      02-21-2020, 09:30 AM   #1
RJJJ
Drives: 2020 BMW X6 M50i
Hi guys, picked my car last month and noticed the m sport brake start to squeal during normal brakes this week. I found a video on YouTube, which is exactly the same problem. Normal brake has squeal, but no squeaking on hard brakes.
Can anyone help? It's very annoying! Many thanks!
Edited: I tried several hard stops from 40mph to 0. At the end of my drive the squeal disappeared. But not sure if the squeal will come back. Will try later when the brake is cold again.
      02-21-2020, 09:49 AM   #2
thereef510
thereef510's Avatar
Drives: '16 X5 35i, '20 X5 40i
i noticed this on our f15, and the CA said that some about of brake squeal is normal in the winter just because that's how the metal is? idk it didnt really bother me too much so I stopped noticing it
      02-21-2020, 09:52 AM   #3
dream54ing
dream54ing's Avatar
Drives: 428xi F32- X5 X5 G05 -640i F06
well, hard brake every time, problem solved!
i would just take it into the dealership.
      02-21-2020, 10:11 AM   #4
RJJJ
Does it have to be the dealership where I purchased the car? Or any BMW dealerships?
      02-21-2020, 10:13 AM   #5
Marty in NY
Marty in NY's Avatar
Drives: 21 X5 40i, 18 GTi, Snowblower
Any BMW dealer, doesn't matter which one so pick your favorite. BMW honors their warranty at all their dealerships no matter where you bought it.
      02-21-2020, 11:16 AM   #6
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Welcome to the M sport brakes from hell. Had the same issue with my 335i. No way to fix them other then the change the brake pads... once they wear unevenly, and the rotor starts to wear, you will get this squel. Never had the issue with any other car
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      02-21-2020, 11:37 AM   #7
bluzbra
bluzbra's Avatar
Drives: '21 M550i / '20 X5 40i
This is completely normal for high performance brakes. You'll notice the same noise, if not louder, with Carbon Ceramic brakes. Porsche did a nice explanation of this for their vehicles (though this easily applies to all high performance brakes, including those used in BMWs):
Current BMWs - '21 M550i Bernina Grey/Black Nappa, '20 X5 sDrive40i xLine Alpine White/Coffee Extended Merino
Past BMWs - '20 740i, '20 X3M, '19 540i M-Sport, '19 440i GC M-Sport, '18 M3 Comp., '18 X5 sDrive35i, '18 340i, '17 X3 sDrive28i, '15 335i xDrive Sport Line, '14 428i Coupe
realdah57.00
ladra17.50
      02-21-2020, 12:07 PM   #8
RJJJ
So sad. My car has only 700 miles so far, how can it starts to run unevenly. BTW, does the change of brake pad/ rotor due to noise covered under warranty? It should be right?
      02-21-2020, 12:25 PM   #9
dream54ing
dream54ing's Avatar
It should be covered under warranty if dealership confirm its a safety issue. According to a few, if its normal, it will be difficult to argue.
We havent experience any noise with our G05 with Msport brakes, but our 4 series without Msport brakes does have the noise. Brakes on it is practically new, so not sure if its only the Msport brakes.
If its normal, why doesnt it make the noise on most with Msport brakes? IMO, not normal on a car this new.
      02-21-2020, 12:27 PM   #10
dream54ing
dream54ing's Avatar
Is the noise coming from only one side? did you try cleaning your brakes to see if its helps?
      02-21-2020, 12:31 PM   #11
RJJJ
Not sure. But when I rolls down the driver's side window, I can hear it clearly. Tried several hard stops yesterday at 40 mph. Then no more squeals at the end. But I am not sure if it will come back tonight when I drive it...
      02-21-2020, 12:46 PM   #12
bluzbra
bluzbra's Avatar
My 4 series without M-Sport brakes also makes the noise sometimes. It's not the case that every car with M-Sport brakes HAS to make the noise, but if it does (especially if the car is new), I wouldn't be alarmed. The squeaking noise is a natural side effect of the brakes, not an intended function of it. So it doesn't HAVE to make the noise, but it COULD make the noise. While some experience it, some may not. Depends on the brakes, the driver, weather, how hard you're braking, etc. If you take it to the dealer, I can almost guarantee they will advise it is operating as designed and there is nothing wrong with them.
      02-21-2020, 01:13 PM   #13
BMWDude2018
BMWDude2018's Avatar
101
Drives: 2014 X5 5.0i
2020 X5 M50i  [0.00]
2018 BMW X3 M40i  [0.00]
2014 BMW X5 5.0ix  [0.00]
Someone linked this in another thread about brake squeals.
In that thread, they suggested that proper brake bedding would reduce or eliminate brake squeaks and squeals.
      02-21-2020, 05:05 PM   #14
Eagl88
Drives: 2020 X5 40i
I just ordered my 2020 X5 40i last Sunday, advisor strongly advised to remove the m-sport brake option. Other than looking cool he said they will squeak and produce a lot more dust than standard. Got virtually every other option ($78k msrp). Sorry this is an issue for you!
      02-21-2020, 05:45 PM   #15
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Surprising no squeaks yet after 2,467 miles and quieter than my M550i but lots of dust LOL.
Did find this video from BMW M
realdah57.00
      02-21-2020, 09:10 PM   #16
Paladin1
Paladin1's Avatar
Drives: 2022 iX xDrive50, DGM
This. With any high performance brakes. The most important part (other than finding a safe stretch of road to do it) is not letting the car come to a complete stop between sessions while braking - this will indeed cause squealing down the road, so to speak. This process "burns in" and polishes the pads to the rotors so you don't have uneven or rough surfaces to brake against, causing squeal. A little noise is normal with high performance brakes - nature of the beast: large surface area, high pressure, quick stop.
      02-21-2020, 11:38 PM   #17
RJJJ
Sigh, M50i come standard with m sport brake, no way to get rid of it....
      02-21-2020, 11:39 PM   #18
RJJJ
I followed the instruction. Now there is no squeaking, but not sure what will happen later.
      02-21-2020, 11:41 PM   #19
RJJJ
Remind me of Porsche.... the biggest reason I didn't go for cayenne coupe was always brake squeal during test drive. Sadly M50i has the same problem.
      02-22-2020, 09:07 AM   #20
hodgson-p@hotmail.co.uk
Phil
41
Drives: Bmw g05
I notice mine with the m sport breaks on are noisy if they are not cleaned often. Once it’s been washed it’s fine after that
      02-22-2020, 02:47 PM   #21
RJJJ
Emmm, but does washing frequently cause corrosion?
      02-22-2020, 03:02 PM   #22
bioman
173
Drives: E30
Try bedding in your brakes to see if that helps reduce the noise.
