12-05-2019, 01:45 PM | #641 |
Rep 978
12-05-2019, 02:21 PM | #642 | |
1198
Rep 1,587
Retrofit details are all over this board. Coding 1CR does not activate remote engine start. Gets very close but no cigar. Looks like it needs an FSC that is not publicly available. Good enough for you boss |
12-07-2019, 05:15 PM | #643 | |||
Rep 2,609
eagle_bmw182.50 |
12-07-2019, 07:05 PM | #644 | ||||
Rep 419
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
12-07-2019, 07:08 PM | #645 |
Rep 2,609
Yes, iOS Bimmercode 3.4, KOMBI ECU Expert Mode (see below). I haven't had time to hook up ESys yet, but need to do that soon: software update cleared all coding, including even anti-dazzle FA coding.
ADV Coding: - KOMBI, Expert Mode - search for and set Aktiv each of: CB_FZG_UMGEBUNG_FAS CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG PIA_FZG_UMGEBUNG_FAS SICHT_ABSICHT_ENABLE
eagle_bmw182.50 |
12-07-2019, 07:43 PM | #646 | |
Rep 419
2019 X5 40i M-Sport
12-08-2019, 03:21 AM | #647 |
1198
Rep 1,587
When you get chance, in esys, can you try and 'Code' the new DSC_VIP_IB2 ecu?
I get an error since 11/2019.34 was flashed. Want to see if it's systematic or a dealer programming issue. Last edited by ifr; 12-08-2019 at 06:27 AM.. |
12-08-2019, 10:57 AM | #649 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
OBDlink app dashboards, will try to post videos to watch them working
12-08-2019, 02:54 PM | #651 |
Rep 2,609
"Interesting", but to the first question, find this spot in Settings/General:
12-08-2019, 05:14 PM | #652 |
Rep 2,609
Not sure if this is good news for you or not good news, but ... I am able to code it without issue and get the usual "0 errors" (code NCD with NCD file unchanged from just read). My file/version is: CAFD_00003D14_008_002_005. Let me know if I can send you any of my files to help to compare/diagnose.
12-08-2019, 05:43 PM | #653 | |
1198
Rep 1,587
Can you just 'Code' rather than Code NCD, so it's not using the launcher token, and can just be run from esys directly without launcher involved? That's the scenario I have the issue with for that new Ecu/cafd |
12-08-2019, 05:47 PM | #654 | ||
Rep 2,609
CaVenGG0.00 |
12-08-2019, 06:26 PM | #655 | |
1198
Rep 1,587
This takes launcher out of the equation reducing risk, and is useful for getting things back to stock before a dealer visit. Well, it is when it works |
12-08-2019, 06:37 PM | #656 | ||
Rep 2,609
I do know the difference between Code and Code NCD, but I just Code-coded most previously modified ECUs to stock before the dealer visit with the regular launcher approach. Is there really a difference between with launcher and without launcher for Code.
12-08-2019, 11:01 PM | #657 |
456bhp for breakfast
425
Rep 913
Thanks to KrisV I tried coding the Assisted Driving View and the Alpina dash tonight.
Like others have reported, I couldn't find KOMBI>3007>PIA_FZG_UMGEBUNG_FAS but it seems to work without this. I am MY2019 and in Canada if that makes any difference. I used expert mode to change the logo for the Alpina dash to X5_M_PERF but I don't see anything. Has anyone resolved how to get the alternative logos to work? I'm still only on 03/2019.53. Hoping OTA is rolled out before she has to spend another day at the dealer. |
eagle_bmw182.50 |
12-08-2019, 11:07 PM | #658 | ||
Rep 2,609
achk132.50 |
12-09-2019, 01:47 AM | #659 | |
1198
Rep 1,587
Not sure how to demonstrate this as a dealer issue. Tricky one! Wrt the differences between stock coding with/without launcher, the logic is that using vanilla esys removes any possible unnecessary developer interaction and it behaves exactly as BMW intended. We only use launcher to work around the security certificate requirements, and more recently to address trimmed mappings. Shawnsheridan is adamant that stock coding should always be done with esys alone. Personally I've never had an issue using launcher for stock coding, but in this case it ensured you were using 'Coding' as 'Coding NCD' wont work without launcher. |
12-09-2019, 07:30 AM | #660 |
Rep 282
Drives: 2023 BMW X5 M Competition
anyone figured out how to code back in HUD TACH in m layout? must be a BimmerCode 3.4 bug...
