Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > BMW iPhone 5 and iOS 6 Functions, Bluetooth and Y-Cable Overview and FAQ
      06-13-2015, 06:45 PM   #89
rspring
Drives: 2011 BMW 335d
I just bought a 2011 335d with navigation. I don't seem to be able to get it to stream music over bluetooth, but it does stream direction from google maps. Will a software update enable streaming music?
Do I need a Y cable to enable functionality (see songlists, etc) on the iDrive?
Thanks!
      06-18-2015, 10:26 AM   #90
tfvdw2at
Drives: 2008 335i
BMW Head Unit acting funky with iPhone 5S
I have a 2008 E90 and use my iPhone 5S with an OEM Y-cable connected to the USB and headphone ports in the armrest. I use an Apple dock connector to Lightning adaptor. I will be riding along, listening to music from my phone and all of a sudden the radio comes on. When I hit the Source button, instead of having Radio, CD and iPod, I get Radio, CD, Aux and USB. I have to disconnect the iPhone and restart it for the iPod choice to come back on the head unit. The radio codes are S645A and S663A. Has anyone else seen this behavior and know of a cure? Thanks!
      06-18-2015, 11:41 AM   #91
alexwhittemore
111
Drives: 2009 Crimson 328i
I and many find it happens with low quality Y cables. They can be incredibly touchy, even when it seems like physical manipulation doesn't correlate.
      06-18-2015, 12:09 PM   #92
tfvdw2at
Drives: 2008 335i
Thanks alexwhittemore! The cable I am using is OEM, but I will swap it out for another one and see if I have any more luck. Cheers!
      06-30-2015, 07:28 AM   #93
hellomyBMW
Drives: 2012 BMW X6 50i
I am having trouble connecting to BMW Connected App (iPhone 5) via original Apple cable (white) to my 2012 X6 50i with CIC navigation. I can stream music off my iPhone no problem but BMW Connected App will not work...
Can anyone please assist me?
      07-04-2015, 03:22 PM   #94
Jamesmccue
Drives: X3 F25 2012
I have been using the Tune2air y cable in my 02/2010 e91. It has been working superbly, streaming Spotify from my iPhone. Thanks to all those who recommended it
However, since the iPhone OS update I have lost the ability to skip tracks using the wheel buttons. Still streams ok with iPhone controls. Also, the currently playing information does not work. Has anyone had this problem?
      07-04-2015, 03:46 PM   #95
LHR
Drives: 2010 335xi E90
I have a 2010 335xi So if I'm understanding correctly I can NOT listen to music from iPhone 5s via bluetooth just phone calls only? Y cable is the only way to listen to music from iPhone?
      07-04-2015, 04:10 PM   #96
Jamesmccue
Drives: X3 F25 2012
That's right. That's why the Tune2air 3000 is such a good thing. Bluetooth streaming as long as you have the USB/aux in your armrest I believe.
      07-17-2015, 04:58 PM   #97
neeko13
Drives: 335i
SOLVED ALL YOUR BLUETOOTH PROBLEMSwARMREST JACKS $3 includes shipping
http://www.ebay.com/itm/261914860500...%3AMEBIDX%3AIT
3.5mm usb bluetooth convert.
Cost $3 and that was with shipping from china. Still uses the normal bluetooth phone controls and uses the music overbluetooth.
Seemlessly connects and switch back and forth.
FRIGGEN MONEY!
Side note I would recommend a 6 inch 3.5mm right angle male to male connector. Mine came with a long cable. This keeps it tight
POINT BEING = That Y cable sucks and is way overpriced.
      06-11-2016, 03:47 PM   #98
Mycallways
Drives: 2010 335xi
So.
I have 2010 335i xdrive. Have the Tune2air bluetooth adapter. It works, however, I cannot skip tracks or see the track info on iDrive. I must use my phone to control.
What's up with that? Any useful fixes?
      06-12-2016, 12:15 AM   #99
alexwhittemore
111
Originally Posted by Mycallways View Post
So.
When you plug in your phone directly with USB, does it work?
If so, you probably HAVE a WMA3000B, when you NEED a WMA2000.
      07-09-2016, 03:34 PM   #100
tkong
Drives: 335i 2011 space gray
According to the Viseeo website, WMA3000B is the correct one for a bmw for full steering controls. If I already have the bmw y-cable 30 pin, am i better off buying the WMA1000 from amazon or ebay, even though they dont make it anymore?
I am looking for a different method than my 30 pin y-cable and lightning cable adapter for my iphone 6 because I have been having issues with my CIC only registering the aux and not the presence of the USB as well.
      08-08-2016, 06:45 PM   #101
nn42day
United Kingdom
Drives: BMW 320d LCI
2009 LCI E90 Audio streaming
I have recently purchased a 2009 320d With iDrive and Bluetooth.
My iPhone 6 has connected OK for calls but I can't stream audio.
I have ready many posts about a Y cable that is used to connect to the aux and USB port located in the centre console, however I don't have a USB port, just a AUX.
Will this still work or do I need to buy a different adaptor?
There is a USB port in the glove box but I think this is for charging only as IDrive did not detect my phone when I plugged into nor an iPod 5th gen.
Many thanks
      03-18-2017, 10:07 AM   #102
MikewhitE92
Drives: M2 Competition
Hi all, not sure how to start a new post so will try here first. I have a 2009 e92 with the aux and USB in the glovebox. I have an offices bmw lightning y cable, the music plays, however I cannot control it through iDrive. The music isn't displayed at all and you cannot change tracks with idrive nor the steering wheel buttons. Any help would be great.
Thanks
      03-20-2017, 11:54 AM   #103
alexwhittemore
111
Thanks
Someone else with iDrive would know better, but I believe you don't actually have an iPod interface option in your car. The USB jack in the glovebox is for the iDrive system, not an iPod. You'd have to have one in the armrest for the iPod interface. Try putting your VIN in https://www.bmwvin.com/ and see which options come up. S6FL should be there if you've got the iPod interface option.
      09-18-2018, 04:04 PM   #104
grandosegood
Drives: 2009 328i
Hi everyone,
At the dealer, they wanted $100 to get the new Y-cable that has a lightning connector already built into it. I have an iphone 7 and my friend has an SE. Is there a cheaper alternative that will give us control from the car and audio as well? I have a 2009 328i. Thanks!
      03-30-2019, 07:08 AM   #105
John Reed
Drives: x3
Cool my small story
Hello everyone, yes, I had a similar problem, it was very annoying for me, so I decided to replace all the wiring, speakers, control units, put a new amplifier, and a head unit. Yes, With Android no problem I spent a lot but it was worth it.
      09-03-2020, 02:00 PM   #106
Hazazzel
Drives: BMW 320d E90
Hello everybody,
Recently i bought BMW E90 320D (2006) which has CIC unit (i suppose retrofitted because i couldn't find any E90 from that year with CIC).
The problem that i'm facing is the both aux ports (glovebox and armrest) are not working ( i tried to connect them with 3.5 to 3.5mm cable with iphone xs max, iphone 5S, ipad mini, huawei_ and nothing happens, when i select External devices -> AUX -> there is no sound. I checked volume, checked everything, but still no sound.
In the glovebox there is also an USB port, which is working fine for listening to music from usb (although i can't inport the songs, it gives me the message that there is no USB in the glovebox, but yet somehow i can listen to that music ?!)
While searching online i also found on terms like MULF2 and COMBOX, i checked my trunk below the carpet and there is none of them i cant find anything. I have option to connect my phone with bluetooth but only for calls, not for audio.
Could anyone help me solve this problem? My idea is to connect the phone with AUX and listen to some better radio online (via tunein for example)
Thank you in advance.
Tags
bmw ios 6, bmw ios6, bmw iphone, bmw iphone 5, bmw iphone 5 adapter, bmw iphone 5 bluetooth, bmw iphone 5 cradle, bmw iphone 5 snap in adapter, bmw iphone 5 y-cable, bmw iphone adapter, bmw iphone snap-in adapter, bmw iphone5, bmw iphone5 adapter, bmw iphone5 bluetooth, bmw iphone5 cradle, bmw iphone5 snap in adapter, bmw iphone5 y-cable, ios 6 bmw, ios6 bmw, iphone 5 bmw adapter, iphone 5 bmw cradle, iphone 5 bmw snap in adapter, iphone bmw adapter, iphone bmw snap in adapter, iphone5 bmw adapter, iphone5 bmw cradle
