data transfer speed isn’t quicker.
Edit: Isn’t at USB-C at least 3.1? I really wish there was more technical specs in the owner’s manual. I scoured the tech documents, and they don’t go into any depth either. I’m sticking to wireless everything! |
02-10-2020, 06:55 AM | #26 | |
Rep 4,246
The other point of transitioning to Type-C connectors is for more compact ports (1/3 of the size of old Type-A connector) and reversible connections. Type-C also supports a variety of different protocols which can output HDMI, DisplayPort, VGA, and audio.
02-10-2020, 05:19 PM | #27 |
Rep 202
Drives: BMW X5
I just hooked up my iPod Classic to the USB port on the center console, and it appears to be working fine, although I will further test it on my way home from this meeting. It even shows up in the heads up display as a choice.
02-10-2020, 06:33 PM | #28 |
Rep 210
ipod classic with the 30 pin connection? what adapter cable did you use?
02-10-2020, 08:33 PM | #29 |
Rep 202
Drives: BMW X5
This iPod came with as 30 pin cable. The 30-pin in fits in the iPod. The other end is a standard USB2 connector, which plugs into a charger (or into the BMW front center console - between the cup holders.). It would be handier if there was a UBB2 port in the storage area between the front seats.
