      02-23-2020, 03:00 PM   #1
jojo t
Drives: 2020 BMW X5
Just got rid of last chrome
Just got rid of last chrome on back of car (badges and exhaust tips). Now have all black grill, wheels and badges. Used plasti dip for the badges and exhaust tips. Love the way it turned out
Appreciate 4
perikifi165.50
Chuck W.356.00
radmjk240.50
      02-23-2020, 03:01 PM   #2
jojo t
Drives: 2020 BMW X5
I still have a little clean up to do inside exhaust tips to make it perfect
      02-23-2020, 03:20 PM   #3
VTENGR
1053
Drives: 2020 X5 M50i
I'm assuming you did plasti-dip or something similar? It'll be interesting how it holds up against the exhaust heat.
      02-23-2020, 03:34 PM   #4
jojo t
Drives: 2020 BMW X5
Yes, plasti dip. It holds up up to 200°. Those plastic pieces would melt at that temp. I also saw a video on you tube where the actual metal pipe tips were plasti dipped and it lasted long time. If they dont I will then replace the parts with black oem
      02-23-2020, 04:01 PM   #5
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
Missing the roundel ....
Looks like good work with the Plasti dip.
Recently I decided to just debadge.
      02-23-2020, 05:06 PM   #6
atl_1M
Drives: '11 1M, '20 X5 40i
Did you tape between the letters and numbers or did you let the plastidip build up there and just peel off? Thinking of doing the same to my badges.
      02-23-2020, 06:16 PM   #7
jojo t
Drives: 2020 BMW X5
take a look at the second pic, tape is about an inch from the numbers. It isnt a difficult thing to do just a bit time consuming. 6 coats with 30 min between coats and then the time to tape off and clean up. Well worth it as I love the look
      02-23-2020, 06:21 PM   #8
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Wow, that's brave painting those badges right on the car, no matter how great the masking looks ... particularly since those badges take 60 seconds to remove the whole set and trivial to reattach with replacement 3M tape :-).
      02-23-2020, 06:25 PM   #9
jojo t
Drives: 2020 BMW X5
but thats the beauty of plasti dip. it sticks to the badge and peels right off the paint as long as it has dried.
check a how to video on you tube to learn. its a very forgiving product
      02-23-2020, 06:26 PM   #10
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Cool, will do. Great job.
      02-24-2020, 08:21 AM   #11
The Libertine
The Libertine's Avatar
Drives: 2021 Porsche Macan
Looks awesome! Can’t stand chrome either....
      02-24-2020, 08:27 AM   #12
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
The hue actually looks like it matches the lower dark charcoal in the bumper. I like it. If it holds up for 2 years and you have to redo it, who cares. It’s cheap and easy enough to redo. These are the fun little jobs that have little risk in trying.
      02-24-2020, 08:57 AM   #13
atl_1M
Thanks. I'll try it out. I'm going to add the glossifier on top also to give it a shinier look.
      03-28-2022, 05:36 PM   #14
wendyp
Drives: BMW X5 45e
How is this holding up? I've done a bit of plastidipping on my older ride (2005) and really interested to do our new 45e.
Did you use this primer? https://www.amazon.com/Plasti-Dip-41...0B2MRE5E&psc=1
I wonder if it helps at all long term. I feel like the chrome isn't a great surface for rubber sticking, but 6 coats is 6 coats :-)
      03-28-2022, 09:13 PM   #15
cellarrat
Drives: 2022 X5 45e
That is the cleanest garage I have ever seen!
      03-28-2022, 10:12 PM   #16
Chuck W.
Chuck W.'s Avatar
356
Drives: '95 Porsche 993 Cab
Nicely done. That looks great.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
      03-29-2022, 10:59 AM   #17
Stoshu
Stoshu's Avatar
Drives: 2021 BMW X5 M50i
Amazing!
Funny how 15 years ago chrome everything was the way to go, now not so much although I still like some as a contrast. I guess that’s why they have different options.
      06-28-2022, 05:11 PM   #18
jojo t
Drives: 2020 BMW X5
I just thought I would follow up on this thread. I saw wendyp asked how it is holding up. Nearing 2 1/2 years now and it looks as good as it did in the pictures above.
      06-30-2022, 12:19 AM   #19
SeldomSeenKid
Drives: 2022 X5 xDrive40i
+1 bump to this.
I am also interested in doing this to my new Arctic Grey X5 xDrive 40i
      08-28-2023, 09:57 AM   #20
jojo t
Drives: 2020 BMW X5
just another follow up. Now well over 3 1/2 years and they have not changed at all. Same with the exhaust tips. They look like the day I sprayed them. Just FYI
Appreciate 3
eelnoraa2032.50
Mtn2Srf282.00
radmjk240.50
      08-28-2023, 07:12 PM   #21
eelnoraa
Drives: G05 X5
After you spray the badge with plastic dip, do you use a razer to cut around the edge (carefully), and pill out the unwanted coverage?
2022 G05 B58/PHEV
+ a few very old BMWs
      08-28-2023, 08:04 PM   #22
Tejas1836
Tejas1836's Avatar
996
Drives: 2023 X5MC Workmaster 75
Stealth, visually and aurally, is the correct path.
Two is One and One is None
