03-18-2024, 03:35 PM | #45 |
The Wolf
247
Rep 987
Drives: stuff
I got close with my USB pack but it won't supply 14v for very long, my m340 had this problem for 3/2023 and dealer had to update but I sold it to a friend and he had no problem updating with OTA without connecting anything. Nor did any of my x3 m40i friends. I had hoped my m850 would be solved as well. I only have small 1-4a battery tender devices and they won't supply enough to please the car.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
03-18-2024, 05:51 PM | #46 |
The Wolf
247
Rep 987
Drives: stuff
Went and got a centech battery charger, set 12v 40a boost mode and it worked... We are up to date!
03-18-2024, 05:55 PM | #47 |
13269
Rep 19,789
I don't see an AGM mode, are you sure that has one? If not I wouldn't use it.
03-18-2024, 05:58 PM | #48 |
The Wolf
247
Rep 987
Drives: stuff
I was just using to supply 13.6v to charge points only, batteries been trickle charger several times.
03-18-2024, 06:27 PM | #49 |
13269
Rep 19,789
I understand but it is an AGM battery so AGM battery chargers/maintainers are what is recommended.
03-18-2024, 06:42 PM | #50 |
The Wolf
247
Rep 987
Drives: stuff
Tnx
03-19-2024, 11:27 AM | #51 |
Rep 7
I used this one off of Amazon: https://a.co/d/gazTJse
03-19-2024, 12:06 PM | #52 | |
Rep 7
03-19-2024, 04:46 PM | #53 | |
13269
Rep 19,789
03-19-2024, 07:46 PM | #54 |
11
Rep 36
I followed:
(1) I plugged the trickle charger, waited until fully charged. ~12 hours (2) I checked iDrive, but no message to upgrade software. (3) iDrive off. I used Bimmerlink and cleared all errors (not just the head unit errors, but all). Charger still connected. iDrive on, no message to upgrade. (4) Let trickle charger top off the battery again (5) I repeated step #3 again (6) This time I got the install prompt when I turned on iDrive, I accepted, let it upgrade. I used a Schumacher SC1281 to charge the battery and left connected during the above process. |
El_zorro20.00 |
03-20-2024, 11:44 AM | #55 | |
Rep 7
I only use it to maintain 14.0V voltage for updating and programming, after I use my 4A Duracell Battery Charger (https://a.co/d/fChn8YQ) to charge it to 90-100%. That Duracell one should be good for AGM charging. |
04-06-2024, 05:04 PM | #56 |
Rep 1
Hello Guys,
So i did the update, In these steps 1. connected the obd 2. started bimmercode 3. I selected that i have mounted a new battery 4. check battery status ( it was 100%) 5. clear the codes 6. restarted the idrive( push vol button with ignation on for 10 sec) 7. and the update button was there( lets update) |
04-14-2024, 07:35 PM | #57 | |
BMW CCA 69606
86
Rep 227
Charge AGM at constant 14.8v until current reaches to 2.5 amp. Charge Li-ion at constant 14.0v until current reaches 2.5 amp. |
