      02-14-2020, 01:34 AM   #1
Ninefourteener
Ninefourteener's Avatar
1340
Drives: 2020 X5 M50i, 2020 Alfa 4C
Locking doors while car is running
Only day 3 with the car. I'm sure there is a setting or something.... Still learning all the features/settings.
I don't have BMW connected features in Europe, on a US spec car. So, I can't connect with my phone, download apps, etc. Just a part of being in Europe I guess.
Every morning, I go out and start my car to let it warm up in the driveway. Then, I get out and go back in the house. If I try to lock the doors, the car gives off two loud HONKS.... at 7am.... and I'm pretty sure the neighbors don't like it.
Is there any way I can lock the car from the outside, while it's running..... with just a simple "beep" sound?? If the car is off, it just gives a beep when I lock it. Why does it HONK when it's running?
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      02-14-2020, 02:50 AM   #2
six
Drives: G05 X5 50e
It’s a more recent ‘feature’ on BMWs with comfort access, to stop you accidentally leaving the engine running when you lock and walk away from the car. I’ve coded it off on my other cars busing Bimmercode but the app doesn’t support the X5 yet for this particular feature.
So what you can do it physically hold the key fob on the glass of the front screen then press the lock button. This way the car seems to think the key is within the car and locks the doors without the honk. Give it a try, works all the time for me a saves irritating neighbours on cold mornings!
Appreciate 4
AshD100.50
thereef5101164.00
      02-14-2020, 06:00 AM   #3
Resjudicata
Resjudicata's Avatar
Drives: M850i convertible
you need to use remote start or get bimmercode or have someone code it off for you.
      02-14-2020, 06:53 AM   #4
Tenac
Tenac's Avatar
4537
Drives: All
If you press the lock button three times do you not get remote start??
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      02-19-2020, 05:19 AM   #5
Ninefourteener
1340
I haven't even tried. Hmmm. Didn't even know that was an option.
Crappy BMW "genius" spent a whopping 15 minutes with me.... half of that time was me teaching HER how to adjust the ambient lighting colors, because she's never seen it.
      02-19-2020, 08:56 AM   #6
X5 45e
1091
Drives: BMW X5 45e
I had the same with my genius. I explained him how to install the ambient air cartridges and where they are located.
I think they basically only know how to create a connected drive account and how to pair with the car. And even that didn't work. Had to call CD helpdesk.
I wonder if any geniuses are frequently visiting this forum. Should be a great help for them.
      02-19-2020, 09:05 AM   #7
thereef510
thereef510's Avatar
Drives: '16 X5 35i, '20 X5 40i
the guys at the PCD know what they're doing. My mom had a primary CD account which I was using on my phoen with her login which didn't matter on the f15 but you need separate logins for the g05. He quickly showed me how to set up a secondary CD account. He knew everything I asked him, I was pretty impressed with his depth of knowledge.
      02-20-2020, 01:48 PM   #8
Tdot F30
Tdot F30's Avatar
Drives: G05 & F31
I thank you and my neighbours thank you!
      02-20-2020, 01:55 PM   #9
sygazelle
Drives: 2014 328i M-Sport, 2019 X5 40i
I hope you figure it out.
Question: Why are you warming up your G05? Is it for your comfort or do you think the engine needs it?
      02-21-2020, 04:50 AM   #10
Ninefourteener
1340
No, its for me. It's cold in the mornings.
      02-21-2020, 07:56 AM   #11
VTENGR
1053
Maybe this has something to do with ASS, but when I leave my car while it's running, with the FOB in my pocket, when I come back the car is off.
      02-21-2020, 08:14 AM   #12
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
Me being the dumb ass I am...I decided to leave the car running and taking the FOB with me instead of doing remote start. Not even 2 mins, my alarm kept going off. I stopped it, but 10 seconds later...boom.
I had no idea there was a motion alarm inside, but once the vehicle shuts off...it seems to activate. I just remote start and let it be now.
      02-21-2020, 12:32 PM   #13
Ninefourteener
1340
Vtengr and randy..... neither is the case for me. I do need to go out and try the remote start though. If that works, it will no longet be an issue.
Will it remember the last heat and seat heater settings?
      02-21-2020, 12:36 PM   #14
VTENGR
1053
Heat - yes, seat heater no. However when I remote start, and its cold outside, my steering wheel and seats are warm by the time I get in.
      05-25-2022, 04:15 PM   #15
Himaia_M5
Himaia_M5's Avatar
12
Drives: 2015 F10 M5 CP
It's a more recent 'feature' on BMWs with comfort access, to stop you accidentally leaving the engine running when you lock and walk away from the car. I've coded it off on my other cars busing Bimmercode but the app doesn't support the X5 yet for this particular feature.
What exactly did you code off? I'm having the same issue with my F90, when I had my F10 I was able to keep it in park or neutral with the parking brake on and lock the car with no issues. This is new to me lol
      05-25-2022, 07:34 PM   #16
jad03060
Drives: X5 45e
There are some rules you can set to turn the seat heaters on along with the steering wheel and the ventilated seats. They have temperature limits, so you can have it only turn the seat heaters on when the temp is below a certain point that you can adjust.
      05-26-2022, 09:55 AM   #17
10101X5
10101X5's Avatar
465
Drives: 10101X101
I remember once you started driving, you need to be inside to lock it. That trick on the glass may work. Some cars let you lock when you use the physical key and lock it. Haven't tried on G05. I personally would not want the car to give me this option. It's not safe imo. On the other hand, if you have not driven yet, you could use remote start. Once started, you can go in, go out, lock, and the car is still happy running. Just don't press "Start" until you're ready to go.
      05-26-2022, 11:28 AM   #18
elite-fusion
Drives: 335xi
I think this feature would be great. For me, in NY, if I ordered take out for pickup, I can leave the car running while going inside to pick up the food. NY is not the safest, so ideally, I'd like to lock the car for the 30 seconds that I am in there to pay or whatever, while its still running.
      05-26-2022, 11:43 AM   #19
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
I have a U.S. MY21 45e. It does not require any coding to allow me to lock the vehicle after exiting it with the ICE running. in fact, it confirms with 2 beeps of the horn.
      05-26-2022, 01:50 PM   #20
jad03060
Drives: X5 45e
This is one of the beauties of the 45e...all HVAC functions are electrical, so no need to keep the 'engine' running...there's a menu option to tell it to stay on that pops up when you shut down to keep that going.
      05-26-2022, 01:52 PM   #21
nZtiZia
nZtiZia's Avatar
i agree. i just mentioned this to demonstrate it can lock while the engine is running (dunno about dedicated ICE cars)
      05-27-2022, 08:05 AM   #22
10101X5
10101X5's Avatar
465
Drives: 10101X101
ICE can lock too. That's not the issue. The issue is it honks.
