      02-10-2020, 05:12 PM   #1
OzJedi
Australia
25
Drives: X5 2019 40i MSport Carb Black
Recommended Tyre Pressure
I am always confused at Gas station while inflating my tyres to right amount of air. There are recommended settings on the driver side door but there also settings on tyres itself which are different from the one on door.
I have 22 inches
Front : 275/35 R22 Y XL
Rear : 315/30 R22 Y XL
Any help in this regards will be much appreciated.
      02-10-2020, 05:23 PM   #2
ifr
Drives: BMW X5
I think there is an idrive menu option (TPMS bit) which allows you to configure the tyre config, winter/summer, size and if comfort or load is preferred.
It then makes some recommendations on the inflation.
OzJedi25.00
      02-10-2020, 05:26 PM   #3
OzJedi
Australia
25
Thanks! I haven't opted for TPM feature so don't have this option sadly.
      02-10-2020, 05:35 PM   #4
Paladin1
Paladin1's Avatar
Drives: 2020 X5 40i M Sport, Arctic Gr
2020 X5 M Sport  [0.00]
The settings on the door are the maximum recommended pressures for the OEM tires with the maximum recommended load in the car. The pressure on the tire is the maximum safe pressure for the tire itself, which will be higher than the door sticker.
OzJedi25.00
      02-10-2020, 05:36 PM   #5
Resjudicata
Drives: M850i convertible
Dealership
I've been told by both dealership near me to use the door jam psi.
OzJedi25.00
      02-10-2020, 06:43 PM   #6
MystroX5
MystroX5's Avatar
2402
Drives: 2019 M2 Comp, X5 50M-Sport
Door Jam.
OzJedi25.00
Copyright ©2000 - 2020, vBulletin Solutions Inc.
