03-08-2024, 09:38 AM | #23 | |
13269
Rep 19,789
03-08-2024, 09:40 AM | #24 |
Rep 464
This update went fine no hitches, but the previous one bricked the car.
If this happens to people and it's stuck in the garage, call BMW and try to get it elevated, some kind of tech remotely enabled the car again and it was fine.. I just drove it to the dealership to get it updated instead of having a tow truck drag the car there. |
03-08-2024, 03:21 PM | #25 |
Rep 105
Do you mean the BMW dealer I got it from or BMWNA? Just in case
2021 X5 xDrive40i M-Sport | Phytonic Blue / Cognac
03-08-2024, 05:44 PM | #26 |
Rep 646
Been a good 6 weeks since "preparations for upgrade to version 03/2023.67 complete". What is the significance of this version? Year 2023?
Driving a 2019, iDrive 7. I booted the iDrive via the volume knob today. Car remains parked in a garage. Still nothing.......... |
03-08-2024, 06:06 PM | #27 | |
13269
Rep 19,789
Mixitt372.00 |
03-09-2024, 07:39 AM | #29 |
20
Rep 36
I read this thread and tried the following after the software had downloaded to the car and was waiting for the install prompt.
(1) I plugged the trickle charger, waited until fully charged. ~12 hours (2) I checked iDrive, but no message to upgrade software. (3) iDrive off. I used Bimmerlink and cleared all errors (not just the head unit errors, but all). Charger still connected. iDrive on, no message to upgrade. (4) Let trickle charger top off the battery again (5) I repeated step #3 again (6) This time I got the install prompt when I turned on iDrive, I accepted, let it upgrade. All good now. 2022 X6M Thank you TurtleBoy |
03-09-2024, 11:20 AM | #30 |
Rep 8,815
I’ve tried everything listed here from clearing codes to charging my battery well over 90% to parking it outdoors and the car just wouldn’t give me the option to install. I give up at this point. Insane how I’ve done this atleast twice before without any issues but somehow this one is different.
Alan |
03-09-2024, 01:04 PM | #31 | |
13269
Rep 19,789
03-09-2024, 01:50 PM | #32 |
Rep 98
Bought the vehicle in 8/2023 and a few weeks later, I installed a software update.
Just now, I installed V.11/2023.50. So far I'm 2 for 2. Don't know what I'm doing wrong..
2023. X5 M50i
2019. F150 SCREW 3.5 L Ecoboost |
E91toG05342.50 |
03-10-2024, 08:59 PM | #33 |
The Wolf
247
Rep 987
Drives: stuff
I manually charged both batteries to full 13.0v, cleared fault 038400, fault still returns. No update takes place, frustrating. Currently on 3/2023 that was dealer installed.
03-10-2024, 09:24 PM | #35 |
13269
Rep 19,789
No, it is a general error and not specified. Definitely not the parking brake though.
03-10-2024, 09:40 PM | #36 | |
13269
Rep 19,789
By manually, you don't mean that you connected the charger directly to the battery do you? Hopefully not as that can cause various issues.
03-10-2024, 09:42 PM | #37 |
The Wolf
247
Rep 987
Drives: stuff
I disconnected the batteries from the car and charged them, yes I left charger on charge points also when finished and batteries reconnected to no avail.
03-10-2024, 09:45 PM | #38 |
13269
Rep 19,789
Not that it will help us but it seems like they may have figured out the update process for the 8/8.5 vehicles. Unfortunately they likely won't do anything the the iD7's.
03-18-2024, 02:09 PM | #39 |
Rep 7
So I FINALLY got mine to update after being frozen on waiting for installation.
I have a 2020 X5 xDrive 4.0, and went from 03/2023 to 11/2023. I have the original 12V and lithium ion battery. My steps will differ in that I have a voltage stabilizer / battery charger. I tried a 4A trickle charger but it did not work for me, but I also did not come across this thread until after i got my voltage stabilizer / battery charger. I did this in my garage at a 1 degree incline and it was 67 degrees outside. My hood was open for the entire upgrade process. I got a free trial to use my car's AT&T mobile hotspot, sorry but I don't know if this would have changed the outcome or not for me. 1. Let car sit overnight to completely cool down. 2. Pop hood and plug in voltage stabilizer or battery charger that can maintain 14.0V when requested by the vehicle (something that will let you set to 14.0V or 14.4V and has 20A or over). 3. Get inside car, ensure door is closed. Confirm in xView (Car > Driving Information > xView) that you are parked at less than 12 degree incline. Confirm your phone is with you as well as your key. 4. Confirm parking brake is set and car is in park. 5. Put the car into diagnostic mode. iDrive will remain on. Turn off external lights. 6. Go into bimmerlink, and clear all codes that you can. 7. If not in your sensor values menu in bimmerlink, bring in "supply voltage" and confirm it is 14.10V. 8. Unplug your OBD2 plug or bluetooth dongle. 9. Exit diagnostic mode by pressing the start / stop button once. 10. Press start / stop button again to turn on iDrive. At this point, I was prompted to upgrade. 11. Upgrade took about 20 minutes, and was successful. Hope this helps someone. |
03-18-2024, 02:28 PM | #40 | |
The Wolf
247
Rep 987
Drives: stuff
03-18-2024, 02:33 PM | #41 |
13269
Rep 19,789
I would think just about every charger out there will. I use a Schumacher SC1281 and it works fine.
03-18-2024, 03:23 PM | #42 | |
The Wolf
247
Rep 987
Drives: stuff
Getting close! Maybe a big jumpbox will work?
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
03-18-2024, 03:24 PM | #43 |
Rep 105
It seems more uncommon for the upgrade to actually work than it should be. I got mine updated from 11/2019 ( i believe ) to 03/2023.67. I think I'm just going to keep it there unless there is something that 11/2023.50 solves. Other people are having brick issues and it just seems not worth it to me to risk it.
03-18-2024, 03:32 PM | #44 | |
13269
Rep 19,789
