      09-22-2022, 12:35 AM   #1
FiEXHAUST
FiEXHAUST's Avatar
197
Drives: BMW 1-8, M and X series
Activate Performance Sound for G06 X6 40i / M50i w/ Valvetronic Fi EXHAUST
Activate Performance Sound for G06 X6 40i w/ Valvetronic Fi EXHAUST
Fi EXHAUST X6 G06 40i product page: click here
Frequency Intelligent Exhaust provides the best of both worlds. It’s the perfect exhaust system for those who want to cruise in comfort and experience sports car resonance and Fi EXHAUST signature frequency at a press of a button.
The Fi EXHAUST has been rigorously tested to offer the highest performance and optimal sound frequency. The exhaust is built from high grade stainless steel material and masterfully detailed and finished using TIG welding producing high quality and clean welds.
When valves are closed exhaust gasses are routed through the muffler resulting in a low-profile comfortable drive. When valves are fully open for maximum flow and performance it creates an exotic tone, intense sports car sound with signature Fi EXHAUST frequency. With Fi EXHAUST valvetronic catback exhaust achieve 90.6 dB sound level with valves closed, and increase the sound level by 111 dB with valves open
The exhaust is also compatible with OEM electric valves giving car owners an option to regulate sound volume using OEM sport mode. Additionally Fi EXHAUST users can select an OBD2 remote controller upgrade with a mobile application functionality to switch between comfort and sport exhaust sound profiles.
Fi EXHAUST Valvetronic technology and built-in intelligent control allows users to switch between Comfort and Sport sound modes with one click – swiftly and smoothly. With the mobile application a driver can set up auto mode preferences based on RPM, Speed and Turbo Boost and delete O2 related CEL error codes. Depending on the selected auto mode valves are going to intelligently switch after reaching a set data unit.
BMW G06 X6 40i features:
  • Full turboback valvetronic exhaust system, which includes a front pipe, mid pipe, valvetronic muffler and downpipe.
  • 3 downpipe options to regulate exhaust gas flow and sound: Ultra high flow catless , Racing 100 Cell and Sport 200 cell downpipes.
  • Fi EXHAUST valve modes are compatible with a BMW OEM sport button.
  • Manufactured from a high-grade T304 stainless steel.
  • Expert TIG welding techniques.
  • Weight reduction compared to OEM/Stock exhaust.
  • Comfort/Sport exhaust sound profiles.
  • Rigorously sound tuned exhaust sound frequency.
  • Horsepower increase and low back pressure.
  • Guaranteed bolt-on fitment using precision crafted design.
  • Compatible with OEM exhaust tip outlets.
  • Intelligent ECU exhaust control valve with intelligent controller and mobile APP functionality upgrade.
  • Remote Control and Mobile APP on iOS and Android devices is available (optional).
  • Available for G05 / G06 X5 / X6 40i models.
  • Only downpipes are currently available for the M Series G05 / G06 X5 / X6 M50i models.
  • Available for OPF and Non-OPF vehicles.
Fi EXHAUST mobile APP allows users to choose between 2 valves modes ON/OFF or set it on auto mode. When on auto mode the system will automatically detect the engine's RPM/Speed/Turbo and intelligently switch between valve modes. Depending on a selected auto mode valves are going to automatically open after reaching a set data unit, for example, at 3000 RPM.
After installing catless downpipes and pairing them with an aftermarket tune by YD Motorsports power on the X6 G06 M50i was increased from 603.09whp @6120 RPM to 616.63whp @6070 RPM.
      09-30-2022, 08:29 PM   #2
NYCX5M50i
Drives: 2021 X5 M50i executive/DHP
beautiful setup. But decrease in tq??
      10-06-2022, 02:07 AM   #3
kokozaurs
Drives: 2022 X5M50i
what's the price? thanks
      10-07-2022, 12:49 AM   #4
FiEXHAUST
FiEXHAUST's Avatar
197
Normally, good gains on the top end and slight losses on the bottom end. But if you tune it right, reducing backpressure and increasing exhaust velocity, it does not really reduce torque on forced induction set-ups. But for NA vehicles, yes, torque would usually decrease but very slightly.
      10-07-2022, 12:50 AM   #5
FiEXHAUST
FiEXHAUST's Avatar
197
We'll send a dm, please check your private message. Thanks.
AAA59.00
      06-21-2023, 01:42 AM   #6
An2610
An2610's Avatar
30
Drives: Bmw g05 Bmw e66
Just sent the inquiry on the website. Will the downpipe throw check engine light ?
      07-25-2023, 02:58 PM   #7
hitter07
Drives: X5 s40i
Whats price for an x5 40i 2020?
      07-25-2023, 04:56 PM   #8
Bucksn6
Drives: BMW x5m50i
To be clear, you have a cat back exhaust for the x5 m50i? And catless DP? Can you send links and price?
Tags
catback, downpipe, exhaust, g05 x5, g06, g06 x6, g06 x6 parts, muffler, valvetronic
