02-15-2021, 04:15 PM | #45 |
Rep 274
I purchased this one and it's working well. Supplied hooks attach to the floor rings in the G05 45e front cargo area. The loops on the top side easily reach and go around the pull down hooks on the upper sides of the cargo area. It's not too taunt but that allows it to easily rest along the tailgate when not attached to the side hooks. Serving its purpose very well.
Premium Quality Adjustable... https://www.amazon.com/dp/B0756J1SM6...p_mob_ap_share |
02-17-2021, 12:30 AM | #46 | |
Generalissimo
643
Rep 1,393
Someone here mentioned using this net from previous generation of X5? Is it the same as the one in Europe in the pic below? Thank you. |
02-17-2021, 10:51 AM | #47 | |
Rep 7,489
The 11 digit BMW part nbr is given in post #43 for the flexnet used for the G05 X5.
02-17-2021, 11:19 AM | #48 | |
Rep 1
Do you know which one you ended up picking? (32x24, 35x16, or 40x32) Thanks!! |
02-17-2021, 11:43 AM | #49 | |
Generalissimo
643
Rep 1,393
02-17-2021, 12:50 PM | #50 | ||
Rep 274
02-19-2021, 11:39 AM | #51 |
Generalissimo
643
Rep 1,393
So, can anyone confirm that the part number 51477332111 for the flexnet (the one that goes across the tailgate) fits G05 without the luggage compartment package? I assume it has for hooks - the bottom ones hook on the two the lashing eyes on the cargo floor and the top ones go into the holes by the rear seat release levers, right?
02-19-2021, 02:07 PM | #52 |
1062
Rep 1,540
Is there a cargo net that separates the cargo area from the passenger? None on BMWUSA site and I need something along those lines. Amazon alternative 🤔 available that somebody would like to recommend?
02-20-2021, 03:10 PM | #53 |
Happy M Driver
241
Rep 390
Hey Folks,
As some have already noted, if you get the Luggage Compartment Package you also get the netting to attach to the rear-most part of the luggage space. I appreciated the DIY tip on adding bungie cords to the small side compartments. Well, I thought this was a good idea and was going to do the same. Apparently, part of the Luggage Compartment Package includes netting for those small side compartments! Yeah, just goes to show how much I paid attention... Anyway, thought I'd share some pix for reference, and hope they help some folks for reference. I also included a picture of the luggage compartment door being lifted to show the spare tire -- I guess if you have the spare, they have to install TWO shocks/lifters instead of just ONE when you don't order the spare tire option. Cheers, -Tony
2020 X5 40i M Sport - The "Unicorn" (B&W Sound, Touch Screen, Heated/Cooled Cup Holders, Soft Close Doors, Acoustic Glass, Full Alcantara & Glass Controls, Luggage Compartment Package, Heated/Ventilated Seats, Laser Lights, Fog Lights)
2016 M4 Coupe; 2008 Dinan S1 M5; 2006 530i; 1998 328i |
thereef5101165.00 |
02-20-2021, 03:31 PM | #54 |
311
Rep 332
Quick question: how did you hook the net at the top?
I have the lashing eyes at the bottom (floor of the cargo area) but can't see where you hooked up top
SSMXV
02-20-2021, 03:34 PM | #55 |
Happy M Driver
241
Rep 390
There is a hole, on both sides, to simply drop in the hook.
02-20-2021, 03:37 PM | #56 | |
311
Rep 332
Thank you for the help!
SSMXV
02-20-2021, 04:45 PM | #57 |
Generalissimo
643
Rep 1,393
Anyone knows whether this is the flexnet part number 51477332111 and whether it will fit G05s without the luggage compartment package?
02-20-2021, 04:55 PM | #59 | |
311
Rep 332
I couldn't really tell as it gets a bit pixelated when I zoom in but now that you mention it, I see the hooks. I tested my existing net a short while ago and it's the perfect size. Should be easy enough to rig some hooks to it.
SSMXV
02-20-2021, 06:20 PM | #60 |
Rep 3,933
02-20-2021, 07:20 PM | #61 | |
311
Rep 332
I had a few extra Nite Ize ones lying around and they do the job well. I might get some smaller ones with a 10lb rating as the 25lb ones are a bit bigger but the look clean, install easy, and most importantly I don't have to get a new net
SSMXV
02-20-2021, 10:39 PM | #62 | |
Generalissimo
643
Rep 1,393
02-22-2021, 04:30 PM | #63 | |
Rep 422
These are the options I came across for the side cargo nets: -Rear Cover P/N 51-47-7-479-782 -Storage Net Storage Comp.Lug 51409947 P/N 51-47-9-471-112 The second option is for the X3 but it indicates that it fits the G05 X5 Last edited by lknbimmers; 02-22-2021 at 04:37 PM.. |
04-18-2021, 04:50 AM | #64 |
Rep 72
Is there any type of net that goes above the middle row of seats that stops something from flying out of the boot space and into the middle row of seats?
My g31 5 series touring had this as standard but it would need hooks on the ceiling roof about the headrest to clip into |
04-22-2021, 12:53 AM | #65 | |
Rep 274
Cargo net
https://smile.amazon.com/dp/B0756J1S...v_ov_lig_dp_it |
04-22-2021, 01:17 PM | #66 |
817
Rep 1,785
I'm using one from a Lexus RX. Fits perfectly.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
