      12-04-2019, 02:26 AM   #1
dwjpaypal
Drives: G05
CANBUS Help!!
Hi all,
I've purchased an active sound unit from Cete Automotive, and to install its saying I need to connect up to the
White/yellow
White/blue
CANBUS.
I've literally pulled all of the wrapping tape off from the right hand side in boot where the fuse box is, but can't find these specific colours.
Does anyone have any ideas as to where I can find these colour CANBUS cables???
Car: G05 MY20
Thanks!
David
      12-04-2019, 05:50 PM   #2
dwjpaypal
Drives: G05
Anyone? I just need to know what colour the transmission canbus is in the boot (trunk....)
Rather not splice into any twisted cables to keep testing!!
Any help appreciated
David
      12-04-2019, 07:26 PM   #3
ElectroGeek
Drives: X5 G05 50i
David
why would you even do something like this?
CanBus works only with very specific parameters, if you just cut into CAN HI and CAN LOW without a proper connection you will cause your entire car to do random unwanted things like: randomly shutdown, or go neutral, or idle, or something worse. it's highly unlikely you will find a can hi and can low "spare" set.
      12-05-2019, 07:01 AM   #4
dwjpaypal
Drives: G05
Ok, I've managed to figure it out....!
Basically the G05 only has a CANBUS cable to connect to in the drivers footwell (UK Spec).
The colour cable you need to connect to is;
Yellow/Black & Yellow/White
This is connected to the COM cable, removing the connector block makes the job a lot easier.
All connected up now, will post video over the weekend of the sound module fitted!
Thanks,
David
dcg7172.00
      07-28-2020, 10:52 PM   #5
atlas
Australia
383
Drives: F10 535i, M2 LCI, G05 X5 40i
Was this on the OBD port? Or another bunch of wires? Easy install??
